Project Resurrection - Page 12 - TCCoA Forums
 265Likes
post #331 of 359 (permalink) Old 04-24-2019, 07:37 PM
I need to throw a party again; I have a huge area near the lake we can camp at, and the hotels are cheap.
I'm still looking for a Cargo 747, lol.
MaddMartigan likes this.
Grog6 is online now
post #332 of 359 (permalink) Old 04-24-2019, 08:05 PM Thread Starter
MaddMartigan's Avatar
Crap. I bet that's your popping; it's getting unmetered air.
Is that manifold aluminum or plastic?
If it's aluminum, it'll have to be welded; if it's plastic, I'd remove the bolt, make a slightly larger 'shelf' on the runner side, epoxy it back together, and add a 1/8" shim of steel that mounts under the nut, and will catch on the edge of the lip you made, holding it down with the mounting nut.
I hope it's aluminum.
It's an aluminum intake (Trick Flow Street Heat). Honestly, I've been looking for a reason to switch to a higher RPM intake so I guess this is my opportunity. I just have to verify that the Track Heat upper will bolt to my lower. Historically it was supposed to but I've got a message out to Trick Flow and Summit.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #333 of 359 (permalink) Old 04-24-2019, 08:27 PM
Breakage is always the best time to upgrade; and someone will buy and fix that one, lowering the upgrade cost.
I have to ask, tho: I thought the one you have is best for "Overall performance" while the "Track Heat" one was for drag racing; I'd love to hear your perspective.
I know "sheet metal" intakes are XXXXRPM, +-500rpm massive power, with extreme peakage; I'm not at all informed about the trick flow ones.
And I know only really old 5.0 engines; my buddys 93 mustang is the latest one I've dealt with; and his carbed '85 eats it alive. (Even with me driving)
Of course, there's probably over 1000lbs between those cars, lol.
Grog6 is online now
post #334 of 359 (permalink) Old 04-24-2019, 08:33 PM Thread Starter
Well, in this case I'm thinking of addressing a unique problem. The Street Heat intake is good for idle to 5500 rpm and the Track Heat is good for 1500 to 6500 rpm. Because of the amount of torque the engine puts out, it can be a little tough to control with the street intake. By getting a bit more horsepower in the upper rpm range and losing just a slight bit of torque I think it will balance the car a bit more. At least that's the theory.
Yeah, I'll try to sell the old one but I doubt there are a lot of takers at this point. We'll see. I just have to verify that I can use my existing lower intake.
Grog6 likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #335 of 359 (permalink) Old 04-24-2019, 09:43 PM
Zep5.0's Avatar
That's a big change in operating RPM. Is your Cam somewhere in the middle? I'd be afraid to run that much intake of your Cam operates to a 5500 peak RPM. If you're closer to 6000 with the Cam, you might be on the right track. That being said; I'd think you're in the higher part of the operating RPM range, so if your Cam is in between, lean to the higher RPM intake.
It's always something, isn't it.
Zep5.0 is offline
post #336 of 359 (permalink) Old 04-24-2019, 10:31 PM
I don't think the cam is the controlling factor there; runner length is the big deal.
A cam does have input to that, but the airflow resonance characteristics, helmholts port stuffing, is the big deal.
You want the reflected shock wave thru the intake from the valve closing to return just as the valve is opening, as you can stuff 2x+ the amount of charge into the cylinder, if those waves are correct.
That's why that intake is so pricey.
For every cam change, the 'tuned intake' wave changes, and gets bigger; but that doesn't really change the timing of the wave.
More cam == more better, but you eventually end up with an engine that makes power at 7000rpm, but nowhere else.
And your auto tranny does not want to see 7k. Without mods.
MaddMartigan and CDsDontBurn like this.
