Contour question? AC - TCCoA Forums
post #1 of 4 (permalink) Old 06-11-2005, 07:26 PM Thread Starter
Stroked and Blown
BlakTbird96's Avatar
Hey guys/gals. I've been having some issues with my air conditioner lately in the Contour. I first noticed a month ago that it was blowing warm air when I tryed using it on a hot day. I took it to the dealer where I bought it because its unde rwarrenty. They replaced the compresser. The ac worked for a few days and then I didnt use it for a while because it wasnt that hot out. I went to finally use it again and it was blowing out warm air. I took it back to the Ford dealer and they replaced some kind of leaking dring? (sp?) near the accumulator assembly. The air worked again for a day and the it started blowing out warm air again. I then took it back to the dealer for the 3rd time (this past monday actually) and they kept the car for 3 days (I got it back yesturday) They told me they found out the compresser they installed was a defected one, so they installed another compresser. This morning on the way to work, it felt really nice and cool. On my way home from work today, it still feels cool, but not as cold as an air conditioner should be. It's almost as if it lost the coolnest over 8.5 hours. I'm starting to think that Norris Ford is dicking around with me and I'm about to get a second opinion. Do any of you know what else this could be? I'd appreciate any help because the summer is here and it's been hot lately.
BTW- I don't like to post over at the Contour Boards because they seem to be real cocky over there, so I would rather ask you all. Thanks, Frank
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #2 of 4 (permalink) Old 06-11-2005, 09:33 PM
Paddycake's Avatar
Hey man sounds like they didn't purge the system before they recharged it. Common Dealer issue they did my Cougar that 3 times before I just ripped off the AC and went with a Steeda eliminator kit.
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #3 of 4 (permalink) Old 06-11-2005, 10:50 PM
jk69cat's Avatar
sounds like they didnt properly diagnois the problem the first time and if you replace a compressor, your supposed to change the orfice and the accumulator/drier . thats what i bet tis the problem, and you may have other leaks in the system
mn12 less!
jk69cat is offline
post #4 of 4 (permalink) Old 06-12-2005, 05:19 PM Thread Starter
Stroked and Blown
Okay, on my way to work this morning, I turned on the ac and it was even warmer. When I left work and turned it on, it was nothing but hot air coming out.
My other home:
Mid-AtlanticMN12's
