antenna removal tool? - TCCoA Forums
post #1 of 12 (permalink) Old 03-06-2006, 11:18 AM Thread Starter
pnyklr's Avatar
Send a message via AIM to pnyklr Send a message via Yahoo to pnyklr
Now that I totally wrecked my antenna screw (tried using a hammer and screwdriver to tap it loose)
Is there a tool available to take it off ? I tried pliers with no luck
I think I will have to buy a whole antenna set up
Chris
87 GN,94 Prizm,05 Suburban Z71
pnyklr is offline
post #2 of 12 (permalink) Old 03-06-2006, 01:22 PM
MattsLE97's Avatar
Send a message via AIM to MattsLE97 Send a message via Yahoo to MattsLE97
Theres a socket kit i believe you can get try doing a seach on google or yahoo i think it will come up
2000 dodge dakota 4.7L 4x4
Flowmaster 3" SI/DO 2.5
31" cooper stt tires (mud and off roading here I come)
MattsLE97 is offline
post #3 of 12 (permalink) Old 03-06-2006, 03:52 PM Thread Starter
pnyklr's Avatar
ok I wil check on that later
Chris
pnyklr is offline
post #4 of 12 (permalink) Old 03-06-2006, 04:11 PM
Will when i was taking the fender off the car i noticed that it was just a bolt screw. Could you just un-screw it from the bottom?
post #5 of 12 (permalink) Old 03-06-2006, 04:15 PM
MattsLE97's Avatar
ya that holds the mount on the inside, it wont take the whole unit out, you have to take the top nut off to take the whole unit out
-matt-
post #6 of 12 (permalink) Old 03-06-2006, 07:01 PM
yeah i remember holding the bottom nut while un screwing the the top off and then again the other way around too.
post #7 of 12 (permalink) Old 03-06-2006, 07:06 PM Thread Starter
pnyklr's Avatar
i got the bottom one off top didnt budge i tried tapping with a hammer didnt work either
Chris
pnyklr is offline
post #8 of 12 (permalink) Old 03-07-2006, 09:00 AM Thread Starter
pnyklr's Avatar
ok ladies and gentlemen I got the stupid bolt off ... I went down to the hardware store and bought two new sets of needle nose pliers and got it off with some fighting
Chris
pnyklr is offline
post #9 of 12 (permalink) Old 03-07-2006, 10:56 AM Thread Starter
pnyklr's Avatar
oh ya i also broke the cornering light taking the fender off .... cost me $28 for the complete assembly
Chris
pnyklr is offline
post #10 of 12 (permalink) Old 03-10-2006, 05:57 PM
Ok, ok...i see what your talken about, I went to the junk yard to get an antenna. I see that bolt on top. So you used a needle nose pliers? How did that work?
post #11 of 12 (permalink) Old 03-10-2006, 06:00 PM Thread Starter
pnyklr's Avatar
I used the needle nose pliers to loosen the bolt and it was off in a second
Chris
pnyklr is offline
post #12 of 12 (permalink) Old 03-10-2006, 06:07 PM
ok i guess ill give it a try thanks