Grog6 is online now
post #337 of 359 (permalink) Old 04-28-2019, 05:58 PM Thread Starter
I had a buddy of mine come over that has a lot of experience and knowledge with Windsor engines and he listened to my "pop" sound and determined it was probably coming from a leak in the headers that's igniting air that's getting sucked in and then burning inside the exhaust. I agreed since I am pretty sure that I have a hole larger than a pin hole in one of the primaries that I created by accident and didn't think would be a problem. Now I just need to remove the passenger side header, grind down the surface a bit and weld the hole shut. After that I should be in business to deal with the next dumbass mistake I make.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #338 of 359 (permalink) Old 04-28-2019, 06:10 PM
That sounds a lot like My process.
I'm happy you found it.
Grog6 is online now
post #339 of 359 (permalink) Old 04-28-2019, 07:17 PM Thread Starter
As soon as my buddy said that he thought it was the exhaust "burning" unmetered air/fuel I knew what was up. The sound was coming out of the tail pipe but the engine was running pretty smooth. Better this problem than something more serious.
Grog6 and CDsDontBurn like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #340 of 359 (permalink) Old 05-13-2019, 06:11 PM Thread Starter
OK, after a week and a half of bullshit and no resolution, I'm almost back to square one. My latest stupid is replacing the throttle body elbow because I was too clever by half. Measure twice, cut onc......just start drilling. Anyway, I figured I managed to create a big vacuum leak. That wasn't it either but that potential future problem from stupid is now fixed.
Anyhoo.....while attempting to start the car again, I forgot to connect the brake booster and fuel pressure vacuum hoses. The car started, ran smoothly and promptly died. I figured I flooded it and check the plugs to verify after it wouldn't start. Gave up on it that night but figured I had it fixed. Next day, still wouldn't start. I ended up wiggling the ignition control module plugs/wires and it started right up but it was back to the random *SNAP* and *POP* and *CRACK*.
I think I have a wiring issue in the ignition control wiring. I rerouted it into the passenger compartment and there is some of the wires that are folded back over themselves as a result. Some of the tires have a foil like wrap on them too. Is there a chance that I'm creating some sort of interference that's causing it to randomly fire?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #341 of 359 (permalink) Old 05-13-2019, 07:46 PM
It's possible; the wires that are shielded on my car are the cam sensor and crank sensor; probably on yours too.
Both of those signals are sensitive to edges, or transitions in the signal, not a voltage level; so this is a good place to look.
They care about When it changes, not What it is or changes to. (A TPS wants and tracks a voltage; the crank sensor wants to know when the timing mark passes.)
These voltages are from magnetic reluctance sensors, so they are tiny.(https://en.wikipedia.org/wiki/Variab...uctance_sensor)
This is a fancy name for a coil of wire, wound around a pole piece; some of the pole pieces are magnetic, some are not, and if that's not correct it won't work. I think they all have magnets now.
To check the circuitry wiring, the best way is to untape them and separate them as far as you can from each other, and everything else. Then see what happens.
You can then wiggle individual wires, and see what effect it has.
You can replace those with Coax cables, but it needs to be rugged stuff to handle the heat. And it's a pain.
Covering them with aluminum foil with a bare (ground) wire to a bolt on the chassis should reshield them as good as you can for troubleshooting purposes.
Just wrap the foil around the wire, with a piece of bare wire crumpled inside; that will work for a few days without solder or whatnot.
It will eventually corrode where the copper hits the foil and lose the grounding effect, so then you rip it out and do it again with fresh foil/wire.
I use some of this stuff, that I rescued from a dumpster after it was removed from a project: https://www.thorlabs.com/newgrouppag...tgroup_id=7902
Aluminum foil works just as good, but it's hard to solder to.
Another thing I do to sensitive electronics, is take a large heavy AC drill or side grinder that sparks a bunch, and hold it nearby, hitting the trigger, and see if it screws up when you hit the trigger; nothing causes interference than an old 15A drill sparking next to it.
Doing that may give you an easy check, and after you separate the wires, pinpoint where the problem is.
A handheld 'taser-like' device works well too.
If the ignition triggers in time to the interference, it's a pickup problem for sure.
You might also try the AM radio check.
Find an old AM battery powered radio, tune it to a blank spot, and with the car running, wave it around and see where you pick up noise. If you hear the ignition coming thru, you have a spark leak Somewhere; it will get louder the closer you are to the source.
