Hydraulic Fluid = WTH!!! - TCCoA Forums
post #1 of 3 (permalink) Old 06-13-2005, 07:39 AM Thread Starter
I knew hydraulic fluid is sometimes used to for other things, but this is a new on!!!
http://www.cnn.com/2005/HEALTH/06/13....ap/index.html
I guess if it looks like hydraulic fluid, smells like hydraulic fluid, and feels like hydraulic fluid, it must be..... surgical cleaning fluid!!!
69 F100 LWB w/460 Engine
post #2 of 3 (permalink) Old 06-13-2005, 08:08 AM
How could it cause joint pain?? In theory, wouldn't hydraulic fluid keep you lubed up?
Jay
FordMan77 is offline
post #3 of 3 (permalink) Old 06-13-2005, 09:27 AM
Jack of all trades, Master of none
bobbylx's Avatar
Haha, I work at the other big Hospital system here in Raleigh. I remember when that happened. Our sterile processing department had to do massive inventory and research to prove that we didn't run into the same problem. And we didn't thank god.
In theory, it should not cause any problems. The fluid was used to clean the surgical instruments and then they were sterilized in the autoclave, which will kill anything on it and remove all traces of the fluid. I still wouldn't want anyone operating on me with that stuff though.
Deaf and blind and dumb and born to follow
what you need is someone strong to guide you
bobbylx is offline
