?? uhhh - TCCoA Forums
post #1 of 5 (permalink) Old 10-13-2005, 03:58 PM Thread Starter
gecko2424's Avatar
?? uhhh
http://cgi.ebay.com/ebaymotors/1T198...rdZ1QQtcZphoto
SOLD!!!!
5.4 block from 99 expedition bored .20 over
Forged crank/Manley Rods/JE flat tops/chromemoly rings and Steeda Underdrives
P&P PI heads (by me) w/ 3 angle valve job w/copper gaskets with ARP studs/bolts and One piece lightning cams
80mm Pro-M MAF and Cut & welded '95 4.6 intake
Jmodded Trans & Trac-loc pumpkin (Cobra) 3.27
Raxles, ADDCO 1 1/4", Eibachs, JL Braces
18" CEC type 169 wheels w/ 245/40 front 255/45 rear
gecko2424 is offline
post #2 of 5 (permalink) Old 10-13-2005, 04:18 PM
Traveler's Avatar
LOL I sent him a message a long time ago about those. He thanked me and said he'd make a note of it. He must have lost the note!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 5 (permalink) Old 10-13-2005, 06:17 PM
mercoug302's Avatar
so in other words . . . "No Parking"
1988 XR7
5.8L EFI, tremec 3550,spec stage III clutch,90mm L-MAF, TFS heads, GT40 intake, lunati cam,Fordchip.com,diablo chip 311rwhp 375 rwft/lbs.13.2 @107.2. with 3.08's
2004 Pontiac GTO LS1 6 speed black/red RIP
mercoug302 is offline
post #4 of 5 (permalink) Old 10-13-2005, 08:51 PM
Draggin the Subframe
with Jesus now
RIP Buddy!
JoelBender's Avatar
Pretty much, Ive emailed the retard myself a while back...no response
The one, the only.........Bagged!.....Bottle Fed!......Thunderchicken!!
13.605 @ 99.46 & 13.608 @ 99.78 & 13.610 @ 101.72 on the bottle.
14.782 @ 94.46 at Cecil
14.792 @ 93.38 at Rockingham with new torque converter (2800 stall) 95% humidity, 82 degrees....
284.3 hp @ 4100 rpm, 370.4 ftlb @ 3600 rpm
Your friendly, run of the mill, Psychopathic moderator
NC Chapter Forum Carolina Thunder
TCCoA A-hole crew 2005 "DIASS"
JoelBender is offline
post #5 of 5 (permalink) Old 10-14-2005, 02:51 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
what the hell?!?!? this is a major repost. should we close it?
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
