Zex Nitrous Dry Kit on stock '95 4.6 - TCCoA Forums
post #1 of 43 (permalink) Old 02-25-2009, 07:36 PM Thread Starter
Dechstang's Avatar
thinking of running a dry kit on my stock '95 4.6. for the record i dont care if i blow the engine up! =) would a 5.0 dry kit work fine for the 4.6?
Dechstang is offline
post #2 of 43 (permalink) Old 02-26-2009, 02:03 AM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
i would highly recommend not doing n2o at all. imho
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #3 of 43 (permalink) Old 02-26-2009, 07:38 AM
don't listen to v8_superbirdy.....
anyway, yes you can run a 5.0 kit on there....I ran a NOS brand dry kit for mustangs for a while, and it ran very well, and did not mess anything up.
I only ran a 75 shot, and going from a 15.8 in the 1/4 to a 14.1 was good enogh for me.
a 100 shot would have put me in the 13's.
Just make sure you get a tep or 2 colder plugs, knock the timing down a few degrees, and add a little more fuel pressure.
Just be safe with nitrous, it will run for a long time.
post #4 of 43 (permalink) Old 02-26-2009, 09:17 AM Thread Starter
Dechstang's Avatar
Awesome thanks for the input. =)
post #5 of 43 (permalink) Old 02-26-2009, 07:30 PM
Don't be put off by scare stories about nitrous - if it's set up correctly it's not really any more "dangerous" than any other power adder. All it does is add more oxygen to the combustion chamber, same as a supercharger or turbocharger. It just does it chemically instead of mechanically. If you have enough fuel, you shouldn't have problems. Assuming you're not adding too much power to overwhelm the physical limits of the engine itself, that is. But that will happen with any power adder.
I ran a 75 shot on my Contour SVT and it was like a whole different car when I sprayed. I used a ZEX dry kit and it worked great. No detonation, no problems. I still have that kit and it's going to go on my 1997 Mark VIII.
My suggestions for N20:
Get a window switch. You don't want to spray until the RPMs get up, and you don't want to spray after the redline.
Get a fuel pressure cutoff switch. You don't want to keep spraying if you have no fuel pressure. That is just asking for engine damage.
Gauges are a good idea.
Pull some timing to be even safer.
SloMo228 is offline
post #6 of 43 (permalink) Old 02-27-2009, 12:26 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
The 5.0 kit should work. Just make sure it comes with the TPS switch to activate the system at WOT.
I've had a ZEX dry kit on my 96 Cougar since they first came out with it for the 4.6L back in the late 90's. If its used correctly it will last a long time and so will the car. I've had awesome success with mine. Follow the directions and don't try to get dumb with it. Like any power adder, you misuse it and the engine will surely go bang.
Again as mentioned, an upgraded fuel pump and pressure regulator is a very good idea. With those in place you can run the 75 - 125 shot with little problems.
Good luck with it and if you are planning to drag race with it, buy drag tires!!!!!!!
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #7 of 43 (permalink) Old 02-27-2009, 01:13 PM Thread Starter
Dechstang's Avatar
Thanks for the info, I do plan on taking it down to the strip. so ill be looking for some drag tires.
post #8 of 43 (permalink) Old 02-27-2009, 01:18 PM
when I had the bottle on, the tires I ran were wore out H-rated bridgestones(crap), and when I would launch, I would not launch right off the bottle....I would wait until I was about a car length out, then I would activate the nitrous.....this would net me 1.99 60's, and that was with 3.08 gears, one wheel peel!
Now, when I would hit the bottle right on the line....tires would go up in smoke...
just lettin you know what worked for me.
post #9 of 43 (permalink) Old 02-28-2009, 12:30 AM
1MTNCAT's Avatar
Again, get good tires. Launching you'll need them especially if you have some converter & gear.
Best [email protected] 1.57 60' Bottle Slicks
Best 13.2 @ 104.67 1.81 60' Motor NA Drag Radials
Steve
1MTNCAT is offline
post #10 of 43 (permalink) Old 02-28-2009, 11:23 AM Thread Starter
Dechstang's Avatar
i'll keep everyone updated as i plan on taking the car up to the garage and doing the install sometime this week.
post #11 of 43 (permalink) Old 03-02-2009, 07:38 AM
but don't let tires make or break what you decide to do....don't be afraid to run it without drag radials or slicks.
