air compressor psi question - TCCoA Forums
post #1 of 6 (permalink) Old 10-20-2005, 02:40 PM Thread Starter
Jedi Master
mn12xr7's Avatar
at what psi do air tools, such as drills and such, work effectively???
-Orlando
mn12xr7 is offline
post #2 of 6 (permalink) Old 10-20-2005, 02:49 PM
dode's Avatar
most function around 90 psi
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #3 of 6 (permalink) Old 10-20-2005, 02:53 PM Thread Starter
Jedi Master
mn12xr7's Avatar
cool thanx!
-Orlando
mn12xr7 is offline
post #4 of 6 (permalink) Old 10-20-2005, 02:57 PM
It's not only psi, it's also volume.
69 F100 LWB w/460 Engine
post #5 of 6 (permalink) Old 10-20-2005, 03:02 PM
Traveler's Avatar
LOL I'm sure there's a bad joke in there somewher, but I'll let it go!
Basically if the air tool is a high speed type tool (for example a sander, or grinder) its going to require a lot of air volume to use effectively. A small tank will require that the pump run nonstop just trying to keep up with the air being used. Other tools such as an Impact wrench rely more on pressure than volume. I actually used the Sears catalog to learn a lot, as they have charts to indicate what tools require so many gallon tanks.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 6 (permalink) Old 10-20-2005, 03:17 PM
You have to look at CFM ratings at the different pressures and SCFM ratings. Most things won't require more than 90 psi, but things like sand blasting require significant sustained CFM that most consumer mobile compressors can't touch.
Bangster is offline
