88-96 PBR Corvette big brakes - TCCoA Forums
post #1 of 26 (permalink) Old 03-10-2008, 06:02 PM Thread Starter
Set up:
88-96 PBR Corvette caliper and brackets
88-96 Corvette brake pads
13" Cobra rotors (drilled to 4.25 bolt pattern)
Have to have 17" or higher rims
Modify:
Open the spindle to bracket holes a couple millimeters (used a round file) so that the new bracket bolts will fit.
You need to buy new bracket bolts, you can't use the GM supplied Corvette bolts because they are too long. Metric hex bolts, steel grade 14mm x 2.0 (do not use cheapo bolts).
On the passengers side you will have to remove the brake line and grind one side of the Banjo block down so both sides match before it will fit on the caliper.
Banjo bolts and crush washers from the Mustang Cobra or Corvette on your stock brake hoses.
See link for more info and pictures:
http://www.mn12performance.com/mn12h...ke_upgrade.htm
post #2 of 26 (permalink) Old 03-10-2008, 07:47 PM
I'm a little confused. What's the advantage of doing this over the mustang twin-piston PBRs on 13" rotors? It seems like the same exact work for either one. Are the corvette parts cheaper than the mustang ones or something?
MadMikeyL is online now
post #3 of 26 (permalink) Old 03-10-2008, 08:44 PM
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
I amd wondering the same thing. The parts look identical.
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #4 of 26 (permalink) Old 03-10-2008, 09:15 PM
1995 cougar xr7's Avatar
what kind of bolts are those, they don't look grade 8
1995 cougar xr7 is online now
post #5 of 26 (permalink) Old 03-10-2008, 10:24 PM Thread Starter
Zero
Yes basically the same thing, a lot of guys didn't know that the 88-96 Corvette calipers are the same. So if you can get a hold of a pair cheaper then the Cobra then it's all gravy. I got my pair for only $40 on ebay when all the Cobras where going for $100++ more for used crapy ones.
Those are cheapo bolts, I do not have them on my car anymore, I have "Grade-A" steel bolts in place now.
post #6 of 26 (permalink) Old 03-10-2008, 11:37 PM
So how much did the 13" brake upgrade cost you with everything?
post #7 of 26 (permalink) Old 03-11-2008, 12:07 AM Thread Starter
Calipers-brackets $40
Rotors $120
Bracket bolts $5
pads $90
Ed conversion kit with hub rings $100
Rotors drilled $10
Banjo bolts and crush washers $25?
Caliper pins with "C" clips $5
Around $400 after parts were shipped
post #8 of 26 (permalink) Old 03-11-2008, 12:41 AM
Do you order pads for a corvette or a mustang cobra? Or does it not matter?
post #9 of 26 (permalink) Old 03-11-2008, 01:08 AM Thread Starter
Doesn't matter same thing
post #10 of 26 (permalink) Old 03-11-2008, 01:27 AM
Do you know the size on the hub-centric rings? Sorry to be asking so many questions, but suddenly the 13" brake swap looks a lot more do-able, so I just want to get all the info I can.
post #11 of 26 (permalink) Old 03-11-2008, 01:30 AM Thread Starter
Don't worry about it, you can get a set from Ed...
http://forums.tccoa.com/showthread.php?t=37231
post #12 of 26 (permalink) Old 03-11-2008, 09:14 AM
Cool, thanks for documenting that, I have one or two other vehicles that I want to do big brakes on, and I can substitute those if need be.
BTW I got my 10th anniversary calipers from a Ford/Motorcraft/FRPP seller online on a forum for 164 bucks a set, the black Mach I ones were even cheaper. I decided to go new. I wish I could find someone to drill mine for 10 bucks, they want 150 for the four to drill, I don't know if I want to risk doing it myself on brand new FRPP drilled and slotted rotors or not. I didn't get them from the person that sold parts here at the time, he didn't have them in stock, but hos price was close to the same, and I would have bought them from him since I had good dealings with him before.