Sure, tires will help maximize your launch, but not totally neccasary if your looking just for some fun.
post #12 of 43 (permalink) Old 03-02-2009, 11:58 AM Thread Starter
Dechstang's Avatar
I ended up picking up a Zex wet kit. i'm just waiting for weather to get better and i'll do the install. I'm currently working on getting the car to run right it doesnt want to stay running in the cold weather. if i start the car and then put it in drive it will stall right away unless the car warms up abit also hesistates so im thinking the IAC but i could be wrong.
post #13 of 43 (permalink) Old 03-02-2009, 11:58 AM
sounds like the IAC is giving you trouble.
post #14 of 43 (permalink) Old 03-02-2009, 12:15 PM Thread Starter
Dechstang's Avatar
well i've checked for vac leaks, none are there i've also changed out the maf with a newer clean maf. i pulled 2 codes which said banks 1 and banks 2 were running lean but that was due to a vac leak i found prior. i want to make sure this thing is running 100% before i install the nitrous what do you guys recommend i do to this engine? oil change, plugs, wires? coils? let me know what will work best as you guys have the experience when it comes to running n20 on these birds.
post #15 of 43 (permalink) Old 03-04-2009, 10:26 PM
danalba's Avatar
ok so iv been looking at nitrous kits for a little while now. im only eighteen and cant afford the good ol superchargers and such, so obviously a nitrous system would be my answer. i was looking at dry kits for my 4.6L. but my question is can you use a purge kit with a dry kit? or is it really not necessary? because there basically the same thing until you change the way it gets to the engine correct? and since it is installed before the nitrous solenoid i essentially can right?.. or is that completely wrong? im new with the nitrous sooo bear with me
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #16 of 43 (permalink) Old 03-04-2009, 10:39 PM Thread Starter
Dechstang's Avatar
yes you can use a purge on the nitrous line. unless you wish to shoot out fuel from your fuel tap lol! =)
post #17 of 43 (permalink) Old 03-04-2009, 11:00 PM
danalba's Avatar
haha ok. thanks man I'm sure I'll have some more questions
PI intake/PI cams
355 trac lok
danalba is offline
post #18 of 43 (permalink) Old 03-05-2009, 07:48 AM
yeah, before the nitrous solenoid...
also, there is no fuel solenoid for a dry system
post #19 of 43 (permalink) Old 03-05-2009, 08:54 AM
danalba's Avatar
thanks ... so what do you think about this....
http://nitrousdirect.com/drynitrouskits.html
in the picture i do not see the nitrous solenoid though??
PI intake/PI cams
355 trac lok
danalba is offline
post #20 of 43 (permalink) Old 03-05-2009, 11:16 AM
paintme205's Avatar
The nitrous solenoid is in the center of the pic at the top. To the left of the red/black wiring. Its black and wrapped with the ground wire i believe.
THere is nothing wrong with the kit but i prefer the zex kit personally. I think the price is nearly the same also. ALot of users have used it with great succes.
paintme205 is offline
post #21 of 43 (permalink) Old 03-05-2009, 12:36 PM Thread Starter
Dechstang's Avatar
thought he was looking into wet kits my bad. lol
post #22 of 43 (permalink) Old 03-05-2009, 12:36 PM
danalba's Avatar
yeah thats what iv seen. so ill prlly end up going with zex when i do purchase one
PI intake/PI cams
355 trac lok
danalba is offline
post #23 of 43 (permalink) Old 03-05-2009, 01:18 PM
danalba's Avatar
alright another question. how long to the bottles last for, ...10lb...15lb...? say seconds wise. holding it down??
PI intake/PI cams
355 trac lok
danalba is offline
post #24 of 43 (permalink) Old 03-05-2009, 01:18 PM
danalba's Avatar
also the price to refill the bottles? not refilling yourself
PI intake/PI cams
355 trac lok
danalba is offline
post #25 of 43 (permalink) Old 03-05-2009, 01:22 PM
I could get about 10-11 good solid runs with my 10 lb bottle, and this was holding the button down 14-15 seconds at a time.(this was a 75 dry shot)
When I had the juice, it was $3.00 a lb....so a little over 30 bucks a fill.
post #26 of 43 (permalink) Old 03-05-2009, 04:40 PM
Buckcreekbilly's Avatar
Curious, know nothing about this stuff, what's the diffrence between wet and dry?
Buckcreekbilly is offline
post #27 of 43 (permalink) Old 03-05-2009, 04:53 PM Thread Starter
Dechstang's Avatar
dry injects just nitrous into the intake. wet sprays both nitrous and fuel into the intake.
post #28 of 43 (permalink) Old 03-05-2009, 08:52 PM
danalba's Avatar
thanks badbird
PI intake/PI cams
355 trac lok
danalba is offline
post #29 of 43 (permalink) Old 03-05-2009, 09:07 PM
danalba's Avatar
whats better dry or wet? or more effective?
PI intake/PI cams
355 trac lok
danalba is offline
post #30 of 43 (permalink) Old 03-05-2009, 09:10 PM
danalba's Avatar
and on wet do you re route the fuel line into the nitrous fuel solenoid, then to the plenium?
PI intake/PI cams
355 trac lok
danalba is offline
