Project Resurrection - TCCoA Forums
 249Likes
post #1 of 350 (permalink) Old 06-09-2018, 09:15 PM Thread Starter
MaddMartigan's Avatar
So, I have the next chapter in my silly saga now sitting in my garage. It is amazing how easy stuff becomes once you do it often enough. I had to go pick it up today and it didn't have any wheels, knuckles/spindles or suspension. We added enough to get it up on the trailer to get it home and I have all of those items back off and I also have the rear subframe and suspension removed.
I'll try to take pictures as I go. I will pretty much have to transfer everything I have from the old wrecked car as well as I'll have to install brand new stuff like brake lines (ALL brake lines) and fuel lines. I'll even need to transfer all electrical components. It's going to be a lot of work.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 350 (permalink) Old 06-10-2018, 04:23 AM
Good luck with the project Randy!
Was it a race car? I see a cage in there.
post #3 of 350 (permalink) Old 06-10-2018, 05:59 AM Thread Starter
Thanks. Yeah, it was used prior for some road racing. It was formerly another member's car from long ago.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #4 of 350 (permalink) Old 06-10-2018, 08:58 AM
I always wondered what happened to that car!
MadMikeyL is online now
post #5 of 350 (permalink) Old 06-10-2018, 09:54 AM Thread Starter
It's been hiding in a garage since 2012 apparently. I will literally have to take care of almost every single system in the car to get it going again. It doesn't even have any viable brake lines or any braking system. There is no wiring to speak of. There is a lot to do.
On a side note, since I have a plasma cutter now, I'm thinking of taking care of a few things. Since the car has a full cage, there are some items that I really want to remove. The first is a panel to access the fuel pump. The second is the spare tire well.
Any thoughts on removing the spare tire well?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #6 of 350 (permalink) Old 06-10-2018, 10:04 AM
It never seemed worth the effort to me, unless you were putting a fuel cell in its place. You won’t be saving much weight, and even what you do save is being taken from the worst possible place as far as trying to keep your weight distribution as even as possible. I also am not a fan of the access panel for the fuel pump. If you put a good fuel pump in, you should never have to mess with it again, and even if you do, you can get the pump in and out by just lowering the tank some, you don’t even have to disconnect the filler pipe or anything, so I would rather just do that.
post #7 of 350 (permalink) Old 06-10-2018, 10:52 AM
dDUBb's Avatar
LOL that's for sure. Good luck on the project, it looks like a fun fresh start.
Ive always been hesitant to take a plasma to these cars, so much undercoating, seam sealer and grease that it catches on fire quickly.
dDUBb is offline
post #8 of 350 (permalink) Old 06-10-2018, 11:15 AM
Did it come with a second set of doors? I was looking at pictures of that car in its heyday and it had the frames lopped off above the side mirrors with the window assemblies gutted out. Those doors are obviously in tact
I mentioned this to you in IRC, but until you resurrected your bird in earnest a few years ago I had always thought the original bird in your avatar was silver. The effect of the white hood on the beige body in such a low res form I guess. So you snapping up a silver car seems very meant to be, doubly so finding a shell with a road racing history.
I second Mike on the pump hole and tire well
post #9 of 350 (permalink) Old 06-10-2018, 11:29 AM Thread Starter
I think that if there were to be a street driven car then I would totally agree. Since it's just for track use and I really hate to drop the exhaust to drop the tank it's something I really want to do just to get it out of the way. It's a major pain to go back and do it so I figure I'm going to get it out of the way.
The spare tire well is a similar scenario. IF I ever plan to do a fuel cell, it's just one more thing that's out of the way that I don't have to do a bunch of disassembly to other parts to get it done. Again, the car is stripped so now is really the time to knock out some of these things.
This car is the infamous Mansier car so it's pretty much (I said pretty much) stripped of most of those inconvenient things.
He did have a second set of doors. He wanted to keep the skins for sentimental value and since they were just too bare bones for my taste I was all for it. There is actually a lot of sentimental value in this car for the former owner. I'll do my best to make it work well. Yeah, a silver bird really does seem meant to be based on how much I came to hate the color of our original bird.
