reducing rollout ideas - TCCoA Forums
post #1 of 16 (permalink) Old 06-23-2010, 03:15 PM Thread Starter
paintme205's Avatar
My wife and I have taken a liking to index racing and it seems to be working well for us so far. We have two first place finishes, one second place, and one fourth place over the last two times we have done it. There is a problem though that I need to address if I want to keep doing this.
No matter what I do, I can't get better reaction times than .670-.690 with .5 being perfect. It is a pro tree so I can't launch any earlier. I don't think it's a driver error unless i'm just slow. Either way, I'm trying to reduce the vehicle rollout or do something that will allow the reaction time to get better. I am already practicing so don't say that lol.
The only thing I know to do is go with shorter tires 25 inch or 24 inch instead of 26 or working on improving my 60 foot by doing 4:30 gears instead of 3.73's.
I can't seem to find 25 inch tall tires though. My mods are below. I'm welcome to any suggestions. Getting my time in the .580 range would make me happy. My index is 8.50 (1/8th) so no one is cutting perfect lights. The cars just aren't fast enough.
Mods are in my signature. I'm running 165/85/15 tires now. If anyone knows where to get decent priced 25 inch tall tires that aren't drastically wider, I would appreciate the help.
Luke
paintme205 is offline
post #2 of 16 (permalink) Old 06-23-2010, 03:24 PM
MAMN12 Posse Member
JeffTBird93's Avatar
I don't see how tires are gonna affect your reaction time...? Your reaction time is when the car breaks the starting beam. When are you leaving the line? General rule is on the 3rd yellow, nail it. You might also try deep staging.
~Jeff
*signed off
JeffTBird93 is offline
post #3 of 16 (permalink) Old 06-23-2010, 05:00 PM
Did I read that right? 165/85/15? I see slicks in your sig, but I'm guessing you're not running those for the track events.. that or you meant 165 is your front tire size. If 165 is correct... massive wheelspin?
a black car.
Sophosis is offline
post #4 of 16 (permalink) Old 06-23-2010, 05:50 PM
Like Titles Matter
kdanner's Avatar
It's no problem getting shorter than 26" tires, but I can't think of any that are DOT if that matters.
Do the rules not allow deep staging?
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #5 of 16 (permalink) Old 06-23-2010, 06:09 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
I agree with KD. You either need to stage deeper in the stage light to the point that you are nearly turning off the pre-stage light or go off the tree a bit earlier. Depending on traction and how the car reacts, I've seen cars start off the 2nd full yellow down the tree. Shouldn't have to do that but try it like you are staging now and see what happens.
The main thing is to experiment with those things, see what the RT's look like and work on getting the consistancy at that point.
A couple inches make all the difference in the world sometimes.
I'm sure Kris will agree too, practice, practice, practice.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #6 of 16 (permalink) Old 06-23-2010, 06:30 PM Thread Starter
paintme205's Avatar
165 are the front tires lol. I couldn't imagine them on the rear. I can spin slicks now.
post #7 of 16 (permalink) Old 06-23-2010, 06:33 PM Thread Starter
paintme205's Avatar
I can't deep stage to the point it turns off the first light. I do slide forward another 2-4 inches past the stage beam but I'm still getting in the high 6's for reaction times. I can't really push it any further without going to far.
A pro tree is not friendly to slow cars.
I am looking at 24 and 25 inch front runners from goodyear or mickey thompson currently. I was hoping for a DOT tire but it doesn't look like it is going to happen. Should I get a 25 or 24 inch?
post #8 of 16 (permalink) Old 06-23-2010, 06:38 PM Thread Starter
paintme205's Avatar
I do need more practice. That is a given. The pro tree kills any ideas of leaving on the second light though. It's all three on at one time.
post #9 of 16 (permalink) Old 06-23-2010, 08:27 PM
driller's Avatar
Yeah, I have a hard time adjusting to a pro tree as well.
But even with a pro tree, once I find the 'sweet spot' and consistent reaction times, I do not try to do anything to change the launch except to stage deeper into the lights to reduce rollout and hence lower the RT slightly. That will result in slightly higher ETs but you can adjust the dial for that easy enough. The tough part is rolling into the light the same each time, but like everything else, with practice it does get better.
Reaction time is not only a measure of your reaction but also a measure of the car's reaction. But I think rollout is only part of the equation. Suspension setup also plays a huge role. One of the reasons the IRS is dissed so bad at the track.
driller is offline
post #10 of 16 (permalink) Old 06-23-2010, 10:53 PM
Like Titles Matter
kdanner's Avatar
Another thing to do would be limit front end travel. Not overly though, or you'll have traction loss.
Index racing off a pro tree is really fun.
kdanner is offline
post #11 of 16 (permalink) Old 06-24-2010, 09:28 AM
1MTNCAT's Avatar
I guess I missed it.
I didn't realize you were leaving on a pro tree. So, cancel my statement about that LOL! Since its a .500 pro tree watch the Top light of the 3 yellows.
Sometimes a minor change in tire pressure's in the front will help too. If I remember correctly to improve RT increase the front pressure a couple lbs, to decrease (If you are going red) lower the front pressure a couple lbs. Again, to see if it works you must stage consistantly each time.
We've pretty much covered it all on here but the bottom line is that it is the combination of the things discussed here and driving ability (Seat time) that will benefit you the most. Seat time will get you the consistancy you need.
Pro tree (.400-.500) Index heads-up is fun but it takes a lot of work with these cars.
Good luck with it and let us know how it works out.
Steve
1MTNCAT is offline
post #12 of 16 (permalink) Old 06-24-2010, 12:13 PM
r429460's Avatar
kdanner is right, limit the front end travel.
r429460 is offline
post #13 of 16 (permalink) Old 06-24-2010, 10:05 PM Thread Starter
paintme205's Avatar
Any ideas or links on how to limit the front end travel? I am a newb to that aspect.
Thanks for all the help.
Luke
post #14 of 16 (permalink) Old 06-24-2010, 10:19 PM
driller's Avatar
Luke
A lot of info here... http://www.racetec.cc/shope/
driller is offline
post #15 of 16 (permalink) Old 06-24-2010, 11:26 PM Thread Starter
paintme205's Avatar
Thanks driller.
post #16 of 16 (permalink) Old 06-30-2010, 06:45 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
i've only had 1 perfect .5 r/t with my stang had many close to perfects but only 1 perfect light.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