(I use this a lot on electronic interference problems; some of my preamp prototypes have shut down all the cell phones in an area before.)
If you hear other noises, suspect the grounds; that means a fast moving signal is taking a longer path back to ground than it should.
Sticking the antenna inside the loop formed by the signal from source to ground makes that one louder.
Grog6 is online now
post #342 of 359 (permalink) Old 05-13-2019, 09:10 PM Thread Starter
More digging does indicate that this is it. There is the concern of the aluminum shielding and then there is the concern of having any of it too close to the wiring for the alternator or the alternator itself.
I think I may be on to something because I also found this: https://forums.corral.net/forums/gen...shielding.html
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #343 of 359 (permalink) Old 05-13-2019, 09:25 PM
I'd see if the local lowes or homedepot has any 18awg Shielded wire; something with a nice heavy braid.
It has to be stranded, or it will break, but for garage troubleshooting, you could use TV coax cable. IIRC, you'd need two pieces of coax to replace 1 of the wires. (2 signal wires, +ground.)
It's important the entire wire is covered with shielding, and the shield is grounded good to the signal ground, as the stock one is.
I believe those are two signal wires, covered with the mylar/aluminum foil shield, which is connected to a third pin, which is ground at the eec.
The shielding touching ground somewhere else can cause problems too, so make sure it's not touching somewhere else.
Some shields are connected at one end only, some are both ends, I'd duplicate the factory setup.
I have a couple of rolls of wire that would be perfect for that, I thinks it's alarm wire, or maybe some kind of lighting wire. The heavy braided ground is the important part.
The factory shielding is fragile, so it's not hard to mess up without massive rewiring.
If you've got a stretch without shielding, I'd start there, that's a problem for sure.
Grog6 is online now
post #344 of 359 (permalink) Old 05-13-2019, 09:36 PM Thread Starter
I think the shielding is certainly something to check but one of the things I was just reading mentioned the wiring being too close to the alternator. I just checked and my wire bundle was sitting right behind the alternator. I have relocated it so that it doesn't come near the alternator.
Here's the thing; when I relocated all of it, IIRC, the cable bundle routed across the core support to the passenger side air box area. It basically went around the world. When I relocated it I took the most direct route and that it right up against the alternator.
It's too late to test tonight but I'll give it a shot when I get home from work tomorrow evening.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #345 of 359 (permalink) Old 05-13-2019, 10:35 PM
I can see the alternator messing it up; especially if there's a loop of wire in the bundle.
The alt is a big magnet spinning around in an aluminum housing that won't shield the magnetism, so there a spinning signal generator right by your wires, probably making pulses of it's own, randomly related to the real timing signals.
Foil or braid wire shielding does nothing to magnetic fields; I've designed circuitry to go in an MR scanner, lol.
The easy check is to disconnect the alt wiring; that will take 30 seconds with a 8mm.
Stick a charger on the batt to be sure.
It should run for a while with no alt anyway, and if the problem goes away, that's the problem.
If you have a piece of 1/8" wall steel tubing to run the wires thru, that should shield it.
Grog6 is online now
post #346 of 359 (permalink) Old 05-14-2019, 04:47 AM Thread Starter
Well, like I said, I just moved the wire so that it takes a different route to get to the distributor where it doesn't pass by the alternator at all.
Grog6 likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #347 of 359 (permalink) Old 05-14-2019, 12:13 PM
I'd never considered the alternator as a source of magnetic interference; I'd bet this is it, and I'd have probably never thought of it.
I won't forget now, tho.
The fields in the alternator are a lot stronger than the fields driving the sender.
That explains why ford spent money on extra wire.
Does the 5.0 have a crank and distributor trigger, or just the distributor? IDK why it would need both...
My only question now is: did it help?
Grog6 is online now
post #348 of 359 (permalink) Old 05-14-2019, 12:23 PM Thread Starter
It's just a distributor.
I'll find out tonight.
Grog6 likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #349 of 359 (permalink) Old 05-14-2019, 06:16 PM Thread Starter
Boo!
