first time at the track - TCCoA Forums
post #1 of 138 (permalink) Old 08-07-2011, 09:50 PM Thread Starter
Boost!!!
modularbird's Avatar
Talking first time at the track
well i finally got around to going to the track,and here are my results...
this run i launched at about 1400 rpms which seemed to be about the best take-off this big thing could muster...
r/t .167
60ft 2.236
1/8 9.833
mph. 72.96
1/4 15.177
mph. 91.74
i had a lot of fun, and with a couple little tweaks i think i could break into the 14's .
here's a link to my best run of the day that i got on tape, if anyone wants to see it
http://www.youtube.com/watch?v=w0HusozC77k
the things i felt that i need to improve before i go back were, the cheap wal-mart tires gotta go, i'm gonna adjust my shift pressure down a little so i don't chirp the tires so much going into 2nd, and i'm probably gonna move my battery to the trunk just to help shift a little more weight to the rear...
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #2 of 138 (permalink) Old 08-08-2011, 04:43 PM
Mgino96tbird46's Avatar
Get some wider tires, and you should be in the high 14's.
Mgino96tbird46 is offline
post #3 of 138 (permalink) Old 08-08-2011, 04:55 PM
Faster than Porkchop
cjchevez's Avatar
Good times man , congrats!
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #4 of 138 (permalink) Old 08-08-2011, 05:35 PM Thread Starter
Boost!!!
i was really hoping to get into the 14's, but im almost there... some punk with a honda was talking a lot of crap every time i ran, his best time was like 14.5 ish. i hope hes down there next time i go!!! I think after i shave a little weight off the car (weighs 3840 lbs with me in it and 1/4 tank of gas) and get some better tires i'll do a lot better...hopefully
Blake
post #5 of 138 (permalink) Old 08-10-2011, 11:35 AM
Banned
91bluecoupe's Avatar
Blake,
Do you think you had a lot of wheel spin?
I would hope to you (or I) could get into the lower 14's atleast.
91bluecoupe is offline
post #6 of 138 (permalink) Old 08-10-2011, 12:12 PM Thread Starter
Boost!!!
Originally Posted by 91bluecoupe View Post
Blake,
my best run i didn't have hardly any wheel spin, but i could only launch at about 1350-1400 rpm max or i had bad wheel hop or spun. i could probably get a bit lower on better tires alone... i have stock size and width Viva 2's on it now... they suck for traction though.they are rated to last 60,000 miles, but the way im going they may last about 10,000
Blake
post #7 of 138 (permalink) Old 08-10-2011, 12:50 PM
Banned
Yeah that is one of the reasons I have not went to the track, cause I know even though my tires are really wide they are hard and it takes a lot to get the warm. I spin very easily on the streets now. And I run only 25 psi in the rears.
post #8 of 138 (permalink) Old 08-10-2011, 03:39 PM
tires, gear and weight removal will get you low 14's.
post #9 of 138 (permalink) Old 08-10-2011, 04:01 PM Thread Starter
Boost!!!
i highly doubt i'll ever go bigger than 3.73's on the gears.im working on the weight this weekend, got a couple little things to do also(fix exhaust leak, install u/d pulleys,change my speedo gear, and relocate the battery to the trunk).
i will probably get an extra pair of stock rims and some drag radials for the track and some skinnies for the front...by the way quick question :what is the best kind and gauge of wire for relocating the battery?
Blake
post #10 of 138 (permalink) Old 08-10-2011, 04:46 PM
Banned
When I am able to get a set of slicks then I will go to the track to run high 13's.
post #11 of 138 (permalink) Old 08-10-2011, 05:24 PM Thread Starter
Boost!!!
you sound fairly certain... i thought i would be in the 14's before i went, then when i got my first time slip and it said 15.45 i was like wtf i thought it was faster than that...plus my reaction time was over .700 good thing they were running one lane at a time...and not to mention the second time i staged up, i did so on my back tires... the track attendant probably thought i was retarded
Blake
post #12 of 138 (permalink) Old 08-10-2011, 09:02 PM
were you driving through the water box?
post #13 of 138 (permalink) Old 08-10-2011, 09:26 PM Thread Starter
Boost!!!
yeah there wasn't really room to get around it...i burned out like hell trying to dry them off/heat them up. i know burnouts on street tires don't really help...i had to get the water off them some how...and it was a lot of fun!!! probably wasted half the tread on the tires ...seriously i ran about 20-25 times and did a burnout every time
Blake
post #14 of 138 (permalink) Old 08-11-2011, 08:28 AM
Banned
Blake you need a higher stall converter, the stock ones are junk. It made a huge difference in my car when I got mine.
Wow that is alot of runs!! Sounded like alot of fun!
