Project Resurrection - Page 9 - TCCoA Forums
 226Likes
post #241 of 325 (permalink) Old 04-02-2019, 09:38 AM
Looks great! What amazing work you put into that resurrection. Shoot a video of the startup! I'd like to hear it run.
Thanks.
post #242 of 325 (permalink) Old 04-02-2019, 11:21 AM
Thanks.
For that matter, so would I!
Fuelly
RalphP is offline
post #243 of 325 (permalink) Old 04-02-2019, 06:28 PM Thread Starter
MaddMartigan's Avatar
Fuel pressure test today revealed that I didn't installed the O rings on the fittings for my Aeromotive fuel pressure regulator. So, after some cussing and realizing that it's a pretty tight area, I got my gorilla hands in there and pulled the regulator and installed the O rings on the fittings. Now I have a 40psi of fuel goodness at the regulator with key on. Tomorrow night is the night I attempt to start it.
I've attached two pics; one is the very first engine compartment pic and the other one is from tonight. There is a bit of a difference for sure.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #244 of 325 (permalink) Old 04-02-2019, 09:06 PM
Nice... A lot of work into that hole.
MaddMartigan likes this.
post #245 of 325 (permalink) Old 04-03-2019, 11:11 AM
I love before/afters, you went a long way in a really short time
MaddMartigan and Grog6 like this.
post #246 of 325 (permalink) Old 04-03-2019, 07:34 PM Thread Starter
Well, it's a swing and miss. I tried to start it and it's a no go. I verified that I'm getting fuel pressure and spark. I have a Noid set for the fuel injectors and I am not getting a pulse on the fuel injectors. I checked the throttle position sensor and I am getting voltage through the range (~.1v to ~.97v). I'm not exactly sure where to go from here but between you guys and my other abilities to research things I hope to find it. I do have a ODB-I code scanner so I can try that too.
On another sour note, my clutch is not fully disengaging when I press the clutch pedal in which I learned when trying to start it. I guess I need to bleed the clutch again too.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #247 of 325 (permalink) Old 04-03-2019, 09:28 PM
The injectors all have a common power feed from the EEC relay, and then they are ground side controlled by the computer. Check to see if you have key on power on the red wires going to the injectors. If you don't then you will have to trace that back. If you do have power, but the computer is not firing the injectors, then either the computer is seeing a WOT signal from the TPS, or the computer is fried, but I suspect more likely you will find no power going to the injectors, especially since you pared down the harness, maybe something got put back in the wrong pin on one side or something like that.
post #248 of 325 (permalink) Old 04-03-2019, 09:33 PM Thread Starter
Yeah, that sounds about right. I had done some other reading and that lines up. Thanks for confirming the first suspicion.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #249 of 325 (permalink) Old 04-04-2019, 01:34 PM
It's scary when the Mad and Madd scientists put their heads together!
MaddMartigan and CDsDontBurn like this.
post #250 of 325 (permalink) Old 04-04-2019, 06:20 PM Thread Starter
Progress is made. The 12V power wire that powered the part of the harness that ran the fuel injectors among other things was mismatched at the bulkhead harness. I guess I was just drunk on several of those days.
The good news is that I am getting 12v power at the injectors now. When I try to the car it does act like it wants to start occasionally. The bad news is that it still doesn't start. I have verified that I'm getting spark. I now know that I'm getting fuel. The strange thing is that occasionally the engine diesels after stopping the start for a very short bit and only occasionally.
Before I jump into the PITA OBD-I code scanner, does anyone have some thoughts?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #251 of 325 (permalink) Old 04-04-2019, 08:01 PM
What fuel is in it? Did you purge the lines after cleaning out the tank? Change the in-line fuel filter?
Just grasping at straws but sometimes it's something simple ...
Is the octane adequate? I'd be concerned about dieseling.
post #252 of 325 (permalink) Old 04-04-2019, 08:10 PM
Is the tune and everything on the motor the same as it was installed in the other car? Try unplugging the MAF to see if it makes it any better or worse. Look for a massive vacuum leak, like the PCV line or brake booster line unplugged, as that could throw the air/fuel ratio off enough to prevent it from starting.
post #253 of 325 (permalink) Old 04-04-2019, 08:10 PM Thread Starter
  • 93 Octane Fuel
  • Brand new lines from the tank to the FPR and rails
  • Brand New Fuel Filter
  • Octane is adequate
  • No fuel leaks now either
I'm sure that it's some else dumb.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #254 of 325 (permalink) Old 04-04-2019, 08:12 PM Thread Starter
It's the same ECM that ran the car when I removed it. Same chip in it as well. I don't think I have a massive vacuum leak but I can look. I did notice that if I open the throttle wide open when trying start it that it behaves slightly different.