Same problem.
I have some heavy duty aluminum tape so I guess I'll try that next.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #350 of 359 (permalink) Old 05-14-2019, 09:01 PM Thread Starter
So, it must be a wiring issue. I took apart the "bundle" for the ignition control module to the distributor/coil and ECM. The foil is generally intact and it appears that Ford just put a bare ground wire in place and then wrapped it with foil tape. I had a part of it that was a bit messed up so I wrapped it in some aluminum tape that I have.
Looking through my schematics, it appears that the tachometer connection sits on the other end of a resistor where T/Y is converted to W/PK. I guess I need to track that all down and figure out the right way to wire in the tachometer.
I was incorrect about the wire routing across the front of the engine. What it did was route the power for the ignition (R/LG) across the core support to the PCM relay and a fuse in the fuse box under the hood. That's a constant power feed versus a switched power feed. I honestly I don't know if I had that wired up correctly really because I had the standalone R/LG wired to my switched fuse box instead.
Dammit. It's late so I'm going to bed.
Grog6 likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #351 of 359 (permalink) Old 06-22-2019, 12:48 PM Thread Starter
Well, it's not perfect and I still have some problems but it does move with a little coaxing.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #352 of 359 (permalink) Old 06-22-2019, 04:23 PM
quickford's Avatar
Sweet!
It's like they say...the first step to getting it perfect, is to get it good enough. Someone's probably said that before, right?
Current poor life choices: 1991 Mercury Cougar XR7, 1998 Lincoln Town Car, 2005 Ford Focus ST, 1997 Ford Probe GT.
Previously: 2015 Focus, 1996 Thunderbird, 1998 Taurus, 1989 Escort.
quickford is offline
post #353 of 359 (permalink) Old 06-23-2019, 12:31 PM
Like a Phoenix from the ashes!
Fantastic!
MaddMartigan and Grog6 like this.
post #354 of 359 (permalink) Old 06-24-2019, 02:47 PM
Have you went out and annoyed the neighbors yet?
It's looking good!
It needs a TCCoA sticker, tho.
Grog6 is online now
post #355 of 359 (permalink) Old 06-24-2019, 04:16 PM Thread Starter
It's looking good!
I'm sure that my trip up and down the block did annoy them. It annoyed me too. The car is too loud, the steering is really difficult, the brakes are too mushy and the car backfires too much.
Just a few things to fix.
Is there even such a thing as a TCCoA sticker anymore?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #356 of 359 (permalink) Old 06-24-2019, 04:24 PM
The car looks sick! I love the look of a titanium bird with a black hood. Only suggestion would be to paint the body side moulding piece on rear bumper body color, since the front is already painted and the side mouldings are already gone. As for the TCCoA sticker, send a PM to ClintD. He makes custom decals, and I'm sure he can make one for you.
post #357 of 359 (permalink) Old 06-24-2019, 04:33 PM
I have a stack of the ~4x6 ones that Michelle sent me WBW; PM me your addy, and I'll mail you a couple. They last about 10 years before fading.
ClintD makes them out of vinyl, much nicer than what I've got; these are just white lettering on clear.
I think I still have a few of the Lorain Assembly Plant stickers B made.
I still have an unused "DirtyDog Performance" windshield banner too.
Grog6 is online now
post #358 of 359 (permalink) Old 06-24-2019, 06:35 PM Thread Starter
Thanks. It was just dumb luck to get one this color. I much prefer it to Mocha Metallic or as it's also known; High Performance Tan.
I'll look into painting those parts at some point. I need to work through my other challenges first. We won't get into the fact that the 15W50 came out of the oil pan like water because of how fuel soaked it was. I'm hoping that since I didn't ever drive the car with it like that nor did I even get the engine completely warm and it's not smoking that no real damage was done.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #359 of 359 (permalink) Old 06-24-2019, 08:34 PM
I seriously think you should paint the headlights with yellow metalcast It’s almost perfect as is though, I liked your old tan bird at the end and I liked this bird from the old days with quick35th, it’s so great to see them combined!