Yeah I have done some testing on a closed road by my house and I have marked the road for the 1/8th and the 1/4 and I clock my test runs.
post #15 of 138 (permalink) Old 08-11-2011, 03:54 PM Thread Starter
Boost!!!
yeah there were literally less than 20 cars running. it was great there was no line, and there were some interesting cars there...there was a nova with a huge motor and twin turbos the size of spare tire rims but he couldn't get it running right i wont have the money for a stall converter till tax season ...unless i get a LOT of overtime.
i will be shooting for low 14's this year, and 13's next year
Blake
post #16 of 138 (permalink) Old 08-11-2011, 04:36 PM
Banned
It will be real tough for you to get into the 14's without a stall.
post #17 of 138 (permalink) Old 08-11-2011, 06:01 PM Thread Starter
Boost!!!
like i said, im gonna drop as much weight as i can, and maybe ill get there...all i gotta drop is 2 tenths of a second, and im there. it shouldn't be that difficult .
Blake
post #18 of 138 (permalink) Old 08-11-2011, 06:48 PM
Earl's Avatar
I ran a 14.992 and have almost identical mods to your car, but you have better exhaust, CAI, MAF, tb, etc. in all of those areas your car is superior to mine, plus when I ran mine I was not yet J-modded, just tuned, and I had no idea what I was doing, so, with that in mind your car is more than capable of running mid 14's, tires would probably help you out on this.
Earl is offline
post #19 of 138 (permalink) Old 08-11-2011, 08:59 PM
Tbird1997's Avatar
Dang I have very similar mods as you (minus the 373 gear) and I'm kinda afraid to go to the track.. I was really hoping I would be able to hit low 15s and with a gear coming soon high 14s.. If your numbers are about right that means I am in the mid to high 15s CRAP. My buddy Ethan's 97 mustang 5spd is running 15 flat with just exhaust and fat tires.
-Patrick
Tbird1997 is offline
post #20 of 138 (permalink) Old 08-11-2011, 09:37 PM
No. If you are a decent driver, you should be running faster times than what I am running. I ran the 15.421 with no j-mod, skinnier tires, wheel spin, and stock drive shaft. The transition from 225 to 235mm wide tires made a noticeable difference in WOT traction also.
post #21 of 138 (permalink) Old 08-11-2011, 10:47 PM Thread Starter
Boost!!!
no reason to be afraid of going to the track...it doesn't matter how fast you run
there's always someone faster or slower than you. your not there to prove anything
to anyone your there because you enjoy it. no matter what i run i always have fun... after the first 10 runs i wasn't getting any faster, but i kept running it because it was fun. to tell you the truth i had more fun in the burnout box than some of my runs
Blake
post #22 of 138 (permalink) Old 08-11-2011, 11:37 PM
ManicMike's Avatar
Seat time is the key. The more you race, the faster you'll get till eventually you hit the car's performance wall.
Auto car's are easy. Try launching a 2900lbs, 500lbs of torque making, turbo 5 liter... Though a 5 speed! I'm getting there but still need a lot more seat time.
Best to date is a 11.67 @ 119 mph with a 1.73 '60 foot on a .220 R/T. I can smell 11.40's, but just need to focus on the '60 a bit more and hope the 8.8 hold's up
Current rides:
'88 Mustang LX Coupe - The race car
'92 Thunderbird SC - The daily
ManicMike is offline
post #23 of 138 (permalink) Old 08-12-2011, 11:00 AM
I couldn't agree more. I made my 15.421 on my second pass ever on the 1/4. Before then, I had never taken my car to the track, let alone been to a track.
post #24 of 138 (permalink) Old 08-12-2011, 11:30 AM
Banned
Blake we need to get to a track for a mini meet sometime and maybe my friend Jamie(Cobra R) in Tally can be there to.
I have raced a lot and I agree about seat time.
But one thing I did find out is that once you hit the wall on being good with your setup then to get even .2 is really tough.
In an Auto you almost have to have a good stall TC to get our heavy cars into the 14's I have seen.
post #25 of 138 (permalink) Old 08-12-2011, 12:26 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Stage I-IIish cams, Bullitt/SVO intake and an appropriate retune for shifts and you'll be there easily.
guitar maestro is offline
post #26 of 138 (permalink) Old 08-12-2011, 12:36 PM
If you go with one of Dirty Dog's higher stall torque converters, you should easily be in the 14's with no problem. IIRC, Alan told me that if I go with one of his 10" units, I could drop anywhere from .6-.8 seconds off of my 1/4 mile e.t. easily.
post #27 of 138 (permalink) Old 08-12-2011, 01:54 PM
modularbird,
You asked about gage of wire for the battery relocation. I'm running 1-gage wire, which may be overkill. I know it was damned hard to get it to follow curves! Most of the kits Summit racing sells come with 2-gage wires.
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #28 of 138 (permalink) Old 08-12-2011, 02:17 PM
Banned
I know that my TC was the top 3 best mods I have done yet.
And I know I have gained atleast .5 in the 1/4.
post #29 of 138 (permalink) Old 08-12-2011, 03:48 PM Thread Starter
Boost!!!
i just looked, im running 215 70r15 how much wider should i go on stock 15 inch rims? ...size suggestions anyone?
Blake
post #30 of 138 (permalink) Old 08-12-2011, 04:05 PM
Banned
I ran 255/60/15 for a long time and it helped a lot. Handled great and looked tough to.
