Questions on roll cages - TCCoA Forums
post #1 of 58 (permalink) Old 12-24-2012, 05:16 PM Thread Starter
S4gunn's Avatar
Q: If the goal is to make a drag weapon (as opposed to a daily driver), how built up is your roll cage. At the ETs you guys are running, do you already have a full cage yet?
If so, is the cage tied to your front/rear suspension points?
Here's an example of a rollcage that's almost a "car within a car". I especially like the plates that tie the shell whenever it comes close to the roll cage structure.
http://www.millerwelds.com/resources...article96.html
-G
http://goo.gl/csaet4
S4gunn is offline
post #2 of 58 (permalink) Old 12-26-2012, 11:44 AM
I have a roll bar, and my points 7 and 8 are tied into my home made SFC's.
other than that, my car is one body now....all the unibody seams were welded.
post #3 of 58 (permalink) Old 12-26-2012, 01:21 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
A bar is all you need till 9.9's. Then a cage is required!
Most all of the legal drag racing cars on here presently use bars. Once into that 9 second zone then a cage is a must legally.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #4 of 58 (permalink) Old 12-27-2012, 03:18 PM
Moderator & Teksid Whore
guitar maestro's Avatar
did you use mild steel or chromoly?
that's a lot of work to weld all the seams. If I was stripping my whole car, I'd likely do the same. But I'm not, lol.
guitar maestro is offline
post #5 of 58 (permalink) Old 12-27-2012, 03:27 PM
MS.
I did not have the funds for a tig, and already had 2 migs.
Have you decided to remove any sound deadening?
oh, and I welded the bottom of the car too!
post #6 of 58 (permalink) Old 12-27-2012, 03:29 PM
What is the difference between a "Bar" and a "Cage"?
For the "Bar" the pipe is following the inside driver B-post, roof and then passenger B-post? And obviously the cage is what Nick has?
post #7 of 58 (permalink) Old 12-27-2012, 03:31 PM
a roll bar is 8 ppints or less.
a roll cage is 10 or more.
I have a roll bar.
funny you ask, as I am having this same discussion on a local forum. lol
post #8 of 58 (permalink) Old 12-27-2012, 03:34 PM
Wow that's a lot of bar. You have to have a roll bar for times 11.50 and under correct?
post #9 of 58 (permalink) Old 12-27-2012, 03:47 PM
correct.
11.49 - 9.99
and I believe there is a limit on mph as well, but I can't remember without looking it up.
post #10 of 58 (permalink) Old 12-27-2012, 03:52 PM
I can't see having a roll bar in my car. I like the interior the way it is. I'll have to keep it slow, but on the other hand if I had a rockin drag car I'd cage it out like a jail cell. Thanks for the 101!
post #11 of 58 (permalink) Old 12-27-2012, 04:02 PM
what??? this doesn't look cozy to you??
anytime my friend.
post #12 of 58 (permalink) Old 12-27-2012, 04:42 PM
bowez's Avatar
I know its being a smart arse but...
At my local track the only requirement is a helmet, but then again its the only wildcat track left--no NHRA.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #13 of 58 (permalink) Old 12-27-2012, 04:46 PM
the tech is getting lax at my local track as well.
we always joke about that your car can be on fire and still pass tech.
post #14 of 58 (permalink) Old 12-27-2012, 04:51 PM
A bar isn't too bad as long as you don't need to get in back. And it stiffened the car up alot on mine. Riding with the firm ride off now is like riding with the firm ride on before the bar.
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------322RWHP -------------who knows/who cares
[email protected]@[email protected]
BLOWN38 is offline
post #15 of 58 (permalink) Old 12-27-2012, 05:29 PM
tbirdtess's Avatar
Roll cage
My cage is required.
I attached it to a 2x3 I ran from front to back.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #16 of 58 (permalink) Old 12-27-2012, 06:55 PM
1MTNCAT's Avatar
I expect it is in your line of motorsports. Most cars on here do not need nor do they require a cage. Thats all I was saying. Some refer to a bar as a cage, but they are not the same.