I'll give unplugging the MAF a try. What do you think of removing the SPOUT to see if it's a distributor issue (I read that somewhere)?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #255 of 325 (permalink) Old 04-04-2019, 08:33 PM
Zep5.0's Avatar
I'm sure you've already checked, but it almost sounds like the distributor is 180* off ( TDC exhaust)
Zep5.0 is offline
post #256 of 325 (permalink) Old 04-04-2019, 08:38 PM Thread Starter
OK, I plugged in my code scanner and pulled the codes. For completeness, I'll list everything it spit out in order:
511 No power to PCM pin 1 or bad PCM (processor) I have this connected straight to the battery circuit with a fuse. I *might* have it miswired. I'll check tomorrow.
122 TP low (possibly grounded or open circuit) – TPS No idea. I put in a new connector and it's wired exactly like the original. I checked this and the sensor is showing the full range of voltage as expected.
564 Fan Control (FC) circuit failure – A/C and Fan Circuits Expected
563 High Fan Control (HFC) circuit failure – A/C and Fan Circuits Expected
565 Canister Purge 1 solenoid/circuit failure – Solenoids Expected
511 No power to PCM pin 1 or bad PCM (processor) See above, it's a repeat but this may be significant.
122 TP low (possibly grounded or open circuit) – TPS See above, it's a repeat but this may be significant.
564 Fan Control (FC) circuit failure – A/C and Fan Circuits See above, it's a repeat but this may be significant.
563 High Fan Control (HFC) circuit failure – A/C and Fan Circuits See above, it's a repeat but this may be significant.
565 Canister Purge 1 solenoid/circuit failure – Solenoids See above, it's a repeat but this may be significant.
10 Spacer Code? No idea here.
512 Memory power (PCM pin 1) was interrupted – Was battery disconnected ? See code 511. This may be common based on my circuit wiring.
Could 511 be the one that doesn't allow the car to run? I know 122 could certainly do it but I don't think I have that wrong.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #257 of 325 (permalink) Old 04-04-2019, 08:39 PM Thread Starter
Definitely already checked. I've heard that backfire and it requires a change of clothes on this high compression engine.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #258 of 325 (permalink) Old 04-04-2019, 08:45 PM
Cam timing?
Edit: Ah, I have no idea. You've clearly got more experience troubleshooting these things than I do. Fugetaboutit.
post #259 of 325 (permalink) Old 04-04-2019, 08:52 PM Thread Starter
Cam timing?
This is a pushrod engine. If my cam timing is off then I'm totally fucked. That's OK though. I feel good about that one. It's definitely something the wiring.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #260 of 325 (permalink) Old 04-05-2019, 09:30 AM Thread Starter
More consideration has been given.
I'm thinking bad TPS. I'll definitely check it tonight but it seems logical. I had this problem when I first built the engine 15+ years ago. That troubleshooting took a lot longer but now I have experience and people/information on my side.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #261 of 325 (permalink) Old 04-05-2019, 03:26 PM
Sounds like it's a wiring issue to me; maybe a fuse.
The eec sends regulated 5V power to all these sensors that ain't working, just so they don't vary with the battery voltage, pretty much.
So that's why they don't work, I'd bet, no eec power, no sensors.
The TPS should be +5V, some voltage, and ground, if you don't have that, that's the deal. It's there Key On, if it's working right.
I'm pretty sure all the sensors are that way, that aren't controlled by the eec. (like the O2's would be)
I'd check connector ends First, to see if there's a pin that doesn't have a mate; that's easy to do, move one to the wrong spot.
You'll find it as the last thing you look at, unfortunately; when you find it, it'll fix it all, probably.
Something like this helps as a troubleshooting aid:
They're little voltmeters, ~$12 on amazon for 5 of them.
They measure whatever is on those two wires, and don't work under about 2.5V, so you can see easily when somethings dead.
I wrap them in tape, put a magnet on and more tape, and add ~4' of wire and some clips.
You can make a crib sheet that says RED=main, Blue=pump... and be able to just look around and see what it doing, while you're tracing.
Wire piercing probes for a voltmeter work, BUT: after you are thru, you have to rub RTV into any insulation holes you made. That keeps it from rusting in there.
And don't pierce it near the connectors, stay 4" back if possible.
If you think the timing is wrong, use an old school timing light, and check it vs the TDC mark. (You will want to verify TDC IF you think it's possibly off.)
That's about All a timing light is good for now, lol.
