Fastest "stock" IRS 1/4 mile time ? - TCCoA Forums
post #1 of 19 (permalink) Old 06-09-2012, 06:13 AM Thread Starter
jhiland32's Avatar
Anyone ?
Edit stock meaning modified rear but retaining the IRS set-up no solid axle swaps.Just curious.
Jason H.
Mods:
jhiland32 is offline
post #2 of 19 (permalink) Old 06-09-2012, 06:32 AM
Define "stock" for the purpose of this question.
post #3 of 19 (permalink) Old 06-09-2012, 06:49 AM
Exactly. Example, there is one Bird I know of within 1/20 second of 9s running the stock IRS. Granted most use air bags in the springs and aftermarket bushings, but the IRS subframe and halfshafts remain the same.
post #4 of 19 (permalink) Old 06-09-2012, 07:04 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Yeah Really
You've got a boat load of engine combo's too if that matters? 3.8 SC, 4.6 2v, 4.6 4V, 5.0, or 5.0 stroked small block derivatives.
I know I've seen one car go 9's two years ago at the shootout on the IRS if I'm not mistaken. Chris Lazzo's car. I'm sure it went a 9.97 or so, built and stroked small block Ford. I also know that Dave Niebert's built small block is very near breaking into the 9's last I saw. As far as the 4.6's Mike Siska's Allen SC IRS car has run in the 10.3 range. I've seen a SC IRS car (Chris Vining) go down in the 10.7 range. I suppose there could be others out there we don't know about.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #5 of 19 (permalink) Old 06-09-2012, 09:38 AM
Yeah Lazzo and Neibert with their SBF's one centrifugal and one turbo. Neibert went a best of 10.04 so close to 9.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #6 of 19 (permalink) Old 06-09-2012, 09:24 PM
Don Pfau's Avatar
Here is Mike Burbank's 98 Lincoln Mark VIII running 10.67 ---- http://www.youtube.com/watch?v=xyqZ2M1JVdA ---- Has since ran a best 10.64
93 Mark VIII - Vortech S/C 8psi, Kooks headers, 3800 stall, DD valve body, 4:10 gears w/trac-loc, 2 1/2 true duals with a Magnaflow X-pipe resonator, Electric Water Pump, Meth Injection, 17 in Cobra R wheels. [email protected] Pictures http://www.lincolnvscadillac.com/for...o=hall&u=16112 Videos http://www.youtube.com/user/1210291341?feature=mhee
Don Pfau is offline
post #7 of 19 (permalink) Old 06-09-2012, 10:04 PM
and to add to this list ...
RobertP (4.6 2v) is in the 10's - 10.9 and 10.75
Kevin Leitem (3.8 SC) has run 10.1
post #8 of 19 (permalink) Old 06-10-2012, 02:44 AM
VicRattlehead's Avatar
Kevin isn't on IRS anymore
CMP Drag Racing
VicRattlehead is offline
post #9 of 19 (permalink) Old 06-10-2012, 09:40 AM
My IRS is completely stock to the axles and bushings oem ford 4.6 not super coupe, just have lowering springs 10.75
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #10 of 19 (permalink) Old 06-10-2012, 10:11 AM
1MTNCAT's Avatar
So whats Supercoupe got to do with it? Its still stock MN12 stuff and its no stronger at the hubs than the standard MN12 stuff.
"Kevin isn't on IRS anymore"
Keith is correct. Kevins car has been a solid axle for several years. All the others listed at this point are factory style IRS.
Steve
1MTNCAT is offline
post #11 of 19 (permalink) Old 06-10-2012, 10:32 AM
Supercoupe is bigger axles, period ford put bigger axles for a reason just look at a cobra
10.75 @128.38
RobertP is offline
post #12 of 19 (permalink) Old 06-10-2012, 11:05 AM
1MTNCAT's Avatar
Robert, You done went and lost your damned mind! The axle part is a bit heavier but it makes NO difference. Where it goes through the hub and where they break is at the hub, not the axle. The SC, LX, Lincoln Mark VIII are ALL the SAME where it breaks at the hub period and on the inside at the carrier as well.
You want me to send you the ones I've broken to prove it to you?? I've got a couple. Launching as hard as mine does (1.57 60ft) I've broken plenty of them. I'm sure some others on here know as well.
Steve
1MTNCAT is offline
post #13 of 19 (permalink) Old 06-10-2012, 11:19 AM
Agree to disagree and leave it at that.
Let's not get all bent out of shape (no pun intended ) over axles.
post #14 of 19 (permalink) Old 06-10-2012, 12:05 PM
Beside the point I've got and cobra axle here that I broke and it's part way the splined and the axle part, I guess ford decided to waste money on metal
10.75 @128.38
RobertP is offline
post #15 of 19 (permalink) Old 06-10-2012, 01:12 PM
1MTNCAT's Avatar
The actual shaft from the Inside knuckle to the outside end knuckle is larger in diameter on a SC. But the splined end of the halfshaft from that point is no different. They break at the hub, and not the shaft itself, knuckle to knuckle.
I will agree to disagree TM cause I know I'm right.
Now a Mustang IRS, not sure if the hub is splined the same or not, same diameter or what going through the hub assembly but I'm talking MN12/FN10's here. They may be different and maybe the parts don't interchange. I think the inside splines at the rear are certainly different.
That I'm NOT sure on. So I have no comment there.
Steve
1MTNCAT is offline
post #16 of 19 (permalink) Old 06-10-2012, 03:09 PM
Point is I'm running lx v8 axles not supercoupe or mark 8 axles enough said its stock oem stuff on my lx supercoupe would not be stock is the point
10.75 @128.38
RobertP is offline
post #17 of 19 (permalink) Old 06-10-2012, 09:42 PM
1MTNCAT's Avatar
Edit " stock meaning modified rear but retaining the IRS set-up no solid axle swaps. Just curious".
Ok, So tell me whats different about your stock IRS LX halfshafts than a Mark VIII IRS halfshaft. Do they/will they interchange swap to swap?? So I'm not putting a original stock Ford IRS halfshaft in my car out of a Mark VIII?
I broke the original ones in mine abut 9 years ago the first time. I've used salvage yards pulls in it since.
Steve
1MTNCAT is offline
post #18 of 19 (permalink) Old 06-10-2012, 10:11 PM
Mark 8 has fatter axles I'm sure they all fit just fine, I even put supercoupe axles in Hans car way back when I know they fit just fine but there a different part number, there the same as an auto supercoupe atleast the ones I have seen and the manual cars are even bigger
10.75 @128.38
RobertP is offline
post #19 of 19 (permalink) Old 06-11-2012, 09:32 AM
Some of the 5 speed SC cars came with a fatter right side shaft. But all the outer knuckles are the same spline count from t bird to mark to cobra. Which is where most break. You have to go to the driveshaft shop to get an upgraded outer hub with 33 splines. The terminators came with a 31 spline inner knuckle.
BLOWN38 is offline
