2000 concorde - TCCoA Forums
post #1 of 22 (permalink) Old 02-11-2006, 05:50 PM Thread Starter
shaggy433's Avatar
Send a message via AIM to shaggy433 Send a message via MSN to shaggy433 Send a message via Yahoo to shaggy433
2000 concorde
ok a friend of mine has a 2000 Chry Concorde and is having a small heating problem.
it takes a while for the heat to start coming out of the vents which is not really a big deal but...whenever he pulls up to a red light the heat stops coming out. It is still blowing out air at the normal speed but it just changes from warm to cold. when the light turns green and he takes off it turns warm again. any ideas about what could be causing that to happen????
shaggy433 is offline
post #2 of 22 (permalink) Old 02-13-2006, 02:00 PM Thread Starter
shaggy433's Avatar
anyone?????????? any ideas at all???
post #3 of 22 (permalink) Old 02-13-2006, 02:32 PM
Rolling-Thunder's Avatar
Have you or him checked some of the basic things like;
1. How fresh is the coolant?
2. Is there the correct amount of coolant in the system?
3. Is the system losing coolant?
4. Is the thermostat operating correctly?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #4 of 22 (permalink) Old 02-13-2006, 04:18 PM
If it has a 2.7l in it check the bleeder housing at the front of the motor. They love to leak around the brass insert.
cougarnut281 is offline
post #5 of 22 (permalink) Old 02-13-2006, 07:21 PM
Full Metal
RedThunder94's Avatar
if it has the 2.7 tell him to get rid of it quick, that is the worst v6 to have in the concord/intrepid cars, my nephew got a 2001 intrepid with less 29000 miles on it and the thing lunched the 2.7 pos within 2 years with less than 80,000 miles on the clock. just google dodge 2.7 and it should come up with about a thousand results about people having to replace the 2.7 with sometimes less than 50,000 miles on it and chrysler blaming it on the owners and refusing to warranty the engines. just an aside, although it really has nothing to do with the heater issue, lol...
well, maybe it does, it could be low on coolant from the design flaw the engine has allowing the water to drip into the oilpan causing the sludge buildup that kills those engines. you never know,
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #6 of 22 (permalink) Old 02-13-2006, 08:20 PM
Not even close.
I am a mechanic at a Dodge dealership. Yes the 2.7 is junk in the LH body cars. The reason they have sludging issues is due to excessive underhood temps. In the intrepids, concorde, 300M, and LHS the cat. converters are practically right next to the cylinder heads. Couple that with minimal airflow across the motor due to how tight everything is packaged underhood and you have a problem. If you look at the cowl area you will see where part of the weather stripping is missing. The engineers did this to help vent underhood temps. When they put the 2.7 in the JR bodies(stratus, Sebring) they made sure to design it so there would be sufficiant airflow across the motor.
I have replaced dozens of 2.7 motors in LH's but can count on one hand the amount of JR 2.7's I've replaced, and most of the JR ones were due to lack of oil changes. So while the 2.7 has its problems please don't think it is solely the motors fault when the chassis its in has something to do with it as well.
post #7 of 22 (permalink) Old 02-13-2006, 08:24 PM
Full Metal
well i'm just going by what is floating around on the web, i'm not spouting it as gospel, that's why i said maybe, but there is a problem with the 2.7 in the lh cars, right?
post #8 of 22 (permalink) Old 02-14-2006, 03:19 PM
Sorry if it sounded like I was calling you a lier. That was not my intent. And yes there is a problem with them in LH cars. My suggestion has been to use a full synthetic oil and change it every 3,000 miles. Its expensive but I know of two people doing it. One has over 100,000 miles and the other is a tech I work with. I think he has around 40,000 on it and hasn't had a problem yet.
post #9 of 22 (permalink) Old 05-09-2006, 09:21 AM
Unherd's Avatar
Originally Posted by cougarnut281
Not even close.
The 300M and the LHS never came with the 2.7 and their engines don't have the problems the 2.7 has. Even if excessive heat was to blame it would be because the coolant passages in the 2.7 are way too small. Otherwise the 3.5's would be having the same problems right?
I'm with Rolling Thunder, I say check your thermostat.
"No weapon that is formed against thee shall prosper" - Isaiah 54:17
Unherd is offline
post #10 of 22 (permalink) Old 05-09-2006, 04:59 PM
Lithsanatrex's Avatar
Send a message via MSN to Lithsanatrex
anyone aside from me like the 300m bodystyle? its just mean looking off topic, i know
Lithsanatrex is offline
post #11 of 22 (permalink) Old 05-09-2006, 05:15 PM
Full Metal
i love the 300m, limited? i guess, bone color exterior, tan leather interior, sunroof, 18" chrome, autostick, 255 hp 3.5. 11, or was it 13 speaker infinity audio system, with cd changer, need i say more?
post #12 of 22 (permalink) Old 05-09-2006, 05:34 PM
FordFanatic's Avatar
the real problem is that its a crapsler product. they are the biggest pos in the entire universe. tell him to drive it off a cliff, or burn it, or pay the driver of bigfoot to run it over or........you get the point.
