which is better for drag racing lx rear springs or sport springs - TCCoA Forums
post #1 of 32 (permalink) Old 04-13-2010, 10:45 PM Thread Starter
On Probation
blown96bird's Avatar
I have a tork tech blower on my bird. The blower intercooler and all the plumbing add around 100-125 pounds to the nose of the car. I had to add the stiffer sport springs up front to help to compensate for the extra weight. I have had the sport springs on the rear for a while and I don't think it hooks up as well as it did with the lx springs. I am going to swap the rear springs for lx units and give the results. I would like to know your opinion on this swap?
blown96bird is offline
post #2 of 32 (permalink) Old 04-14-2010, 12:03 AM
Traveler's Avatar
Can't help you on your question. (sorry) but can you post any pics or did you do a thread on the install of the tork tech?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 32 (permalink) Old 04-14-2010, 04:08 AM Thread Starter
On Probation
yes it is under the roots supercharging section.
post #4 of 32 (permalink) Old 04-14-2010, 07:29 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
I've got the stock sport springs on my car.
JL
Fuelly
Johnny Langton is offline
post #5 of 32 (permalink) Old 04-14-2010, 08:02 AM
I run the LX springs in the rear.....with 2 coils cut off each.
post #6 of 32 (permalink) Old 04-14-2010, 10:24 AM
Sport Springs vs. LX springs
The LX springs are not as stiff as the Sport springs and natural physics will play into effect big time between the two springs. The Stiffer the springs are in the rear, the less traction you will be able to get because a stiff spring will not allow for much maximum weight transfer to the rear. The optimal springs would be really old worn out springs from an earlier thunderbird/cougar for drag racing. You want the nose of the car to fly up in the air and the rear to sit down and old, worn out springs will definitely help out traction.
speedbird8807 is offline
post #7 of 32 (permalink) Old 04-14-2010, 10:39 AM
or get some adjustable 90/10 coil overs for the front...
post #8 of 32 (permalink) Old 04-14-2010, 06:50 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
I have had the best results with the Sport springs myself. I will be swapping back to them...
TGJ is offline
post #9 of 32 (permalink) Old 04-14-2010, 10:41 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
well with the softer springs in back it will let more weight transfer to the rear which will probably help you get better traction
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #10 of 32 (permalink) Old 04-15-2010, 05:53 AM
The problem I had-even with the sport springs,was that my car launches hard enough to bottom out the rear suspension,which will cause a bounce that will unload the rear tires,and cause spin. This was only cured when I increased the spring rate by adding airbags to the springs. This would be FAR worse with the softer LX springs.
JL
Fuelly
post #11 of 32 (permalink) Old 04-15-2010, 03:04 PM
Nitemare's Avatar
I would think that stiffer springs would hold the tires to the ground better than softer springs, especially when the "weight transfer" is pushing down on the springs.
Needs more stall.
Nitemare is offline
post #12 of 32 (permalink) Old 04-15-2010, 10:30 PM
paintme205's Avatar
I'm with JL on this one. I am cutting 1.73 60 foots on lowing springs with 260 horsepower and not alot of gear... sports would be better but not in the budget currently. Wheel hop will kill you with soft springs. Especially if you have some power.
One thing i have noticed is that most of the better 60 footing t birds have got airbags in their springs or a minimum of their right spring.
paintme205 is offline
post #13 of 32 (permalink) Old 04-18-2010, 12:09 AM
Clueless Poster
JL
damn .
i get really bad wheel hop in my mustang on stock motor and suspension on street tires. wouldn't lca's cure the wheel hop issue for the most part. most people have been telling me to get them for that very reason as it helped them considerably.
post #14 of 32 (permalink) Old 04-18-2010, 02:29 AM
sCrEaMiN BiRd's Avatar
damn .
LCA's are a good place to start, you may want to look into relocation brackets as well. There are soo many suspension parts for an S197 mustang it can make your head spin but UMI is a good place to start. I don't own a set but the UMI roto joints are supposed to be excellent for helping eliminate wheel hop and also improving your cornering grip as well. You should at least consider these.
sCrEaMiN BiRd is offline
post #15 of 32 (permalink) Old 04-18-2010, 02:56 AM
VicRattlehead's Avatar
ive got H&R sport springs in the back with airbags on both sides at around 20 psi i think. no wheel hop and 1.6 short times.
