What Does A 2400HP Teksid Look Like? - TCCoA Forums
post #1 of 28 (permalink) Old 12-29-2011, 07:10 PM Thread Starter
Well, it starts off looking innocent enough (is that a little coating on them pistons?):
Now add some DOHC heads with valve train modified to handle 9000 rpm:
What kind of intake did they use? Hogan (not Logan):
Little extra girdle strength for the abuse that bottom will be taking:
Top it all off with a pair of "iron lungs":
How can get all that power to the ground? LOTS of tire!:
To go really, really, really, really, REALLY fast requires a light body (maybe a Daytona?!?):
~Rick
TCCoA Sig
post #2 of 28 (permalink) Old 12-29-2011, 08:12 PM
Don Pfau's Avatar
WOW is that pretty. What body is that in ???
93 Mark VIII - Vortech S/C 8psi, Kooks headers, 3800 stall, DD valve body, 4:10 gears w/trac-loc, 2 1/2 true duals with a Magnaflow X-pipe resonator, Electric Water Pump, Meth Injection, 17 in Cobra R wheels. [email protected] Pictures http://www.lincolnvscadillac.com/for...o=hall&u=16112 Videos http://www.youtube.com/user/1210291341?feature=mhee
Don Pfau is offline
post #3 of 28 (permalink) Old 12-29-2011, 08:19 PM Thread Starter
1991 Dodge Daytona mostly
~Rick
TCCoA Sig
post #4 of 28 (permalink) Old 12-29-2011, 08:25 PM
Surprise, surprise! I had it pegged as just another "all-out" Mustang and yippy skippy.
But....going in a G Body Daytona/Laser? That's just sick and twisted.
I have great fondness for sick and twisted, btw. lol
Delete my account.
94 Thunderbird XX is offline
post #5 of 28 (permalink) Old 12-29-2011, 09:26 PM
cobra R Thunderbird's Avatar
2001 GT BULLITT #00762 stock
post #6 of 28 (permalink) Old 12-29-2011, 10:38 PM
So the crank will be spinning 18,000 RPM? Guitar maestro will be jealous
post #7 of 28 (permalink) Old 12-29-2011, 11:22 PM Thread Starter
~Rick
TCCoA Sig
post #8 of 28 (permalink) Old 12-30-2011, 12:12 AM
Moderator & Teksid Whore
guitar maestro's Avatar
don't forget about those coolant passages in the block. Anyone besides me see anything interesting? Have to point it out before newbs start on this endeavor lol.
guitar maestro is offline
post #9 of 28 (permalink) Old 12-30-2011, 12:50 AM
Dual injectors, and an evac pump
post #10 of 28 (permalink) Old 12-30-2011, 04:35 PM
That looks pretty cool, even tho I don't recognize the injectors...
Are you talking about the fail-prone cam gears, GM? I would use the adj crank gears, drilled and pinned, personally.
post #11 of 28 (permalink) Old 12-31-2011, 12:03 AM Thread Starter
You know I didn't even notice that it had dual injectors until you mentioned it! And I even noticed they were purple and my reference shows "Purple Tops" are 65 lb injectors and I thought to myself "those aren't big enough to support 2400 hp". I just figured they were bigger and coincidentally happened to be purple in color.
But now I realize TWO SETS of "Purple Tops" would definitely support 2400 hp. I have a Bosch part number of 0280150845 in my references.
I guess that engine won't suffer from the second port B-head problem of carbon build-up!
As for those cams gears being prone to failure - I just didn't know that. Have to file that in my brain, however.
~Rick
TCCoA Sig
post #12 of 28 (permalink) Old 12-31-2011, 03:21 AM
Nope. First pic, look INSIDE the coolant passages.
post #13 of 28 (permalink) Old 12-31-2011, 07:06 AM
Block is filled. No need for a lot of coolant area in a car that only sees quarter miles @ in 7 seconds at one time. lol
Delete my account.
post #14 of 28 (permalink) Old 12-31-2011, 10:56 AM Thread Starter
So they put Hardblok in it. Why did you say point it out before someone tries to build one like it? Do you think the block would crack without it?
If you look at that pic close enough, you can see the 5 gallon bucket of Hardblok in the background.
~Rick
TCCoA Sig
post #15 of 28 (permalink) Old 12-31-2011, 02:45 PM
At those power levels this ounce of prevention is better than the pound of cure.
I'm actually surprised they didn't also fab up and weld in gussets across the valley before the machining and assembly of the short block.
Delete my account.
post #16 of 28 (permalink) Old 12-31-2011, 06:23 PM
yup.
post #17 of 28 (permalink) Old 01-01-2012, 09:09 PM
It ain't like you're driving any car with that motor to Kroger's for beer, lol.
I'd think block filler and welding would be required at that power level...
post #18 of 28 (permalink) Old 01-01-2012, 11:50 PM
Mihovetz didn't do any welding. He did however machine the main caps and the main bulkheads for beefed up hardware. Stood up fine in his Cougar.
post #19 of 28 (permalink) Old 01-02-2012, 11:52 AM
Who was it that broke the mark engine in half?
I've seen pix here, but it's been awhile.
Seems like it was boost and nitrous that broke it...
I think the middle webbing let go on it.
Here it is:
http://forums.tccoa.com/showthread.php?p=1133590
post #20 of 28 (permalink) Old 01-02-2012, 12:42 PM
95LX4.6's Avatar
I know I'm not a guru like a lot of you, but I can say this. That is the most F****d up engine I've ever seen!!! Holy Crap!!!
95LX4.6 is offline
post #21 of 28 (permalink) Old 01-02-2012, 12:52 PM
There the crank let go and that took out the block. Not like the old 302s where the cam bore itself cracked.
post #22 of 28 (permalink) Old 01-02-2012, 01:04 PM Thread Starter
Here it is:
That engine broke in half is pretty wild. Taking a look at the engine built in this thread, it looks like a forged since the metal is so smooth looking and it looks like some writing on it. I certainly hope nobody would put together an engine like this with a cast crank!
~Rick
TCCoA Sig
post #23 of 28 (permalink) Old 01-02-2012, 03:38 PM
The engine that let go was cast; you can see one of the center 'weights' in one of the pix...
I've seen worse, but it was nitro fuel and a big blower; the blower didn't hit the ground for ~20 seconds, it seemed like.
post #24 of 28 (permalink) Old 01-03-2012, 12:15 PM
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
I'm pretty sure first start will be immediately followed by...
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #25 of 28 (permalink) Old 01-03-2012, 02:41 PM
95LX4.6's Avatar
I'm in tears from laughing right now!
95LX4.6 is offline
post #26 of 28 (permalink) Old 01-03-2012, 11:08 PM Thread Starter
This vehicle has not been run yet; the last post is dated 12-19-11 following the build.
They said they are capping the power at about 2000 until they make a few runs with it.
Personally, I hope it doesn't end up looking like that pic! The builder is seriously hoping to do a big show for a small 281ci size engine, but not quite that big!
~Rick
TCCoA Sig
post #27 of 28 (permalink) Old 01-04-2012, 12:21 AM Thread Starter
I was just figuring something out, also. If he is running 2 sets of 65 lb injectors which is what it looks like.
At maximum duty cycle, each 65 lb injector is 130 hp, so 16 * 130 = 2080 hp !!!
Guess he better not try to push that engine much past 2000 hp or else he's gonna run out of fuel!
~Rick
TCCoA Sig
post #28 of 28 (permalink) Old 02-05-2012, 12:21 AM
Ah!!! Death gears!!!
