HSW Plate Kit? - TCCoA Forums
post #1 of 8 (permalink) Old 09-25-2010, 03:22 PM Thread Starter
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
HSW Plate Kit?
Has anyone here used this kit? I was wondering about hood clearance on the MN12s.
Heres a link to the kit
http://www.harrisspeedworks.com/prod...&cat=91&page=1
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #2 of 8 (permalink) Old 09-25-2010, 09:44 PM
ITS an ok kit.....doesnt have an window switch
i have a 125 wet shot zex kit on my 89 5.0 and it works great
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #3 of 8 (permalink) Old 09-26-2010, 01:16 AM Thread Starter
HSW makes anice TPS/Window switch that I will be using.
Geoff
1995 Mercury Cougar
post #4 of 8 (permalink) Old 09-27-2010, 11:00 AM
MAMN12 Posse Member
JeffTBird93's Avatar
Couldn't you just use a plate (that company or similar), and run that instead of the fitting in the intake tube? I know either NOS or Nitrous Express used to make a 4.6 plate like that.
~Jeff
*signed off
JeffTBird93 is offline
post #5 of 8 (permalink) Old 09-27-2010, 11:23 AM Thread Starter
Nitrous Express and Harris Speed Works makes plates for the 4.6 as far as I know. Yes the plate replaces the nozzle on the intake tube.
Geoff
1995 Mercury Cougar
post #6 of 8 (permalink) Old 09-27-2010, 12:22 PM
MAMN12 Posse Member
Yes, I'm saying running a more reputable kit, and just get the plate later.
~Jeff
*signed off
post #7 of 8 (permalink) Old 09-27-2010, 12:32 PM
i was always told to put the n2o injecter 6-8 inches in front of the throttlebody somewhere in the intake pipe....something about better atomization with the incomeing air and less chance of fuel puddling in the intake runners
mike
1990 ford f150 5.0
1984 tbird 5.0 auto
post #8 of 8 (permalink) Old 09-30-2010, 09:38 PM Thread Starter
I know a few people running Harris kits with absolutely no problems. They might be a smaller company but they have quality products.
I'll prob just do a basic dry kit for the moment and then convert to a wet plate later on.
Geoff
1995 Mercury Cougar
