Duct Tape Thread... - TCCoA Forums
post #1 of 48 (permalink) Old 10-25-2005, 02:04 PM Thread Starter
Duct Tape Thread...
Every board should have an official "Duct Tape Thread"....
So...
Ok guys and gals, what is the weirdest (keep it clean! ) thing you have done/repaired with duct tape. Try to keep it automotive related...
I'll go first:
I shattered a rear u-joint on my 65 Mustang one night at 2 AM. One complete roll of duct tape wrapped around the drive shaft and the pinion flange and I made it home with no "major" problems (just some nasty vibrations)
I should have just had it towed, because the HOURS it took to cut off all the melted duct tape was a major PITA!
69 F100 LWB w/460 Engine
post #2 of 48 (permalink) Old 10-25-2005, 02:21 PM
Fry Rice Specialist
Casper's Avatar
put 2 stripes of the tape on my wife's mouth to get a piece of my mind.
just joking.....
CarDomain Page
Casper is offline
post #3 of 48 (permalink) Old 10-25-2005, 02:39 PM
a 15 inch Radioshack woofer from 1989. The voice coil tore, and duct tape lasts and make it work for about a year. I get two years out of rubber cementing duct tape to fix it.
Bangster is offline
post #4 of 48 (permalink) Old 10-25-2005, 02:39 PM
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
i used to hold the molding on to the door of my buick with duct tape after it got hit by a pole.
damn poles.
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #5 of 48 (permalink) Old 10-25-2005, 02:45 PM
Who is John Galt?
A few interesting things I've used (or seen) duct tape for. . . . hmmmm:
1.)held my summit banner to the ceiliing all last year (what else do you hold banners up with in a res hall)
2.)held a couple of my classmates to the homecoming bonfire during a raid (they got dumb, they got caught. . .freshmen took care of 'em)
3.)Was holding my POS brass eagle talon together
4.)Was holding in the stereo of my old cavalier (I was the third owner, 1st owner had a stereo in it, took it out, put everything back in with duct tape)
As of now, the Cougar is Duct tape free and it will stay that way.
"Won't work, can't be done"
cougar_guy04 is offline
post #6 of 48 (permalink) Old 10-25-2005, 03:15 PM
Carlover007's Avatar
It made a sick intake setup for my car - for a couple months till the glue fell off
Carlover007 is offline
post #7 of 48 (permalink) Old 10-25-2005, 03:42 PM
Black_97_LX's Avatar
We used duct tape to hold open the broken headlight doors on my mom's old "79 Tbird.
Night was dark, but the sky was blue,
Down the alley, the ice-wagon flew,
Heard a bump, and somebody screamed,
You should have heard just what I seen.
Who do you love?
-Bo Diddley
Black_97_LX is offline
post #8 of 48 (permalink) Old 10-25-2005, 03:43 PM
We put it on a friend's Mustang....the rear e-brake brackets were not bolted to the new Lower control arms, so we noticed they were digging in the tire. Had them Duct taped on for over 6 months.
Also, I have duct tape on the firewall(inside) in my bird, where holes are now present that weren't before.
post #9 of 48 (permalink) Old 10-25-2005, 04:04 PM
The black stuff works pretty good for repairing the bumper cover on an 88 Taurus...
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
doodaa is offline
post #10 of 48 (permalink) Old 10-25-2005, 04:24 PM
jk69cat's Avatar
hey at least that's somewhat close to the orginal use
mn12 less!
jk69cat is offline
post #11 of 48 (permalink) Old 10-25-2005, 04:25 PM
jk69cat's Avatar
had a friend who used a piece of 1/2 plywood and ducttape to fix a hole in the floor of his van
mn12 less!
jk69cat is offline
post #12 of 48 (permalink) Old 10-25-2005, 04:36 PM
Drnaline's Avatar
Repaired upholstery holes, but i prefer to call it universal bonding strip.
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #13 of 48 (permalink) Old 10-25-2005, 04:43 PM
Universal bonding strip... I like that.
Other names?
Minnesota chrome is my favorite followed closely by Alabama welding.
doodaa is offline
post #14 of 48 (permalink) Old 10-25-2005, 04:44 PM
Duct tape combined with great stuff and a rubber shifter boot is what I used to seal the new hole in the floor of my car when I did the T45 swap. So far no problems. Also on my crown vic, the Ebrake has been removed (long story) so now the cable that goes to the back of the car is just duct-taped up to the floor.
Mike
post #15 of 48 (permalink) Old 10-25-2005, 05:13 PM
Drnaline's Avatar
Another name, 200 mile per hour tape. Alabama welding, LOL.
Drnaline is offline
post #16 of 48 (permalink) Old 10-25-2005, 05:50 PM
My shop teacher used to call it racing tape, not sure why though. The best (worst?) one I've ever seen was a Viper GTS with blue duct tape all over the front end. It had been in an accident and the duct tape was holding the cracked bumper and hood together... on a Viper. I'd figure that if you can afford a Viper, you can afford bodywork on said Viper when your dumb *** crashes.
1997 Lincoln Mark VIII
1998 Contour SVT (for sale)
SloMo228 is offline
post #17 of 48 (permalink) Old 10-25-2005, 06:16 PM
alpinebird96's Avatar
Send a message via MSN to alpinebird96 Send a message via Yahoo to alpinebird96
The weirdest thing i've done with it would probably be repairing rotted weatherstripping on the trunk of my Impala. Rolled up some paper towels to fill in the void, DT'd over that and no more dust in my trunk :-)
96 V8 Thunderbird, Alpine Green
01 F150 SuperCrew 4x4
78 Chevy Impala, 305
67 Jeep CJ-5, 225 V6
alpinebird96 is offline
post #18 of 48 (permalink) Old 10-25-2005, 06:30 PM
mamberg's Avatar
ok, it wasn't me, but this is a pretty good use:
The statements in this post are my opinions only.