CMP Drag Racing
VicRattlehead is offline
post #16 of 32 (permalink) Old 04-19-2010, 12:55 PM
Clueless Poster
yeah i juts dont have any money as i put a pxton novi2200 on lay away once thats paid off i plan on doing the suspension with either a griggs set up or mm
post #17 of 32 (permalink) Old 04-19-2010, 04:14 PM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
wtf are h&r "sport" springs?
-John
MAMN-12 Fringe Member
94MN1246 is offline
post #18 of 32 (permalink) Old 04-19-2010, 04:38 PM
-John
It was described to me like that some years ago. All I know is they are h&r stamped on em.
CMP Drag Racing
post #19 of 32 (permalink) Old 04-19-2010, 06:10 PM
DSM
don't forget, these cars are IRS, therefore the softer the spring the more camber is going to be produced therefore minimizing the amount of contact patch the tires are going to get.
Stiffer = better.
put the battery in the rear and delete the front crash bar if you're trying to get a good amount of weigh transfer to the rear.
DSM is offline
post #20 of 32 (permalink) Old 04-22-2010, 10:15 PM
Clueless Poster
Stiffer = better.
maybe its the irs but most of the mustang guys seem to love hard in the front and soft out back?
post #21 of 32 (permalink) Old 04-23-2010, 09:21 AM
tbirdtess's Avatar
Different
Hello
That may be true, BUT T-birds have a very different suspension set-up!
I run circle track, 550-600 front(way heavier that stock)
300-380 in the rear. Softer than stock!
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #22 of 32 (permalink) Old 04-23-2010, 09:25 AM
Originally Posted by tbirdtess View Post
Hello
Ahhh yes,but in circle track-you're after a much different vehicle attitude when racing. The purpose in drag racing is to plant the rear on launch,then get the front as low as possible when at speed to reduce wind drag.
JL
Fuelly
post #23 of 32 (permalink) Old 04-23-2010, 09:39 AM
DSM
of course it's the IRS that makes the difference, mustang guys don't have to worry about their contact patch of their tires when they swap out springs, why? A solid axle doesn't cause the tires to camber out when force is applied. They can run a softer spring to plant the rear-end because the contact patch never changes on a solid axle setup.
IRS, softer springs = more squat = less contact patch = no traction.
DSM is offline
post #24 of 32 (permalink) Old 04-23-2010, 09:55 AM
T6Rocket's Avatar
That's backwards from what should work best. Soft in the front transfers weight to the rear, stiff in the back pushes that weight down.
The weight is going to transfer no matter what. You have to decide how hard you want it to push the tires down onto the track.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #25 of 32 (permalink) Old 04-23-2010, 10:20 AM
tbirdtess's Avatar
Al
OK Lets go back to stock.
Factory rear springs are almost double the front. No matter what suspension package you have. LX, SC or Sport.
Don't go with what a different chassis runs!!
Some of the camber squat can be tuned out. Adjusting to the high side of the toe adjust or raising the mount of the lower control arm.
I started running my car with similar springs as the other cars. HUGH PUSH!
that was 1100, Now I am at 600lb ish. front.
rears were about 275-300 now 350-380's
most Metric's are running 1000 front 175 rears. So way different!
Listen to these Guy's that run a similar type of racing.
try to start close, Then fine turn to your track & driving style.
every track may be different.
351W 2bbl.
C-4 Auto
3.90 open rear
post #26 of 32 (permalink) Old 04-24-2010, 12:52 PM
Banned
Send a message via AIM to 1989superchicken Send a message via MSN to 1989superchicken
i have eibachs all around and pull 2.0 60ft's
on 245/45/17 reiken raptors. shock's are new autorides up front and tokico blue's used of my 96 bird that i had. all the tranny and irs bushing's and motormounts have been changed and front end rebuilt with a rear shocktower brace in the trunk.
1989superchicken is offline
post #27 of 32 (permalink) Old 04-26-2010, 01:25 AM
Clueless Poster
Al
maybe i have it backwards? still a rookie to drag racing
post #28 of 32 (permalink) Old 04-26-2010, 01:40 AM
JL
jl, what are your usual 60' times?
CMP Drag Racing
post #29 of 32 (permalink) Old 04-26-2010, 09:10 PM
1.68-1.74
JL
Fuelly
post #30 of 32 (permalink) Old 04-27-2010, 12:36 AM
1.68-1.74
JL
thats what i was guessing.
steven
i have not had any issues with running these h&r springs with the airbags in both sides running 20lbs of air i think, and about 14psi in the slicks. with the setup i was getting 1.64-1.68 60' times with no wheel hop, and not spinning the tires.
CMP Drag Racing