Yeah, yeah, yeah. I know both of your position on that.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #10 of 350 (permalink) Old 06-10-2018, 02:57 PM Thread Starter
Things on the disassembly side for the donor are happening quickly. Other than the stumble on having an almost full gas tank to drain, the rest of it went pretty fast. Dropping the entire rear end out in one piece was very nice. I'll have some parts to sell for sure.
CDsDontBurn, KEVIN8989 and dDUBb like this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #11 of 350 (permalink) Old 06-12-2018, 01:55 AM
KEVIN8989's Avatar
Hey that one looks alot like my 92 SC. I wonder what engine you'll put in that one. I dont know how you can take the car apart that fast, thats amazing!
KEVIN8989 is offline
post #12 of 350 (permalink) Old 06-12-2018, 04:58 AM Thread Starter
It's a 92 SC so if yours is silver then they are definitely twins. In fairness the starting point for me wasn't too far from that. The car was set up for racing so it was pretty stripped down.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #13 of 350 (permalink) Old 06-12-2018, 05:04 AM Thread Starter
Progress is being made on the effort. I got to use the new plasma cutter on the old car last night since my plan is to remove the entire core support so that I can remove it from the old car for future purpose. I also removed the passenger door from the old car since I want easier access to work inside it.
The family joined in on cleaning up the "new" one. It had a lot of stickers on it and the doors were pretty filthy from where they were being stored. It's cleaning up pretty nice.
Mikey97D likes this.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #14 of 350 (permalink) Old 06-12-2018, 10:58 AM
dDUBb's Avatar
I remember the build on that car back on the SCCOA - that was about 10 years ago now. Always wondered what happened to that car and now I know.
- Dan
dDUBb is offline
post #15 of 350 (permalink) Old 06-12-2018, 08:49 PM Thread Starter
More progress on the tear down. I've decided I want to keep the core support and consider transferring it to the "new" car.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #16 of 350 (permalink) Old 06-13-2018, 05:51 AM
That's what I felt like when I redid the vapor canister lines, lol.
You know, even with that much stuff off, the front swaybar Still looks like a pain to swap...
MaddMartigan likes this.
Grog6 is online now
post #17 of 350 (permalink) Old 06-13-2018, 01:20 PM
S4gunn's Avatar
I've cut the spare tire well... with an angle grinder.
- It makes exhaust routing easier and there's a lot more room to access the pumpkin but since i replaced some aluminum cutter flashing with a single thin steel sheet that I screwed down, I suspect weight savings would be pretty minimal (definitely <10LB).
- NVH obviously increases. You'll smell more exhaust too while idling or not at speed.
In your situation, I'd probably leave it UNLESS you always found that area cramped to work in OR decide to install a fuel cell.
Having more metal back there to deform in case you get rear ended is nice, too. More energy would get absorbed there instead of in your frame rails OR (worst case scenario) your cage's rear stays.
http://goo.gl/csaet4
S4gunn is offline
post #18 of 350 (permalink) Old 06-13-2018, 01:23 PM
S4gunn's Avatar
Nows a good time to strip out excess wiring in your harnesses.
If you don't need it, cut it out (or back to the main chassis plug) before swapping it over to the new chassis.
It's easier as you pull the harness out than when the harness is still on the car and the dash plug is up in the dash.
S4gunn is offline
post #19 of 350 (permalink) Old 06-13-2018, 02:16 PM Thread Starter
I'm probably going to remove the spare tire well anyway now that I've had time to think about it. I don't have immediate plans for a fuel cell but if/when I do decide to do it I don't have want to have to tear apart the rear end to make the cut. As for reinforcement, I can always weld in some square tubing between the frame rails to provide some added strength without compromising the space.