Bangster is offline
post #13 of 26 (permalink) Old 03-11-2008, 09:52 AM
rbrown's Avatar
I bet this guy might be able to cut those holes cheaper.
http://www.geocities.com/stus_cobra/irs_machining.html
rbrown is offline
post #14 of 26 (permalink) Old 03-11-2008, 10:18 PM Thread Starter
I had them done at a local machine shop.
post #15 of 26 (permalink) Old 03-27-2008, 08:19 AM
nall_one's Avatar
Smile weird...
so are they after market parts that Ford and Chevy decided to buy for the mustang and corvette. cuz I'm surprised a Chevy part would even be even close to the same as a ford.... AND sorry but i just have to say.... BLASPHEMY!!!!!!! maybe I'm just an old fashion ford fan but the thought of these Chevy engineered parts being the only thing keeping my car from slamming into the car ahead of me at a stop, kind of disturbing.
nall_one is offline
post #16 of 26 (permalink) Old 03-27-2008, 11:49 PM Thread Starter
Yes Corvette and Mustang used the same PBR twin caliper.
I'd rather have a "Domestic" part on my car then a import.
post #17 of 26 (permalink) Old 03-27-2008, 11:56 PM
well, if i could do a direct swap from an import car with brembos cheap i'd say goodbye to my domestic vs. import ethics
post #18 of 26 (permalink) Old 03-28-2008, 12:19 AM
cross breeding= ewww!!
i hate those foxybody stangs with the crate chevy 350.. if you cant rely on the original manufacturer to give you what you want there is no need to have ANYTHING of that brand.. just my 0.2
stickysilvertbird is offline
post #19 of 26 (permalink) Old 03-28-2008, 01:55 PM
PCD
Confirmed V6 Nut
Are these calipers different than my 2000 Mustang GT PBRs?
PCD is offline
post #20 of 26 (permalink) Old 03-28-2008, 01:58 PM
Yes they are. The GT calipers work with 11" rotors, these work with 13".
post #21 of 26 (permalink) Old 03-31-2008, 12:38 AM
TCCoA Founder
Sir William's Avatar
Uhhh....guys....PBR is an Australian company. So they're ALL imports....kinda! Deal with it.
PBR does have manufacturing facilities in Detroit, Knoxville and Columbia, SC. So they're all made here, but the parent company is from down under.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #22 of 26 (permalink) Old 03-31-2008, 01:38 AM Thread Starter
I try to buy products that are made in the USA, I'm sure, but not 100% that the Corvette and Mustang PBR calipers where made at one of the manufacturing facilities in the USA. I'm all about supporting the home team. But That's fine, I like them, haven't had any problems, good product. I made this thread solely to say, "They fit on our car!" I'm sure a lot guys on here didn't even know that they where an option. If anyone is trying to have these calipers put on there car and have any questions at all feel free to send a PM and I will help you as best I can.
Take care,
post #23 of 26 (permalink) Old 03-31-2008, 09:32 AM
fast Ed's Avatar
Those were likely made in Australia where PBR is based. I'm not sure if they have any manufacturing facilities in North America or not.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #24 of 26 (permalink) Old 04-02-2008, 07:58 AM
96sport's Avatar
Take care,
Ditto on the American made Oxman.
Thanks for taking the time to let us all know what works on our Ohio made cars.
I'll put this one on my "new" 96.
Straightaways are for fast cars
Turns are for fast drivers
96sport is offline
post #25 of 26 (permalink) Old 01-26-2016, 03:55 PM
Looking calipers for 13" rotors and find for HD brakes and for base covette C4. It's the same calipers for 13" rotors or must buy HD brakes?
gruchol is offline
post #26 of 26 (permalink) Old 01-26-2016, 03:57 PM
It's probably way easier now a days to just get Mach 1/Cobra Calipers
