confused on vacumm line for fuel regulator - TCCoA Forums
post #1 of 12 (permalink) Old 04-02-2009, 07:19 PM Thread Starter
paintme205's Avatar
For those with the zex kit...Do you by chance have a picture of where you connected the vacumm line from the zex box to the fuel pressure regulator. Im wondering if i just disconnect the stock vacumm line on the regulator or do i tee in?
Thanks.
paintme205 is offline
post #2 of 12 (permalink) Old 04-02-2009, 10:03 PM
1995 cougar xr7's Avatar
i tryed getting pics of vacume lines last week and nobody would put up any , i just kept using different configurations of hoses i still not sure if i got it right
1995 cougar xr7 is offline
post #3 of 12 (permalink) Old 04-02-2009, 10:31 PM
Resident Gun Guru
SHADOW's Avatar
Sorry I dont have a good picture........but there is a T ................follow the lines with the blue zip ties around the back of the motor.
13.66 @ 100.4 mph
1.94 60' time
"If you stick with the basics, you never have to go back to them"
SHADOW is offline
post #4 of 12 (permalink) Old 04-03-2009, 02:27 PM Thread Starter
paintme205's Avatar
Are you talking about the fuel regulator line. Maybe i didnt clarify enough.
I have the vacumm line hooked up but there is a line that runs to the fuel pressure regulator. Stock there is a red vacumm line that runs from the stock fuel pressure regulator back to the front of the engine. SO did you disconnect and then hook up the zex one or did you add in a tee.
post #5 of 12 (permalink) Old 04-03-2009, 02:34 PM
Faster than Porkchop
cjchevez's Avatar
Is this what your looing for ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #6 of 12 (permalink) Old 04-03-2009, 02:39 PM Thread Starter
paintme205's Avatar
Sort of. I found what i was looking for.
For future reference.....You run the line to the regulator and use the stock line for the intake vacumm...if that doesnt make sense then read this lol.
http://forums.tccoa.com/showthread.php?t=61194
post #7 of 12 (permalink) Old 04-12-2009, 09:30 PM
the zex box gets hooked in between the vacum hose going to the regulater and the regulator
no tees are needed
disconect hose from regulater ,hook that to the zex box,
take other hose from zex box and goto the regulater
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #8 of 12 (permalink) Old 05-10-2009, 08:24 PM Thread Starter
paintme205's Avatar
Thanks for the help joker.
By the way....the kit i got from you two years ago works great. Thanks.
post #9 of 12 (permalink) Old 05-10-2009, 09:39 PM
yea i used that zex box to run a 125 shot and never had a problem
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #10 of 12 (permalink) Old 05-12-2009, 05:44 PM
Whining Intakes Rock
Al_Florida's Avatar
Search is a b.e.a.-UUUUUU-tiful thing.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #11 of 12 (permalink) Old 05-12-2009, 05:55 PM
this thread was fine with out any moderator help
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #12 of 12 (permalink) Old 05-14-2009, 05:04 AM
Al_Florida's Avatar
mike
I didn't realize my rudimentary point had the capability to jog right by those slow afferent neurons. There is a wealth of information on this forum. Many of the questions asked today have been answered several times over the years. Most of these questions can be avoided if someone uses the tools that this forum has made available. Allow me to slow that one down.. S E A R C H. It's not rocket science. In fact the original poster, albeit after they posted, found the information they were looking for when they searched the forum. Imagine that it does work.
# 0 rows returned
