nitrous jets - TCCoA Forums
post #1 of 4 (permalink) Old 01-30-2008, 06:37 PM Thread Starter
paintme205's Avatar
nitrous jets
what jets are you guys using for a 75 hp shot on the zex dry kit. i think the nitrous is a 40 and fuel 43? does this sound right for a mostly stock 97 bird. also anything i should check before i run it the first time. What plugs are you guys using?
paintme205 is offline
post #2 of 4 (permalink) Old 01-31-2008, 07:09 PM
Send a message via Yahoo to fntwisted
you should really put the car on a chassis dyno with an expereinced operator first and foremost. then that person can tell what you will need .
fntwisted is offline
post #3 of 4 (permalink) Old 01-31-2008, 08:57 PM
just run it.......I ran my car threw a shat load of bottles untuned before I took the kit off(maybe 30,000 miles) at a 75 dry shot.
couple things, get colder plugs, like NGK TR6's.
also, either get a tune or a timing adjuster to lower your timing a couple degrees when using the sauce.
post #4 of 4 (permalink) Old 01-31-2008, 09:02 PM Thread Starter
paintme205's Avatar
sounds good. im gonna get in contact with lonnie soon since i want to add 373 gears also. im in the process of installing everything now so just gathering info now. thank you very much.
