482803.2 - TCCoA Forums
post #1 of 11 (permalink) Old 11-17-2005, 11:10 PM Thread Starter
Trumpeter Extraordinaire
IronChopz's Avatar
482803.2
482803.2
The odometer on my car passed that mark as I drove back from a production of West Side Story Thursday night.
It's significant number, I believe. That's the metric equivalent of 300,000 miles (miles times 1.609344 = kilometers).
No doubt there's more to come. "Next stop: a half-million kilometers."
The car'll get there a lot sooner when I get back into the "hobby job"/daytime work force.
IronChopz is offline
post #2 of 11 (permalink) Old 11-18-2005, 12:33 AM
Send a message via AIM to FasTBird232 Send a message via MSN to FasTBird232 Send a message via Skype™ to FasTBird232
Holy crap. Congrats!
FasTBird232 is offline
post #3 of 11 (permalink) Old 11-18-2005, 12:35 AM
Last Mrk's Avatar
Send a message via AIM to Last Mrk Send a message via Skype™ to Last Mrk
What kind of engine tranny work have you had done to it.
There's a guy on the LOD website forum that has 375,000 miles on original tranny and engine.
Click Here
Last Mrk is offline
post #4 of 11 (permalink) Old 11-18-2005, 07:20 AM
Birdless
Grasshopper's Avatar
Send a message via AIM to Grasshopper Send a message via Yahoo to Grasshopper
That's some big-time seat time, Pete!
A man may smile and bid you hail
Yet wish you to the devil;
But when a good dog wags his tail,
You know he's on the level.
--author unknown
Grasshopper is offline
post #5 of 11 (permalink) Old 11-18-2005, 01:28 PM Thread Starter
IronChopz's Avatar
Engine: original, with some upgrades, and a few replacement items. The car has a RichardM intake, K&N panel filter, an Apten chip, a 180° 'stat, and no air silencer. I installed new OEM fuel injectors and rail this past spring, just for the sake of it.
Other items of note: A few years ago - oil filter mount/gasket replaced, tensioner replaced, Dynomax exhaust installed. A couple years ago -- water pump and radiator replaced, underdrive pulleys. Within the past year -- PBR front brakes, engine mounts and oil pan gasket.
Transmission: "kind of" original. Never replaced, but it was worked on a few years ago at 178,000 miles. The parts description on the invoice read "Master Repair Kit" and "Overhaul Kit" with "Upgraded Parts." When an auxillary cooler was installed and J-mod was performed a year later, I noticed that the parts needed for the valve body were already installed. Amsoil transmission fluid is what I have used ever since.
Routine maintenance items: plugs, wires, belt, EGR/DPFE stuff and other sensors, hoses, flushes, filters, fluids, battery, brake pads/shoes, rotors, tires, etc.
Additional repair items: control arms, tie rods, shocks, springs, power antenna, LH window motor, blower motor, blower motor speed control, A/C hoses, compressor, condenser, accumulator, windshield, fuel door switch, headlight switch, front and rear window reveal mouldings, LH LED taillight, LH door lock actuator.
Some fun stuff: SC seats, power antenna switch, 220kph speedometer, wider tires, bug deflector, OEM CD player, carpeting, fog lights, heavier-duty headlight harness, headlamp assemblies, clear cornering lamps assemblies, incomplete window tinting, tachometer which states "Premium Fuel Only."
I'm certain I haven't listed everything, but, if you take care of the car, it'll keep running well.
post #6 of 11 (permalink) Old 11-18-2005, 01:37 PM
Blue LS's Avatar
Wow, that beats my 351,XXX. Congrats man, keep rackin then up
"She aint a Cadillac and she aint a Rolls, but there aint nothin wrong with the radio"
Of course everyone loves a hard worker, they do all the work!
90 LS - gone damn city drivers
93 Explorer XL 2dr 4x4 - totalled does anyone in that f*ckin city know how to drive
OK, that was twice in 6 months, red means STOP
Blue LS is offline
post #7 of 11 (permalink) Old 11-19-2005, 10:02 AM
lightevergreenfrost's Avatar
Send a message via AIM to lightevergreenfrost
And I thought 175,000 miles was a lot. My friends freak when they see that, I think theyd die if it were near 300,000 miles.
T-Bird Registry Number 27526
My Car Domain Site
http://www.cardomain.com/ride/2282851
My Space:
http://www.myspace.com/jordonjones
post #8 of 11 (permalink) Old 11-19-2005, 10:40 AM
I keep telling my g/f we're stuck with the Grand Prix until 250,000, but with road salt every winter I highly doubt it. How did you keep yours rust free this long?
post #9 of 11 (permalink) Old 11-20-2005, 10:23 AM Thread Starter
IronChopz's Avatar
Well...it's not totally rust free. Holes developed at the "forward side" of the rear wheel wells (rocker panel area?)....a year apart! I patched one with fiberglass a couple summers ago (didn't do a great job, either), then the other appeared the following year. I may patch the other sometime. Now, more rust is appearing at the "door end" of the LH rocker panel.
Another rust area developed in the right rear passenger floorboard. I discovered that the rubber stopper/cap underneath that area on the underside of the car had popped out, allowing water in. I reseated the cap, treated the area for rust, and used the fiberglass patch on the floorboard.
Undercarriage washes are a regular item for this car.
post #10 of 11 (permalink) Old 11-20-2005, 10:57 AM
jk69cat's Avatar
i just fixed the rear passenger floor in my 92 , the plug fell out due to the area being rusted out. welded a new panel in . and rtv'd it and i just finished painting it last night . then i discovered a small hole in the driverside front on one of the braces. expanding foam here we come! the hole is right over the subframe rail . luckliy the only other rot problem on this car is the lower left fender. its a never ending battle. and i have to clean and paint the bottoms of the doors too .
mn12 less!
jk69cat is offline
post #11 of 11 (permalink) Old 11-21-2005, 07:59 PM Thread Starter
IronChopz's Avatar
Originally Posted by jk89cat
....its a never ending battle....
Very much so. As much as I like the car, and the driving of it, it's not built to last forever. Doggone rust!
But, it costs less to do the repairs than it does to buy a new car, and cough up monthly payments again.
Hopefully soon, I'll be back in the workforce, and be able to save a few dollars to tackle some of those rust areas better.
