Replacing the Regulator on a 94-97 Alternator - TCCoA Forums
post #1 of 7 (permalink) Old 12-07-2005, 11:41 PM Thread Starter
Whining Intakes Rock
Al_Florida's Avatar
I figure the 96-97 alternator is the same as the 94. If not, let me know.
Tools needed:
flat screwdriver
T20 Torx bit
15mm socket and 10mm socket to remove Alternator (need to verify)
Regulator available at any decent alternator shop. Roughly $20 bucks.
Remove Alternator from your car.
Regulator that has seen better days.
First, remove these two screws
These two screws connect to the brush holder. The brushes are spring-loaded but there's no danger of it springing out. Just so you know it's there. When you reassemble these, the screw holes will not line up perfectly.
Remove these 4 torx screws with a T20 torx bit.
Old regulator vs new one. The old one just fell apart.
New regulator installed
Cleaned up and ready to go back on the car
This article demonstrates what I have done to modify my alternator in my car. Neither I nor TCCoA assume any responsibility if you use this article to try to modify your own car. You do so at your own risk.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #2 of 7 (permalink) Old 12-14-2005, 10:53 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
how did you keep the brush assembly in place when you removed the regulator? once you remove the regulator, if you push the brushes into the spring holes, you can put a paperclip through the hole and through the regulator hole too, then when you reassemble, pull out the paper clip and the brushes will go back in place.
-Thomas
Thomas is offline
post #3 of 7 (permalink) Old 12-14-2005, 11:48 PM Thread Starter
Al_Florida's Avatar
They moved a bit but I was able to line them back up with the screws when I reassembled it. The fact that they didn't move a whole lot would suggest they are worn some. It's been 11 - 12 years after all.
# 0 rows returned
post #4 of 7 (permalink) Old 12-15-2005, 10:02 AM
Uber Luber
Thomas's Avatar
yeah. FYI - you can buy the entire brush assembly for 4 dollars. New brushes already set in the housing with a clip in them. Might as well do that while you're at it, for 4 bucks.
-Thomas
Thomas is offline
post #5 of 7 (permalink) Old 12-15-2005, 10:48 AM Thread Starter
Al_Florida's Avatar
Thanks.
# 0 rows returned
post #6 of 7 (permalink) Old 12-15-2005, 10:55 AM
good idea on the brushes Thomas
fyi to others interested; sometimes you need to be carefull if you have many miles on the altenator (say 130,000+), the contacts on the spindle will wear down, and may not work well with new brushes.
good write up/pics AL
tomaso12 is offline
post #7 of 7 (permalink) Old 12-17-2005, 09:03 PM
Thumbs up
That was a very good article. It was very descriptive and the it was made simple to understand. Also the other people that had put in their info to supplement it did a very good job as well. We need more articles like that. I just wanted to complement the article as well as the responses.
tino is offline