I absolutely plan to trim down the wiring harness. The new car has nothing at all in it so I have to work through all of this stuff. Matt has volunteered to guide me and I'm sure I'll use all of you guys to help me navigate it. I think one of my biggest challenges is that I have 25 year old connectors so I'll have to figure that out for sure since so many are breaking.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #20 of 350 (permalink) Old 06-13-2018, 02:44 PM
S4gunn's Avatar
Since you still have the harness on the donor car, it doesn't take much thinking. Just find an endpoint connector (like the dome light or say the rear speakers), and trace the wires back to another connector. Cut it there.
Once you've done that, you may find that you have some connectors that have no wires going to it. Trace THOSE back to the power junction box or circular harness plug or whatever and cut them off at the plug.
If you really want to get OCD, I saved all of my wires (and coiled the up) for future wiring projects. This has come in handy as I now have plenty of different colored wire in 12" to several feet lengths.
-g
S4gunn is offline
post #21 of 350 (permalink) Old 06-13-2018, 03:04 PM Thread Starter
-g
That's a good point. My plan right now is to strip the entire wiring system from the car and use it as I need it in the new car. I will just store what's left over and keep it for when I need it.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #22 of 350 (permalink) Old 06-13-2018, 03:35 PM
dDUBb's Avatar
Yeah that stuff is easy, no problem there. Its not going to be a whole lot of weight if you've already stripped the components they feed but its nice to clear up the clutter and save a couple pounds at the same time.
-g
LOL … wow, now that's OCD at its finest. I save my wires also, all coiled up - ready for the recycle yard. I realized at some point, theres always plenty more where that came from and im never going to get the color / stripe I want for a car project in the length I want anyways so fuck it.
dDUBb is offline
post #23 of 350 (permalink) Old 06-13-2018, 04:04 PM
S4gunn's Avatar
My suggestion is that if you do the harness pruning (or at least tag them for pruning) while the harness is ON the car, it'll be a lot easier than trying to ID a specific plug when the whole harness is on your work bench.
After all, you'll know that Plug XXXX that is on the ceiling in the center of the car was for the dome light. Ditto with speakers, etc.
S4gunn is offline
post #24 of 350 (permalink) Old 06-13-2018, 08:34 PM Thread Starter
Plasma cutters are really awesome. Also, a little more progress on disassembly.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #25 of 350 (permalink) Old 06-13-2018, 09:29 PM
gordonm1's Avatar
I'm looking forward to pics of mustangs and chevy's you beat but it may be a little early to hold my breath. Soldier on...
gordonm1 is offline
post #26 of 350 (permalink) Old 06-17-2018, 08:16 PM Thread Starter
I've made some progress. Almost ready to pull the engine. The temps have been hovering around the low 90's this weekend so it's somewhat slow going.
I made a car dolly to put the old car on once I get to the point of removing it's suspension and making it mobile. It will rest on jack stands while I disassemble it but once that's done I need to be able to get it out of the garage onto a truck/trailer. In the mean time I used it to do a 180 with the "new" car.
Pics attached.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #27 of 350 (permalink) Old 06-23-2018, 03:41 PM Thread Starter
I've been busy. The engine is pulled. We had to remove the K member in order to get it out because of the 7qt. oil pan. I also removed the core support from the other car and did a test fit of the donor core support. It worked like a charm. Now I have to work on brake lines and electrical. Lots to do before I can move everything over.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #28 of 350 (permalink) Old 06-23-2018, 03:57 PM
Looks awesome!
Which core tag are you going to put back, if at all?
Grog6 is online now
post #29 of 350 (permalink) Old 06-23-2018, 04:53 PM Thread Starter
Looks awesome!
I don't think I have the core tags for either one actually.
post #30 of 350 (permalink) Old 06-23-2018, 05:27 PM
Wile E. Coyote Jr.'s Avatar
So thats where the beauty went. Thats awesome man, hopefully you get a good amount of years out of it. Its a shame about your other one, but atleast you have a chassis like that to rebuild off of.
MaddMartigan and Grog6 like this.
Stacy: 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Ellie: 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Wile E. Coyote Jr. is offline