There may be some soon entering that zone soon though. Regardless bar or cage, it's all for the protection of the driver and safety should be a priority.
Steve
1MTNCAT is offline
post #17 of 58 (permalink) Old 12-27-2012, 07:04 PM
tbirdtess's Avatar
YES, YES!!!
Safety first. You never know what will happen!
351W 2bbl.
C-4 Auto
3.90 open rear
post #18 of 58 (permalink) Old 12-27-2012, 07:42 PM
nickleman60's Avatar
Here's mine, the sidebars swing out and are removable. I only have them in at the track.
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #19 of 58 (permalink) Old 12-27-2012, 08:05 PM
VicRattlehead's Avatar
I have a roll bar.
Cage has a halo bar u can do a 10 pt without a halo and its still just a bar.
CMP Drag Racing
VicRattlehead is offline
post #20 of 58 (permalink) Old 12-28-2012, 12:21 AM
97Tturd's Avatar
Originally Posted by BLOWN38 View Post
I cant wait till I get my corbeau seats in!
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #21 of 58 (permalink) Old 12-28-2012, 08:55 AM
For as firm as they are, they are comfy.
BLOWN38 is offline
post #22 of 58 (permalink) Old 12-28-2012, 01:24 PM
97Tturd's Avatar
Those look like cr-1's?
1997 Thunderbird LX
2003 Mach 1
2002 Escape
97Tturd is offline
post #23 of 58 (permalink) Old 12-28-2012, 02:42 PM
I'm not even sure. I bought them used that were never used.
BLOWN38 is offline
post #24 of 58 (permalink) Old 12-28-2012, 04:44 PM
r429460's Avatar
You know what else?
Per nhra all 2008 and newer cars don't
Need a rollbar until 9.99 or 135 mph.
:P
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #25 of 58 (permalink) Old 12-28-2012, 05:04 PM
Exactly we'll said rick
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #26 of 58 (permalink) Old 12-28-2012, 05:28 PM
Originally Posted by r429460 View Post
You know what else?
Per NHRA all 2008 and newer card don't
:P
Yea, Rob. Just keep it under 135 MPH and you'll be fine.
Hey when you do get that rocket back to the track next year let me know, I want to get some video of it. Hopefully I'll be around ....
post #27 of 58 (permalink) Old 12-28-2012, 06:19 PM
You know what else?
:P
Completely bone stock cars down to the tires tho.
BLOWN38 is offline
post #28 of 58 (permalink) Old 12-31-2012, 07:47 PM
tbirdtess's Avatar
role cage
So I have yet to see a role cage in these pictures.
You can see some of my cage in the beginning of this clip.
http://s180.beta.photobucket.com/use...Y0159.mp4.html
Note the door bars & the front hoop.
rear cross.
351W 2bbl.
C-4 Auto
3.90 open rear
post #29 of 58 (permalink) Old 01-01-2013, 01:40 AM
Now that's a real cage!
I like the battery location too
post #30 of 58 (permalink) Old 01-01-2013, 09:33 AM
1MTNCAT's Avatar
Here we go again!. Either NHRA or IHRA require anyone running under 11.50 or 11.00 dependant to have a required Roll Bar regardless! Lap belts and helmets and fire jacket are also required among other things.
Minimum of Bar/Cage is required with either sanctioning body once you start exceeding the 135 MPH barrier.
I know you all skirt the safety issues but this is what the facts are to be legal.
The new NHRA rule is for Sedans from 2008 up that are unaltered in any way to run down to those numbers. Of course, like everyone else that is at the discretion of the track personnel doing the inspecting which at IRHA that I've seen are sometimes very lax.
That being said I'm not getting into any safety issues with the cars. BUT, ROB and YOU BOTH know what should be done concerning his cars. Nuff said.
You won't be doing that but once at any of the tracks up here for sure.
Steve
1MTNCAT is offline