If you have a problem with them, please PM me
and keep the boards clear of flame wars.
_____________________________________________
mamberg is offline
post #19 of 48 (permalink) Old 10-25-2005, 06:34 PM
Who is John Galt?
Nah, all the money went for car payments and gas.
post #20 of 48 (permalink) Old 10-25-2005, 07:13 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
hm...
My radiator hose blew on my truck. I used duck tape, it lasted for about 20 mins before it melted, hose blew again, and the motor seized. (Anyone want an 85 F-150 4x4.. 351, NP205, 9" Rear..)
Also, when I installed my 97 center console top, the HVAC duct in the console hit the bottom of the cup holer. I cut the duct up, and patched it with duct tape. so far no problems.
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #21 of 48 (permalink) Old 10-25-2005, 08:30 PM
Battery's Avatar
Send a message via AIM to Battery
It's holding my front passenger side corner light on as I type this. It was holding together my intake for a while as well until I broke down and spent the $3 for a rubber coupler.
"It's all in the reflexes"
LE RIP
Now 96 Mark VIII
Battery is offline
post #22 of 48 (permalink) Old 10-25-2005, 09:28 PM
Blue LS's Avatar
Fixed a blown rad hose on my buddys old Tempo for a 2 hour drive back home.
Used it and bondo to patch a rust hole in a car once, still holding to this day.
I think the best was to patch a hole in an oil pan on a truck. Hit a rock when we were off roading and ended up with a 1.5 inch hole. Let it drain out, cleaned up the area around it, slapped some on filled it up and drove back.
Almost forgot, when I had a cast on my right arm I was changing the tranny fluid and filter and got a ****load down the cast. Cut it open cleaned up and used duct tape to seal it up. Man the look on the docs face when he saw that
"She aint a Cadillac and she aint a Rolls, but there aint nothin wrong with the radio"
Of course everyone loves a hard worker, they do all the work!
90 LS - gone damn city drivers
93 Explorer XL 2dr 4x4 - totalled does anyone in that f*ckin city know how to drive
OK, that was twice in 6 months, red means STOP
Blue LS is offline
post #23 of 48 (permalink) Old 10-25-2005, 09:33 PM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
I wrapped a Christmas present for my best friend. It was a CD with some tissue paper around it surrounded by a whole roll of duck tape.
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #24 of 48 (permalink) Old 10-25-2005, 09:34 PM
Send a message via AIM to FasTBird232 Send a message via MSN to FasTBird232 Send a message via Skype™ to FasTBird232
Wrapped my fingers with quartered strips of it when I got blisters during golf season. Also used it to hold my golf bag together after a round of really bad shots (those old leather bags sure as hell can't take a hit from a nine iron).
FasTBird232 is offline
post #25 of 48 (permalink) Old 10-25-2005, 09:35 PM
Blue LS's Avatar
Heres the ones Ive seen customers and other people do.
-Front 1/4 window on a Bronco.
-Dash top, the whole length.
-Duct tape and fiberglass for a sunroof on an old celica.
-half of a vinyl seat
-fender flares
-about 20% of the rear fenders were rusted out and covered with duct tape
-used to hold the trunk shut
Blue LS is offline
post #26 of 48 (permalink) Old 10-25-2005, 11:54 PM
SVT2888's Avatar
Send a message via AIM to SVT2888
Viper Hoods are $11,000!!!!
Mods: Concrete Median
CNCpics.com-Automotive Event Photography
Facebook
Ebay Store
Official B-team member. Viva La Revolucion!
SVT2888 is offline
post #27 of 48 (permalink) Old 10-26-2005, 03:56 AM
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
my turn:
ive seen a rustang convertible with a duct tape top
same rustang had duct tape covering rust on his body panels.
used duct tape for a belt once
used duct tape to hold many sousaphones together
neighbor used shiny duct tape to fix a dent in his trucks chrome bumper
used it once to waterproof size 15 shoes to use in the snow cuz boots get expensive at that size
held a seat belt together with duct tape for three hours
im sure there's more, im just tired of thinking right now
-Steven
Project Rust Prevention: 1990 Buick Regal, Toilet Capacity engine, new trim paint, 57K miles
redneckcougarguy is offline
post #28 of 48 (permalink) Old 10-26-2005, 06:54 AM
Now that I think about it, I've seen a lot of people around here use duct tape as a replacement for a car window that has been busted out. (every one except the windshield)
Who do you love?
-Bo Diddley
post #29 of 48 (permalink) Old 10-26-2005, 07:41 AM
97qwikcat's Avatar
Last time I used it was when we did a heater core on a friend's 92 cougar and we didn't want to take the dash out so we cut the heater box open changed the heater core and duct taped it shut. Wait a minute we did the same thing to his 87 mustang.
My mod's
97qwikcat is offline
post #30 of 48 (permalink) Old 10-26-2005, 08:55 PM
Send a message via MSN to lightining rod Send a message via Yahoo to lightining rod
When I hit a deer with my Tempo I duct taped the turn signal light bulb in the fixture then to the fender of the car. Worked until I made it to the junkyard to get replacement parts. I think it even held the bumper on and the headlight in place. And
my uncle uses it to replace the plastic on doors that seals out dust, works good up until you have to take it off then it can be a pain.
Brian Yakle
02 F150 5.4L ext. cab 4wd - Daily Driver
92 Explorer - Transmission said thats it I quit
86 Firebird - apparently the mighty 2.8L cant handle rpm
lightining rod is offline