FordFanatic is offline
post #13 of 22 (permalink) Old 05-09-2006, 05:57 PM
Who is John Galt?
Not all Chryslers are crap. We replaced less on out 3.3 Intrepid while we owned it than I have on the Cougar since I've owned it, that make my Cougar the biggest pos in the universe? They are nowhere near claiming the title of "biggest pos in the entire universe". That title is reserved for something like a Chevette. Cougarnut hit it right on the head about the 2.7.
And the 300M = one of the few FWD cars I'd consider owning.
"Won't work, can't be done"
cougar_guy04 is offline
post #14 of 22 (permalink) Old 05-09-2006, 06:27 PM
yes they are.
no because its made by ford.
although its a chevy (thus making it junk unlike ford which is the greatest automaker of all time), thats still a step above a crapsler.
post #15 of 22 (permalink) Old 05-09-2006, 06:28 PM
Who is John Galt?
Wow . . . I'm done with this thread. So much for thinking people could be open minded.
post #16 of 22 (permalink) Old 05-09-2006, 06:32 PM
Send a message via AIM to Dezal
Chrysler corp. have the some of the hottest cars and trucks on the market ( charger/ 300 and dodge ram 1500). gotta love those hemi's.
Dezal is offline
post #17 of 22 (permalink) Old 05-09-2006, 06:42 PM
about as hot as a flaming bag of dog crap.
sorry dude, didn't know you were so sensitive. see my screen name it explains alot. i hate chevys, but i really really hate crapslers.
post #18 of 22 (permalink) Old 05-10-2006, 02:43 PM
fire is still hot homeboy, im no chevy/dodge/whatever fan, but you have to give credit where it is due, the charger (srt-8 i think) is a monster of a car and the srt4 is no slouch either. my bro Bob has an srt4 that is easily in th 11~12 sec quarter range and hes only but around 7~8k in it. and as far as looks go, all of fords new crap looks just like that, crap. i have bled ford blue since day one, every male on my fathers side for the past 3 genereations have been working on/with ford and i will always have a soft spot for em, but im not gonna hate on a company because they make a car that i find appealing. isnt that the goal of automakers? to make something appealing, affordable to the target market for that specific car, and make it last (despite a lot of automakers abilities to do so).
well im done venting a little bit, sorry bout the flaiming
post #19 of 22 (permalink) Old 05-11-2006, 07:45 AM
ptschett's Avatar
Gee, did someone in a Charger out run you in a street race or something?!?
Or is it a problem that the Dodge brothers quit working for Henry to go build a real car?
1996 Ford Thunderbird 4.6L/auto, 195k miles, semi-retired
2005 Dodge Dakota Club Cab 4x4 4.7L/auto
2015 Dodge Challenger R/T 5.7 Hemi/auto
Gone but not forgotten: 1973 Mercury Cougar XR-7 351C-2V/FMX - 2010 Dodge Challenger R/T 5.7L/manual
ptschett is offline
post #20 of 22 (permalink) Old 05-11-2006, 06:40 PM
Hobohuey's Avatar
The srt line is sweet. (especially the cherokee) besides that, the only dodge I would own would be a six speed diesel. Ive pretty much lost hope on ford doing anything to grab my attention unless they bring the FPV line over. The only thing I like from Chevy is the diesels, the new Tahoe, and the Cobolt SS.
Why cant they make cars like they did 10 years ago?
'95 T-Bird - Light green, 98 Crown Vic Police Interceptor Engine, 96 Grand Marquis Tranny, 3.27 Trac-loc, Ford MotorSports Trans cooler, Sport Springs, Blaupunkt Richmond, Memphis Car Audio 5x7's, Cerwin-Vega 150.2 powering mids/highs, Volgenhag 4-channel 1200w amp (junk), 2 Memphis Car Audio 12's
'88 T-bird turbo - Silver, 5spd, Rebuilt Engine, t-3 .63, Custom FMIC, Bobs Big Log, Bob's 3" Elbow, Walbro 255lph, Maximum Motorsports Coil-over Kit, Bilstein HD struts, Hypercoil 200# 14" Springs, Caster/Camber Plates, Ranger Roller, Gillis Valve at 20#, 3in. Side-Dump Exhaust, NGK Iridium XI Plugs, Jacobs C-4 Coil, High Volume Oil Pump, MAX PSI Oil Lines, Poly Bushings, 245/50/R16 Nitto 450's, Autocross car
Hobohuey is offline
post #21 of 22 (permalink) Old 05-11-2006, 07:10 PM
that wouldnt happen because i dont street race. street racing is for retards, go to the track.
and that would be what?
post #22 of 22 (permalink) Old 05-11-2006, 07:21 PM
ptschett's Avatar
I agree. Just trying to figure out why you think everything Mopar is junk. My Dakota's had less problems in its first 20,000 miles than my T-bird by the time it had reached that mileage.
Dodge was a subassembly supplier to Ford until the mid 1910's, then they decided to build a more advanced car themselves, rather than keep making Model T parts.
ptschett is offline
