Planning on using nitrous for my turbozz - TCCoA Forums
post #1 of 9 (permalink) Old 02-09-2009, 10:02 PM Thread Starter
Tx_Cat's Avatar
So I had the idea of spraying some nitrous on the track just to cool down the air temp going to the engine, but I was not sure as to what size jet to use. After talking too several guys here, they recommended a 25 shot which I think it's fine.
Now, I decided to buy the parts separately instead of buying the whole kit, which I think I could save a few hundred bucks here and there.
(1) Super Powershot Nitrous Solenoids, nitrous flow of up to 175 HP with a low 8.6 amp draw. Utilizes 1/8'' inlet and outlet NPT threads. Item
#NO.16020.
(1) Super Powershot Fuel Solenoid, fuel flow rate of up to 200 HP at 6 p.s.i. Draws only 0.6 amps and features 1/8'' inlet and outlet item # NO.16080.
(1) 10-14 foot of Stainless Steel Nitrous Hose
(1) NX Carbon Fiber nitrous toggle switch
I was looking at the 05116NOS kit for reference.. I Know I am missing the following:
1. Bottle
2. Fuel Pressure Safety Switch
3. WOT Switch
4. 25, 50 jets
5. Relays and fuses
6. RPM Chip
What else am I missing?! Also, could I use does part numbers and listed on the NOS website and use them for my kit?! Sorry for the newb questions guys, still learning as I go..
Much help is needed and greatly apprecited..
Israel
Tx_Cat is offline
post #2 of 9 (permalink) Old 02-10-2009, 08:27 AM
paintme205's Avatar
dry kit or wet kit? I thought you mentioned dry. I think thats all the parts you need. You might want a bottle heater but may not be necessary.
I can take a pic of my dry zex kit if you want that for reference?
paintme205 is offline
post #3 of 9 (permalink) Old 02-10-2009, 09:15 AM Thread Starter
Tx_Cat's Avatar
Yes please. that would help a lot.. So it would not be a problem if I buy the parts for the mustang kit right?!
Tx_Cat is offline
post #4 of 9 (permalink) Old 02-10-2009, 09:05 PM
paintme205's Avatar
it shouldnt be. Im using zex but its the mustang kit so i really dont think it will matter. Give me a day or two on the pics. Gotta find the box.
post #5 of 9 (permalink) Old 02-10-2009, 11:13 PM Thread Starter
Tx_Cat's Avatar
Instead or using the micro switch, can I just use a button so I can spray whenever the hell I Want?!?!
Tx_Cat is offline
post #6 of 9 (permalink) Old 02-11-2009, 08:29 AM
paintme205's Avatar
you want the micro switch. If im correct then that is what senses wide open throttle. You can put a push button on the positive wire and then make it so it is push button only. I dont recommend it though. I would think tuning would be a little harder since you never know when your going to hit it.
post #7 of 9 (permalink) Old 02-11-2009, 12:10 PM Thread Starter
Tx_Cat's Avatar
Ok make sense. So the wiring I posted is the one I will follow on my car, correct?!
Tx_Cat is offline
post #8 of 9 (permalink) Old 02-11-2009, 07:07 PM
paintme205's Avatar
yes just follow that schematic. Looking at that your piecing together a wet kit. Its quite simple.
post #9 of 9 (permalink) Old 02-11-2009, 08:13 PM Thread Starter
Tx_Cat's Avatar
Yeah, I thought it was a dry kit, but I guess I'll stay with the wet kit. Thanks man!!
Tx_Cat is offline
