Does Mason Dixon Dragway Run Downhill? - TCCoA Forums
post #1 of 20 (permalink) Old 01-23-2013, 06:23 PM Thread Starter
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Originally Posted by ThunderChecken View Post
That track up there looks like its down hill then up hill .
Well its slightly up hill, flat at the stripe, then a downhill dip and back up on the shutdown area.
Thats why the Carolina cars run a few tenths slower up here than at Fayetteville. That means that I need to get my car to Fayettville.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #2 of 20 (permalink) Old 01-23-2013, 06:46 PM
Thanks so much everyone. I put a lot of time into making that video.
Yea, you need to bring your car to Fayetteville this fall. It would really help your times running at 165'. The closest thing to Mason Dixon here is zMax at 630'.
Another fine production That track up there looks like its down hill then up hill.
Thanks Darren.
... about Mason Dixon:
It is downhill then up at the end but you will run a few tenths slower at MD then at Fayetteville because the track is at a higher elevation. I've looked extensively into this using Google earth and my own GPS.
Fayetteville is at 165' elevation.
According to Google Earth: Mason Dixon starts at 545 feet elevation at the light tree then drops to 530 feet at a track cross over road located at about the 1/8th mile mark. (Minus 15 feet) the track then rises to 539 feet at the finish - plus 9 feet in the second 1/8th mile but still 6 feet below the start line, the run out continues to rise to 565 feet at the turn out.
That's a 1.3° downward angle over the first 660' (1/8th mile) and a .5° rise from the eighth mile to the finish line. Followed by a .8° rise from the finish line to the turn out in the 1,870' of track run out.
Steve may call BS on this but even if these numbers aren't *exactly right there's no doubt in my mind that this track runs down hill. I will check these numbers again with my own GPS when I'm there in July.
Mason Dixon looks like this:
Here's the best picture of the elevation change at Mason Dixon that I have. Unlike other tracks the time signs are not at the end but located at the 1/8th mile mark.
post #3 of 20 (permalink) Old 01-23-2013, 08:04 PM
driller's Avatar
LOL, unless you have a commercial differential GPS rig, I wouldn't put a lot of faith in those numbers, Google Earth included.
http://weather.gladstonefamily.net/gps_elevation.html
driller is offline
post #4 of 20 (permalink) Old 01-23-2013, 09:17 PM
All right. I'll give you that JP. I know that your background is in this sort of thing.
I'll take a different approach to my analysis.
How about the track's published elevation at their website of 550' and a USGS map of the area?
Here's the USGS map showing two 20' contour intervals running across the track. Based on this:
The minimum elevation change from start to finish of that track is 5 feet (a quarter of the distance of the contour intervals).
The maximum elevation change is 10 feet (half the distance of the contour intervals); which is actually 4 MORE feet of drop - start to finish - than my Google Earth estimate above.
I'll take a ± 5' deviation from my Google Earth estimate.
post #5 of 20 (permalink) Old 01-23-2013, 09:37 PM
driller's Avatar
Not denying any claim of grade of the track, just pointing out the futility of trying to quantify it with GPS.
Besides, any given track day, the car sees much greater elevation changes due to variable atmospheric conditions.
Great video BTW.
driller is offline
post #6 of 20 (permalink) Old 01-23-2013, 09:42 PM
Ah, Ok. I wasn't aware that consumer grade GPS units were that inacurate in their elevation measurements.
I also thought about simply laying a level on the track and seeing which way the bubble pointed. LOL
Yea, no doubt about atmospheric variables.
Thanks JP. I put a lot of time into making that video.
post #7 of 20 (permalink) Old 01-24-2013, 06:28 AM
What side of the Mason-Dixon line is the track on ? Yankee engineering J/King , Thanks for the info Ron .
post #8 of 20 (permalink) Old 01-24-2013, 06:38 AM
Well technically the Mason-Dixon line was measured to divide MD from PA and DE after they figured out what to do about Philly... "North" and "South" were divided (officially) by 36°30′ N.
post #9 of 20 (permalink) Old 01-24-2013, 07:11 AM
From alot of guys I talk to Mir is about the fastest track around for what ever reason they say super mineshaft air and it dead hooks
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #10 of 20 (permalink) Old 01-24-2013, 07:33 AM Thread Starter
1MTNCAT's Avatar
Not true Robert. MIR, Cecil and VMP are equally fast in the right conditions. Englishtown is the same. I've been on it a couple different times too. I've run all of them at different times over the years. Cecil and MIR seem to hook the best however.
They turn out numbers just like Fayetteville.
As for Mason Dixon, my point was you ARE running up hill from the 1/8th to the stripe (Approx 10ft elevation-top end pull) which is within 5 feet of the starting line elevation. Call it downhill if you like.
