87 ranger 2.9 running rough - TCCoA Forums
post #1 of 3 (permalink) Old 03-01-2006, 04:39 PM Thread Starter
I dont have a CEL but I ran the scan tool "KOEO Memory code" and got code 31 "EGR Valve position or exhaust pressure transducer sensor voltage low" What is this?..a new o2 sensor needed? I have pacesetter headers and I had to plug up the EGR if I remember correctly. Any ideas???
94ONAIR is offline
post #2 of 3 (permalink) Old 03-02-2006, 12:36 PM
ZackG's Avatar
your ranger has an egr position sensor. its about $30 if i recall correctly. with you plugging the egr up, its probably throwing a code
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #3 of 3 (permalink) Old 03-02-2006, 05:27 PM Thread Starter
Well today I changed the fuel filter, plug wires and still get a rough idle at Park and it wants to stall when in reverse at low speeds...when I put in in drive and just drive it....it seems fine. So I am out of ideas of what it could be..? I checked all vacum lines...
94ONAIR is offline
