10.176 @ 140.141 - TCCoA Forums
post #1 of 14 (permalink) Old 11-08-2010, 06:19 PM Thread Starter
David Neibert's Avatar
10.176 @ 140.141
Made a small improvement to my best ET & mph on the turbo car this weekend, and broke the transmission trying to get that 9 second pass.
My 60 ft times sucked on every pass and not because of traction, converter is just too darm tight. For my last pass of the night I turned up the 2 step rpms to get more boost off the line and held it on the brake a little longer than normal. When it came off the brake it felt like the tires were spinning hard, but it was actually slipping. 1st and 2nd are slipping and 3rd and reverse are completly gone.
Made a detour and dropped the car and trailer off at Alan's (Dirtydog) shop on the way home. In addition to fixing whatever is broken he's going to build me a new converter with about 3500-4000 stall and upgrade a few other parts for added strength. If it was going to break, glad it broke when the season was over and I was only 120 miles from Alan's shop.
David
PS: Timeslip data
RT .354
60ft 1.680
330 4.418
1/8 6.654
MPH 110.658
1/4 10.176
MPH 140.141
Peak boost was 19.5 psi
See this link for more info and pics of the car.
http://www.sccoa.com/forums/garage_v..._vehicle&id=39
David Neibert is offline
post #2 of 14 (permalink) Old 11-08-2010, 06:23 PM
Wow!! Congratulations again are in order.
Glad you could get her back to Alan to fix up.
post #3 of 14 (permalink) Old 11-08-2010, 06:23 PM
Nice times !
post #4 of 14 (permalink) Old 11-08-2010, 07:05 PM
With the new slicks and Alan's converter, you'll get your 9's next year. Congrats on the new best, David.
post #5 of 14 (permalink) Old 11-08-2010, 07:31 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Congrats
That may have been part of your 60 ft issue all along.
Glad it is trying to hook better with the new tires too!
At this stage of the game, its time to get it done for next year. You have all winter to do that.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #6 of 14 (permalink) Old 11-08-2010, 07:34 PM
CometGSR's Avatar
Awesome! Great job!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #7 of 14 (permalink) Old 11-08-2010, 07:39 PM
R8D-XXX's Avatar
Congrats on your new time!
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #8 of 14 (permalink) Old 11-08-2010, 09:45 PM
Awesome just awesome way to blow the doors off in a 4k lb street car.
post #9 of 14 (permalink) Old 11-08-2010, 10:30 PM
That's crazy fast! Congats on the new time!
post #10 of 14 (permalink) Old 11-09-2010, 08:07 AM
good job. next year will be it.
just think, with a bit of weight removal, you could have had that 9 second slip.
post #11 of 14 (permalink) Old 11-09-2010, 11:43 AM Thread Starter
I know, but that isn't something I'm interested in doing. Probably could have gotten a 10.0 just removing the passenger seat, spare tire and jack, but I wanted to see what it could do at full weight.
Last time I had it on the scales at the track, it had a race weight (includes me) of 4250 lbs, but that was with the chrome cobra Rs, so it was probably more like 4200 with the Bogarts, slicks and skinneys. Reducing the 60ft time is where I need to concentrate the most, and I think the changes I'm making to the convertor will help a lot.
If I could just get it to launch correctly and reduce the 60 ft to around 1.55, I'm sure it will be into the 9s. With the looser converter I'll also be able to switch back to the correctly sized .96 AR turbine housing instead of choking the motor with the smaller .81 housing I'm using now.
I don't really mind that the transmission broke, because I wanted to change the convertor anyway.
David
post #12 of 14 (permalink) Old 11-09-2010, 11:53 AM
Tbird1997's Avatar
wow thats an awesome time! 19.5psi? thats crazy! curious to what kind of hp your putting down?
-Patrick
Tbird1997 is offline
post #13 of 14 (permalink) Old 11-09-2010, 12:16 PM
Nice work! Especially considering the car's weight.
An estimate provided using those online calculators based on the weight, 1/4 time and trap speed puts it probably somewhere around 850 HP at the flywheel.
post #14 of 14 (permalink) Old 11-09-2010, 03:18 PM Thread Starter
Not that it really matters, but the ET is screwed up because of the converter issue, so it would be more accurate to use only the weight and MPH. Using this link, I got the following.
http://www.wallaceracing.com/et-hp-mph.php
Your Horsepower computed from your vehicle weight of 4200 pounds and MPH of 140.14 is 950.06.
Which equates to around 712 at the wheels with my transmission.
