Ran at cecil county dragway - TCCoA Forums
post #1 of 23 (permalink) Old 11-28-2010, 12:31 PM Thread Starter
wolfer's Avatar
Made a few runs Saturday, mods are 2003 explorer PI motor, A/C delete and 3.73. I think it made good time with no tune and hitting the speed limiter before the finish.
1994 Teal Thunderbird LX PI 4.6l
14.0 @ 100mph
wolfer is offline
post #2 of 23 (permalink) Old 11-28-2010, 12:32 PM
Yes it did. Nice
post #3 of 23 (permalink) Old 11-28-2010, 12:41 PM
Mgino96tbird46's Avatar
Looks pretty good for an "off the shelf" setup.
Mgino96tbird46 is offline
post #4 of 23 (permalink) Old 11-28-2010, 01:21 PM
Most have been good air if that's a stock tc cause that's a very impressive 60 ft for no tune and stock tc get a tune and the mph should be in the 96 plus range
Nice times
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #5 of 23 (permalink) Old 11-28-2010, 03:04 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Good job bud. Now by next year you need to get a tune in that car. Hmm, I think I might have told you that last year LOL!! : )
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #6 of 23 (permalink) Old 11-29-2010, 03:49 PM Thread Starter
wolfer's Avatar
Thanks, it still has the stock tc and it was in the upper 40's that day.
14.0 @ 100mph
wolfer is offline
post #7 of 23 (permalink) Old 11-29-2010, 04:11 PM
nice car, good times.
post #8 of 23 (permalink) Old 07-29-2012, 02:15 PM
Tbird1997's Avatar
How does your car run with the 3.73 gears and no tune? I only ask because I am getting my gears installed shortly but I won't have enough money to get a new tune for a while. Wondering if I should just wait and do it all at once.
Are those 245/60 tires are in the front too?
-Patrick
Tbird1997 is offline
post #9 of 23 (permalink) Old 07-29-2012, 09:01 PM
you dont need a tune to run gears, just change out the speedo gear in the tranny(takes 5 mins) and everything works like those were the stock gears. It work untill you get crazy like 4.10s or like me with 4.30s, then a speedcal works to correct the speedo reading.
Somewhere floating around here or SCCOA, they tell what speedo gear you need for the set of gears you plan on running.
97 LX
Motor and trans from 95
Working out the bugs right now.
R.I.P.
1995 Thunderbird LX. Black
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
Stuckinkaos07 is offline
post #10 of 23 (permalink) Old 07-30-2012, 07:01 AM
Well his top speed is 91 with 3.73, it works it just lowers your speed limiter
10.75 @128.38
RobertP is offline
post #11 of 23 (permalink) Old 07-30-2012, 08:19 AM Thread Starter
wolfer's Avatar
Like they said put the gears in, don't worry about the tune. And yes the front tires are the same size as the rears. But right now I changed my wheels back to the stock fan rims with those tires.
14.0 @ 100mph
wolfer is offline
post #12 of 23 (permalink) Old 07-30-2012, 10:23 AM
Tbird1997's Avatar
Ok thanks guys. That's great news I have forgotten that I would just need to change the speedo gear. I talked to a few different tuners and they told me I would need a retune for the 3.73 gears. The computer commands the tranny to shift based on mph correct? I actually have a tune with the limiter removed so I shouldn't have a problem with hitting it at 91.
Wolfer- In the picture above its hard to tell, are those not the fan blades with the 245/60 tires? I found some Bridgestone tires in that size that I will probably go with and they were about $150 a piece. Kinda pricey for 15s but I'm sure they will be worth the upgrade over my 235/60 firehawk tires.
-Patrick
post #13 of 23 (permalink) Old 07-31-2012, 08:50 PM Thread Starter
wolfer's Avatar
Here are the wheels I had on before.
I have the same tires on my truck. They have great dry traction and do pretty good in the snow.
14.0 @ 100mph
wolfer is offline
post #14 of 23 (permalink) Old 11-12-2012, 06:57 PM Thread Starter
wolfer's Avatar
Ran at cecil saturday, only thing done was a tune to rid of the speed limiter. Got it down to a [email protected] It was alittle warm mid to upper 50's, going to try to go back one friday night before they close. I want to see if I can hit 14.2 in the cooler night air.
14.0 @ 100mph
wolfer is offline
post #15 of 23 (permalink) Old 11-12-2012, 08:55 PM
Congrats Joe.
Great job. I think you'll get that 14.2 before the end of the year.
The MAMN12 DRT list is certainly already on a shake up. Be sure to get your times in.
Just wait until the Carolina Thunder meet!
post #16 of 23 (permalink) Old 11-17-2012, 07:28 AM Thread Starter
wolfer's Avatar
Made a few friday night runs, temp was in the mid 40's. Got it down to 14.0.
R/T.....309
60'.....2.130
330....6.008
1/8.....9.142
mph....78.08
1000...11.822
1/4.....14.076
mph....100.14
14.0 @ 100mph
wolfer is offline
post #17 of 23 (permalink) Old 11-17-2012, 09:48 AM
Time for a converter and hello easy 13's.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #18 of 23 (permalink) Old 11-17-2012, 01:06 PM
1MTNCAT's Avatar
Yes, converter, exhaust and drag tires to hook it with the converter.
Nice to run on a good track, in excellent air!!!!!!! Make one more attempt and try to hit a 13.9
Congrats Joe!!!!!!!!
Steve
1MTNCAT is offline
post #19 of 23 (permalink) Old 02-10-2014, 01:08 PM
Tbird1997's Avatar
Wow 14 flat. That's gotta be the fastest time for a thunderbird with a stock converter.
Wolfer, I got those 245/60 BF T/A tires but they don't hook as well as I would like them to, I spin pretty good off the line. Yours seem to hook pretty good with those 60' times. What air pressure do you run them at? Quick burnout or no burnout? If you don't mind me asking.
When the track opens back up I'm trying to get my 9.6 1/8th mile down to about where you have yours. My 60' time is gargage tho 2.2x-2.3 lol
-Patrick
post #20 of 23 (permalink) Old 02-10-2014, 08:02 PM
Are we posting to searches? That's from 2012...
I do this a lot sometimes.
Grog6 is online now
post #21 of 23 (permalink) Old 02-10-2014, 08:52 PM
Tbird1997's Avatar
Yup yup lol
-Patrick
post #22 of 23 (permalink) Old 02-11-2014, 08:48 PM Thread Starter
wolfer's Avatar
Air pressure was at 32psi. Do a small burn out, don't load up on the tc to much..I did run in November and hit 14.1 a bunch of times. I do have a dual exhaust with two high flow cats , x pipe and dynomax max race bullitts I'll be putting on this summer. And maybe a new tranns, and hopefully see 13's.
14.0 @ 100mph
wolfer is offline
post #23 of 23 (permalink) Old 02-11-2014, 10:44 PM
Tbird1997's Avatar
Thanks wolfer. Trying to get some decent times out of these tires before going to drag radials. I'll have to try that out
-Patrick