I've always run best numbers and MPH at other tracks by 2-2.5 tenths at Cecil, MIR, etc in similar good conditions. I had got the bugs out of the car last spring when I ran my numbers at Mason Dixon. Never got a chance to get it at any other track in good conditions where I could run numbers. It is what it is lol!!!!
I know this also, a couple of the boys that ran at SB11 Last summer picked up 4.25-4.5 10's at Fayettville in November. Different track and conditions but you get the point.
Steve
1MTNCAT is offline
post #11 of 20 (permalink) Old 01-24-2013, 03:32 PM
bowez's Avatar
Get a string line on it.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #12 of 20 (permalink) Old 01-25-2013, 10:17 AM
T6Rocket's Avatar
Fayetteville is not a fast track, despite it's elevation. Maybe it's a rough track surface, maybe cause it's uphill to the 1/8th (need to put a level on that track!)
I ran .12 faster at Rockingham than I did at Fayetteville with the same 60' time, same temps. This was back in 2003, ran [email protected] at Fayetteville, and [email protected] at the Rock. My car is intercooled and not temp sensitive to small weather changes.
In the heat, there is no contest, Fayetteville is much slower than the Rock, which doesn't seem to be affected by heat as much.
I only ran at MIR once in my old Talon, it was hot and humid so I ran slow. But people have said MIR and the Rock are comparable. The fact that the Rock doesn't hook anymore is beside the point.
The point is Fayetteville is "average" at best, unless you run in the mine shaft air in the winter, when all other tracks are closed.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #13 of 20 (permalink) Old 01-25-2013, 10:59 AM
I'll say this much about consumer GPS's elevation accuracy...
While we were in Miami sitting still in a parking lot last week, the bosses' Garmin said the elevation was -16' all the way to +2' above sea level. I watched it the whole time we were sitting there waiting and the number kept changing the whole time.
~Rick
TCCoA Sig
post #14 of 20 (permalink) Old 01-25-2013, 11:26 AM
Yea, I'll see that in Fla. too. When I'm driving the keys my GARMIN often drop to negative elevation numbers. But when you're in New Orleans and you see that you know it's right! lol
Still, my GARMIN has shown 165' at Faytteville which is correct.
I was pretty impressed with Google Earth in my examination of Mason Dixon above compared to the USGS map. I'd say it's pretty accurate.
post #15 of 20 (permalink) Old 01-27-2013, 06:42 PM
Like Titles Matter
kdanner's Avatar
Did you look at Cecil County? I first did a couple of years ago. Downhill all the way, just like the pictures show.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #16 of 20 (permalink) Old 01-27-2013, 07:12 PM
LOL
No wonder Steve likes to run there.
No I haven't done an analysis of Cecil and, until you mentioned it, I wasn't aware that that track did run downhill. A quick Google search did bring up lots of references to it running downhill though.
post #17 of 20 (permalink) Old 01-28-2013, 06:35 AM Thread Starter
1MTNCAT's Avatar
Actually
Like you running at MD compared to Fayettville/Rockingham TM LOL.
It would be interesting to see what ALL the tracks look like elevation wise and values. Cecil, MIR, Fayettville, Rockingham, Englishtown Etc.
Maybe useful information.
Steve
1MTNCAT is offline
post #18 of 20 (permalink) Old 01-28-2013, 07:00 AM
It's not that hard to do... Here, I'll list all the tracks that we use all in one place.
165' - Fayetteville, NC
178' - Old Bridge Township Raceway Park - Englishtown, NJ
318' - Cecil*
430' - Rockingham, NC
550' - Mason Dixon**
630' - zMax - Concord, NC
* 8' down hill grade
** 5' down hill grade
post #19 of 20 (permalink) Old 01-28-2013, 10:52 AM Thread Starter
1MTNCAT's Avatar
318' - Cecil*
No I meant incrementallly like Mason Dixon to check grade. Oh, and you forgot MIR & VMP.
It still all comes back to all of us running slower at Mason Dixon than anywhere else.
Steve
1MTNCAT is offline
post #20 of 20 (permalink) Old 01-28-2013, 11:21 AM
That's to much work to look at each of them incrementally. I did look at Cecil and came up with 8' as a pretty close estimate of that track's drop in elevation. I'd say the rest of them are very flat with little to no change in elevation. I just looked at the two tracks that were known to run downhill enough for it to be mentioned not only by us but by other racers as well.
You can look up MIR and VMP and let me know what they are - I never run those tracks.
Yes, we run slower at Mason Dixon but I attribute that to running in the heat of summer. Granted - as Driller said - "... any given track day, the cars see much greater elevation changes due to variable atmospheric conditions." However, running down hill doesn't hurt any either...
Looking at my own times; my average run time at Mason Dixon, with an average DA of 2079', is off of my averages for all runs at all tracks by only .359 of a second and 2.577 MPH. - Which isn't that much slower all things considered ...
