My first time to go to the drag strip - TCCoA Forums
post #1 of 24 (permalink) Old 08-14-2009, 10:16 PM Thread Starter
96tbirdboi's Avatar
went to my first run ever at a drag strip at hrp
best RT .112
best 60' 2.295
best 1/4 mile 14.611
best speed 98.29
this was done on crappy tires and with the bad need of an alignment and this being my first time to ever drag race
The tech articles on tccoa which discussed racing tips helped me out alot
im installing a aluminum drive shaft a tranny cooler fixing my front end suspension and getting better tires for my non-sport wheels,hope to get into the low 14s
next time ill try and post videos
sry about the lifestory
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #2 of 24 (permalink) Old 08-14-2009, 10:33 PM
paintme205's Avatar
Thats a pretty good time. your 60 foot is killing you but thats most likely a stock converter and bad tires combination. Glad you had fun.
paintme205 is offline
post #3 of 24 (permalink) Old 08-15-2009, 12:58 AM Thread Starter
96tbirdboi's Avatar
the stall is stock(along with the rest of the drive train) and i have Douglas tires
I did the 1-2, 2-3 shifting and it spun out when i did that but it got me my best 60' but i got a .413 rt that run
I tried turning OD off to see if that helped but didn't IMO
Comp 262 cams
Sport springs
Steeda UDPs
post #4 of 24 (permalink) Old 08-15-2009, 01:07 AM
VicRattlehead's Avatar
for drag racing, the stock stall is junk, but you already know that. the tires well that has to change too, but you know that too.
do you have a tune for the car? if not you should look into that too. if you do have it tuned, you should probably just leave it in "D" and 'stab and steer' as some say. just watch the tree and go and let the computer do the shifting for you.
OD on vs off makes no difference, all it does is either allow the trans to shift into 4th gear or not shift.
CMP Drag Racing
VicRattlehead is offline
post #5 of 24 (permalink) Old 08-15-2009, 01:26 AM Thread Starter
96tbirdboi's Avatar
I knew about the tires and the stall
I have a tune on the car at the moment almost a must with the pi swap
To me leaving in in "D" was the best i have to agree with you on that
I want to try and find some wheels i can put some MT streets on with my lug pattern
or will i have to convert to a mustang lug pattern
Comp 262 cams
Sport springs
Steeda UDPs
post #6 of 24 (permalink) Old 08-15-2009, 06:27 AM
Just imagine what you can do with some GEARS! Go at least 3.73
post #7 of 24 (permalink) Old 08-15-2009, 11:35 AM
You can put a 26x8 on a stock rim
CMP Drag Racing
post #8 of 24 (permalink) Old 08-15-2009, 12:06 PM Thread Starter
96tbirdboi's Avatar
im going to go 3 73 with a 3800 stall
i was wondering if i got a sway bar like the one you have for the rear if i get better traction
Ive been wanting to do the same suspenion set up as you trunkmonkey (cept keeping the sport springs)
I ran alot of times i wanted that 14.5 before i left i started to get that drag racing additction
i think i may need to chunk these stock brakes soon
I want some street radials Vic for the back??
and for the front what would i get??
Wouldnt the tread in the middle of the tire wear down easy for such a wide tire?
I think im going to do a search
Comp 262 cams
Sport springs
Steeda UDPs
post #9 of 24 (permalink) Old 08-15-2009, 04:36 PM
I'm going to go 3 73 with a 3800 stall
i was wondering if i got a sway bar like the one you have for the rear if I'd get better traction
I've been wanting to do the same suspension set up as you trunkmonkey (cept keeping the sport springs)
Nah, the bigger sway bar is more for canyon carving than traction inducement at the dragstrip. RobertP is still running his stock swaybar on his car and turning in high 11's and low 12's with his car.
Thanks for the compliment on my suspension set-up.
I ran a lot of times i wanted that 14.5 before i left i started to get that drag racing addiction
i think i may need to chunk these stock brakes soon...
