new best et this weekend... - TCCoA Forums
post #1 of 22 (permalink) Old 07-19-2009, 10:22 PM Thread Starter
VicRattlehead's Avatar
bold is new best, here are the slips:
dial ----------------------------------------------------- 12.40
r/t --------- .951 ------ .837 -------- 2.339 -------- .926
60' ------- 1.853 ----- 1.921 ------- 1.639 -------- 1.662
330 ------ 5.741 ----- 5.755 ------- 5.045 -------- 5.048
1/8 ------- 9.168 ----- 8.932 ------- 7.855 ------- 7.860
mph ------ 70.65 ----- 76.00 ------- 87.15 ------- 87.18
1000 ---- 12.097 ---- 11.715 ----- 10.304 ------ 10.302
1/4 ------ 14.525 ---- 14.072 ----- 12.503 ------ 12.410
mph ------ 92.10 ----- 91.81 ------- 92.59 ------ 103.95
CMP Drag Racing
VicRattlehead is offline
post #2 of 22 (permalink) Old 07-19-2009, 10:24 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
Nice numbers; that's awesome!
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #3 of 22 (permalink) Old 07-19-2009, 10:49 PM
Buckcreekbilly's Avatar
Nice goin Vic.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 22 (permalink) Old 07-20-2009, 12:01 AM Thread Starter
there is still more in the car, driver error has alot to do with crappy r/t's if i could ever get the window switch to work with the n2o i could actually launch on the juice. probably drop the 60' to a 1.58-1.60 if i shifted the thing higher then 5400 or so that would probably drop the et a little too. im hoping that after some seat time ill be in the 11's.
CMP Drag Racing
post #5 of 22 (permalink) Old 07-20-2009, 12:10 AM
Burbank 98 lsc's Avatar
Nice numbers!
Did you run your best time at NMRA /NMCA in Joliet.
Black 98 Lincoln Mark VIII LSC [email protected] 128.16 mph
1998 Mark VIII collectors edition(SOLD)
2007 Mitsubishi Outlander V6(gas saver)
2006 Mercedes R500 4 Matic(family cruiser)
Burbank 98 lsc is offline
post #6 of 22 (permalink) Old 07-20-2009, 05:23 AM
Wow! a 2.339 r/t Congratulations!
post #7 of 22 (permalink) Old 07-20-2009, 02:40 PM
Moderator & Teksid Whore
guitar maestro's Avatar
you'll need to be in the 11s by the time i get my 14:1 compression beast launching my car at a stall +100 RPM higher than your current shift point
good #s
guitar maestro is offline
post #8 of 22 (permalink) Old 07-20-2009, 04:41 PM Thread Starter
Ohhh no worries I'll be shifting higher and laying down some better numbers in Milan @ NMCA in a month or so.
CMP Drag Racing
post #9 of 22 (permalink) Old 07-20-2009, 07:57 PM
driller's Avatar
Congrats!
driller is offline
post #10 of 22 (permalink) Old 07-20-2009, 10:28 PM
VicRattlehead......Awesome numbers man. What's the date that your planning on going to Milan ?? I wanna be there to see that thing run !!
Jon
1996 T-bird, 4.6 with ported PI heads and VT stage 2 cams, JBA shorty headers, 3000 stall converter, 3.73 gears and just about every bolt on available.
Dyno tune results: 275.9rwhp and 301.4 torque.
Best 1/4 mile time: 13.65 at 99.52 mph.
Now I need more gear, more stall and some drag radials !!
QkTbird is offline
post #11 of 22 (permalink) Old 07-21-2009, 07:17 AM
R8D-XXX's Avatar
Good run man!! How big of shot are you running?
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #12 of 22 (permalink) Old 07-28-2009, 11:33 PM Thread Starter
pics from the weekend
CMP Drag Racing
post #13 of 22 (permalink) Old 07-29-2009, 07:36 AM
nice....what does the car weigh?
post #14 of 22 (permalink) Old 08-18-2009, 02:12 AM
jesusraybrown's Avatar
Are those 5x4.5 prostars? I've been thinking about a big-n-little setup.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #15 of 22 (permalink) Old 08-18-2009, 03:55 AM Thread Starter
yes they are mustang pattern 5x4.5 prostars
and i have no idea how much it weighs i didnt stop on the scales like i wanted to
CMP Drag Racing
post #16 of 22 (permalink) Old 08-18-2009, 04:25 PM
96tbirdboi's Avatar
Do you have full interior or minor weight removal
I dont feel bad about my rt time now,working on that would get your time down a good bit
I like your wheels They look clean!!!
nice times keep up the good work!
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #17 of 22 (permalink) Old 08-18-2009, 07:05 PM
Nice times, who was running with you? (Other tbird owner)
post #18 of 22 (permalink) Old 08-18-2009, 07:13 PM Thread Starter
reaction time and ET are two different things rt is the time from when the green light comes on and when you cross the start line. Et is the time distance from the start line to the finish line. It starts right when the reaction time stops.
Car has full interior in it right now power sc seats both sides in front
R
CMP Drag Racing
post #19 of 22 (permalink) Old 08-18-2009, 07:15 PM Thread Starter
That red car is Darrin's from here driven by Jeff Stafford
CMP Drag Racing
post #20 of 22 (permalink) Old 08-18-2009, 09:07 PM
96tbirdboi's Avatar
R
I learned a new fact tonight,thanks for educating the uneducated
Comp 262 cams
Sport springs
Steeda UDPs
post #21 of 22 (permalink) Old 08-18-2009, 10:24 PM
Mgino96tbird46's Avatar
Very good times considering you are still running with a full interior. I just hope you kicked that Mustang's a**.
Mgino96tbird46 is offline
post #22 of 22 (permalink) Old 09-14-2009, 04:11 PM Thread Starter
Took the car back to the track on sat. Temps were about 20 degrees warmer then the last time out. I'm not going to say what it ran but let's say I'm happy where it's at. Find me at the shootout and I'll tell ya
Someone asked what it weighs it's right at 3805-3810.
CMP Drag Racing
