nitrous solenoid - TCCoA Forums
post #1 of 4 (permalink) Old 01-12-2013, 08:40 AM Thread Starter
ricky05uphs's Avatar
Question nitrous solenoid
I'm wanting to put my nitrous solenoid in the trunk for dry shot. Will it work properly?or will all the extra nirous in front of the solenoid continue to flow after the system is shut down?
ricky05uphs is offline
post #2 of 4 (permalink) Old 01-12-2013, 02:17 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Regardless of where you put it when the switch/solenoid is shut off only what is in the line will be left to get to the engine. It don't take long to clear a line. I'd still mount it in the engine bay if it were me.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #3 of 4 (permalink) Old 01-12-2013, 09:38 PM Thread Starter
I mounted the solenoid under the hood to the far left were the fuel lines come up from the under side. I did't have the right size fitting to make it work in the trunk. Oh well its out of veiw for the most part. I hate the way the nitrous solenoid looks. I would put some pictures up but I dont see the option..
95 4.6 Bird full PI swap daily driver, DD 2200 stall converter, Jerry chip, 80mm Maf.
Back in the day with a few other mods such as 3.73 (3.08's now), underdrive pullies(back to stock pullies now)and C&L upper and 70mm TB. [email protected]
96 Tbird FRPP/SVO blower 3.3 pulley, 70mm TB, 90mm maf, AIS w/2 nozzles,iron block with -3cc dish mark VIII pistons, stock pi heads/cams , DD 3800 stall converter, Built trans by Robertp, ported manifolds, nice exhaust, Cobra rearend with 3.73's, Mach 1 Breaks up front, SCT tuned by Robertp, and 60lbs injectors and 405lph pump. E85
2005 expedition 5.4 family vehicle
post #4 of 4 (permalink) Old 01-16-2013, 09:43 PM Thread Starter
Turns out my new-used solenoid sticks...So I use the new one that came with my purge kit. Do solenoids go bad that often?