I think I'm going to do a search
Good call.
post #10 of 24 (permalink) Old 08-15-2009, 04:42 PM Thread Starter
96tbirdboi's Avatar
im looking at a new camcorder so maybe ill have videos to post next time
My intake tube i bought from here was a Robertp copy tube im satisfied with it
Comp 262 cams
Sport springs
Steeda UDPs
post #11 of 24 (permalink) Old 08-15-2009, 05:37 PM
Faster than Porkchop
cjchevez's Avatar
Nice times dude , with 4.10's I got a 14.47 with my first and only run at the qtr mile. I think I could have gotten a 14.2 or.3 with my best times . How are those cams working for you ,looks like you have a few more hp than me with stock pi cams ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #12 of 24 (permalink) Old 08-15-2009, 06:11 PM
ZackG's Avatar
I believe you have a 13 second car there with gears and a converter. Possibly only a converter and some good tires.
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #13 of 24 (permalink) Old 08-15-2009, 08:15 PM
i
street radials come in a 255 i think. for the front, ive got a 165r15 on a weld pro star wheel. if your running stock style wheels, get a 205 50 15 or whatever the narrowest tire you can put on the stock wheels.
about the tread in the middle of the tire, if you keep the air pressure at the correct pressure you wont have an issue.
CMP Drag Racing
post #14 of 24 (permalink) Old 08-15-2009, 10:08 PM Thread Starter
96tbirdboi's Avatar
I never got my dyno numbers on my car
the cam works great i thinks its just right with my pi heads and being n/a
i would recommend it
Comp 262 cams
Sport springs
Steeda UDPs
post #15 of 24 (permalink) Old 08-15-2009, 10:27 PM Thread Starter
96tbirdboi's Avatar
I want to see how low i can get my 1/4 with drivetrain,suspension upgrade,tires,maf,headers and another tune
then decide if im going to stay N/A
Comp 262 cams
Sport springs
Steeda UDPs
post #16 of 24 (permalink) Old 08-17-2009, 07:44 AM
Silenced's Avatar
LOL! That is awesome.
I'm with Zach about it being a 13 second car with just a little work.
I was seeing 1.9 60ft's with 255x45x18 Toyo Proxy ST's.... The ST standing for Sport Truck Say you get tires and a good drivetrain stup, and can match my 60ft, that's a 14.2 with the time difference alone. Obviously, you'd be moving quite a bit faster at the 60ft mark too, cutting the time even further
Powered by:
Megasquirt EMS, Vortech Superchargers, Renegade Racing, Gator1980Transmission, Innovative Motorsports, Devil's Own, Magnaflow, Eibach, KYB, Kooks
Silenced is offline
post #17 of 24 (permalink) Old 08-17-2009, 06:25 PM Thread Starter
96tbirdboi's Avatar
I gotta replace the tie rod bushings and tie rods cause thats causing my tires to get eat up real fast
for now cheap tires til that is fixed then im gona get an extra set of wheels to put some street ETs on them
after i get my aluminum driveshaft in and installed im going to get things straight on my car
ill probably do a run after i install the driveshaft and replace the fuel filter just to see the difference and post the times up
Comp 262 cams
Sport springs
Steeda UDPs
post #18 of 24 (permalink) Old 08-17-2009, 06:30 PM
ZackG's Avatar
just wait till the cooler air starts coming. Oh wait... you live in texas. hahaha. forget that.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #19 of 24 (permalink) Old 08-17-2009, 06:42 PM Thread Starter
96tbirdboi's Avatar
It was pretty hot when i went
i was gona race once it got darker and alot cooler but a cadillac busted its rearend open and made the line very long
Comp 262 cams
Sport springs
Steeda UDPs
post #20 of 24 (permalink) Old 09-11-2009, 10:42 AM
On my car at HRP there is a .4-.5 second ET swing between the dog days of summer {just past} and the cooler months that are approaching.
In Feb or march our ETs would be roughly .4 quicker than they were in July and August.
1995 Lincoln Mark VIII "Grandmas Car"
400,480 miles *STOLEN 04-13-08*
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
post #21 of 24 (permalink) Old 09-11-2009, 01:22 PM
MikeyB's Avatar
I still have yet to run at the strip. I really need to since we just got the new pi swapped motor in. One thing I know I need desperately is geeaarrsss.....(4.10's)!
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #22 of 24 (permalink) Old 09-11-2009, 03:52 PM
95xbird's Avatar
Why not go both. Drivetrain mods and Boost it. I did and I am happy with the results.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #23 of 24 (permalink) Old 09-11-2009, 05:14 PM
don't do any less!
post #24 of 24 (permalink) Old 09-12-2009, 10:39 AM
R8D-XXX's Avatar
4.10's FTW!
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