BTW: If you think it's 180 out, please don't tow it to speed, drop the clutch, and try to set the distributor while it's turning over. While tied in to the front of the vehicle, so you can't fall off. That never works. (that happened... I put him out with a powder fire extinguisher. That was a 5.0 cougar, 76 or so. )
post #262 of 325 (permalink) Old 04-05-2019, 06:18 PM Thread Starter
I'm generally with you but as I take the time away from the car to think about it and research it I come back to the to find that:
  • TPS Reference Voltage measures at 5v
  • TPS signal voltage range is from about .3v to .96v
  • Pin 1 on the ECM is 12v so the code that there is no power to pin 1/ECM is bad may just mean that the ECM is bad
The car still won't start however. I am actually using the ECM that was in the during the crash and it did have a dented cover since it was on the side that took the hit. The car ran with that ECM when I pulled the engine. However, that doesn't preclude a bad ECM.
I definitely follow about all of the signal voltages but that line has proven to be consistently good. Little voltmeters on all of the sensors seems like a neat idea but I'm going to hold off for now.
I've referred to my EVTM and so far I'm seeing everything I expect to see.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #263 of 325 (permalink) Old 04-05-2019, 06:59 PM
If you have the voltage on the pin, and it says no voltage, I'd suspect a spread contact, or a cracked solder joint in the eec.
Depending on skills, you might fix it with a pick tool or soldering iron. Or not, depending.
I'd want a spare, even if I fixed one, tho.
I have a spare eec I'd loan you, but it's eec-V for a 4.6l; not exactly helpful.
What about grounds? You can measure the outside of the eec to get an idea of its ground; more than .5 v is a problem.
Always reference ground measurements to the battery terminal; it's all downhill from there.
Loads make a difference; it can measure 12v just fine until you hit the starter. I'm sure you've been there before.
That's when I switch to mixed-mode cursing, alternating Egyptian with ancient Portuguese for effect; unintelligible to most humans, it will however blister paint at up to 40 paces.
post #264 of 325 (permalink) Old 04-05-2019, 08:47 PM Thread Starter
I actually have another ECM that I can use with the same catch code (T4M0). I can validate that tomorrow.
Well, I didn't scrimp on grounds. Since the battery is remote, it's grounded to the body. All of the grounds for the wiring inside the car are grounded at a common point that is a reliable ground (as evidenced by all of those things working properly). The fuse box under the hood also has a ground terminal group on it and I have it grounded to the body too. I generally feel good about the grounding system.
I'm feeling more and more like this might be a case of a bad ECM. It did take a pretty direct hit so it could be that.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #265 of 325 (permalink) Old 04-06-2019, 11:31 AM Thread Starter
Change ECM with same results. Same codes still no start.
On a side note, when you turn on the key, the fuel pressure should build from the pump and hold. How long should it hold? I may have a stuck fuel injector.
On a side note; I did not connect pin 30 on the ECM (R/LB) that connects to the start/run circuit and is listed as the Neutral Position sensor. Did I make a mistake not connecting it?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #266 of 325 (permalink) Old 04-06-2019, 01:12 PM
I just looked up the connector view, for a 95 Mustang GT, and it lists pin 30 as the transmission range sensor for automatic trans only. Since I believe you are using a 5-speed ECM, that pin wouldn't have had anything on it from the factory, and either way, that wouldn't stop it from starting.
post #267 of 325 (permalink) Old 04-06-2019, 03:05 PM Thread Starter
OK, that makes sense then. Yeah, I'm using a 5 speed ECM (94-95 SN95 T4M0 ECM) so I didn't think I needed it but since PNP will keep an automatic from starting I wanted to make sure I didn't miss something.
I'm running out of ideas. Any thoughts on the fuel pressure bleeding off fast? I feel like it's a stuck injector. The bright side is that those injectors are stupid cheap now.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #268 of 325 (permalink) Old 04-06-2019, 04:11 PM
That will keep it from cranking only. If yours is cranking, which I assume it is since you were checking for injector pulse, then you are past that. A stuck injector is a possibility, as is a bad fuel pressure regulator. Start by crimping off the return line to see if the pressure still drops. If it stays high with the return line crimped, then suspect a bad regulator. If it still bleeds down with the return line crimped, then a sticking injector would be the next guess. In that case, I would say crank it over, then pull the spark plugs and see if one is wet. If it is, then that is your sticking injector.
post #269 of 325 (permalink) Old 04-06-2019, 04:37 PM Thread Starter
OK, that all makes sense. Sometimes I just have to do a sanity check.
I've attached a video of the start attempt.
https://youtu.be/kp1gTsraI3Y
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #270 of 325 (permalink) Old 04-06-2019, 05:01 PM
It sounds like the timing isn't right.
Also, that's a 10:1 engine, and it doesn't sound especially hard to turn over; maybe your starter kicks ass, tho.
Is there a crank trigger on those, or is it all ran off the distributor?
What syncs the injectors and ignition? Check that feed.
