Going to the dark side - TCCoA Forums
post #1 of 14 (permalink) Old 07-12-2014, 10:07 PM Thread Starter
Tbird1997's Avatar
I've been doing some reading on nitrous and thinking about running a 75 shot on the tbird. I've been looking for another affordable upgrade I can do; TFS heads, headers, etc are too expensive so I'm pretty much left with nitrous. I like the zex dry kit which I see a lot of guys here run. I don't need the top of the line nitrous kit but I do want a decent kit that is safe and affordable. Most of these parts I buy will probably be used.
Here's the plan:
255lph fuel pump
2 step colder plugs
window switch
bottle heater
ignition box to retard timing (Probably retard timing 4 degrees? I assume my flip chip advances timing 2-3 degrees.)
Injectors:
Do you think my stock 19# injectors will support my current mods and the 75 shot? I've read that they are good for 280 RWHP. I don't want to change the injectors unless I have to because that will require another tune...
If I will need bigger injectors I'm thinking I will go straight to 30# injectors so I can run e85 with the nitrous. I'll have to wait a little longer to save up for all of that though.
Any other parts I should invest in? Particular brands are helpful.
Another option is a wet kit so I won't have to upgrade the injectors but I see those are twice the cost as a dry kit. Thoughts on the wet kit?
I'm new to the nitrous thing so any other advice you can give is welcome
-Patrick
Tbird1997 is offline
post #2 of 14 (permalink) Old 07-12-2014, 11:17 PM
I've got a used - low mileage - Walbro 255 lph pump I'll sell ya if you're interested ...
Edit: See this thread - http://forums.tccoa.com/showthread.php?t=142045
post #3 of 14 (permalink) Old 07-12-2014, 11:56 PM Thread Starter
Tbird1997's Avatar
I wish you had the new one. Sending you a PM
-Patrick
post #4 of 14 (permalink) Old 07-13-2014, 10:34 AM
Meh, the used one is just as good as the new one at half the price.
To answer your questions, the pump is about 5 years old but it was only in the car for about two years. It's only got about 10,000 miles on it - practically new. As you know, my car is a garage queen that rarely gets driven.
I'll find a box and get you a shipping quote.
post #5 of 14 (permalink) Old 07-13-2014, 12:40 PM
Couldn't resist after reading the thread title.
post #6 of 14 (permalink) Old 07-13-2014, 06:37 PM Thread Starter
Tbird1997's Avatar
Lol Brandon
Thanks TM!
Ben with his cougar made 281rwhp and 425 ft lb with stock injectors so I think I'm going to be good! I need more nitrous people to gve me some input! Steve, 95badbird, VicRattlehead, stayunique91, etc etc
-Patrick
post #7 of 14 (permalink) Old 07-13-2014, 06:55 PM
The Great Obucina's Avatar
since 24lb injectors are sooooooooooooooo cheap and available, i would run them. After all the work involved in running NAWZZ!!! just pop on a set of blue tops and call it good. Why? Lets say you tell me to go get bent and go cheap(which is the same response the majority of the inbreds on f150forum.com tell me to do), the second you lean out on those 19lb injectors, you are done-zo. By the way, those old yellow tops are older than some of my students, replace em!
Just remember, you will need to account for the revised injector pulse width in the tune, when you get one.
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 14 (permalink) Old 07-13-2014, 09:04 PM
For cheap I'd upgrade to teal/blue 24lbs. But, since your looking at a retune anyway, plus nitrous, and contemplating E-85 my advice is 42lb green tops which will cover you almost indefinitely. Also if you can spring for it http://www.2quicknovas.com/nitrousaurus-x.html.
post #9 of 14 (permalink) Old 07-13-2014, 10:39 PM Thread Starter
Tbird1997's Avatar
Crap I just realized Ben is on a wet kit. SOAB
Well I need a retune anyways so might as well... I was thinking the 30#ers would be enough for e85 and nitrous at my power level but I guess if I do heads or something else later I should go for 39 or 42#ers...
I found on an e85 website for a rough estimate to multiply your current injectors by 1.47 if your going to run e85.
Maybe I'll do the dynotunes first (one 93 octane and one e85) then run the nitrous when I have the money... 42s are expensive.. Chris I know this is a broad question but what is typical for 2 dynotunes price wise?
-Patrick
[email protected]77mph on used street tires
post #10 of 14 (permalink) Old 07-14-2014, 12:24 AM
Varies wildly dependent on variables. Hardware, brand, licencing, labor, dyno time, tuner (person), etc... I personally don't tune cars myself. I am a dyno operator which is a bit different, I provide HP/TQ numbers for clients or set the dyno for specific load applications to make adjustments to vehicle parameters. I stay out of the professional tuning business due to the liability, I was even sent to seminars and training to tune vehicles and still choose not to, but many people bring me vehicles with their own setups, for example I have a few mustang customers with SCT X-Cal2&3's and PRP that come to me to run the dyno, they pay by the hour, I provide the load and vehicle simulations, sometimes a wideband (most of them have their own wired to the vehicle) and they make adjustments themselves.
On a personal level I have a tuner that I use (Don LaSota) he requires datalogs and makes adjustments to the tune until it is correct via email. His required data is obtainable under controlled street environments as well as on a dyno. I sometimes regret not getting a PRP but I haven't needed an adjustment in my tune. He dialed it in perfect. However when I change my intake manifold, switch to headers, add a blower, increase injector size, switch to E-85, and change to an SCT big air MAF, I'll make the plunge to PRP and pay for his tune, giving me the opportunity to make big changes on my own in the future.
I charge $150 per hour up to 5hrs. The rate drops above that to a daily rate.
post #11 of 14 (permalink) Old 07-14-2014, 05:44 PM
I probably have a low mileage set of 30's around here somewhere.
bulldog is offline
post #12 of 14 (permalink) Old 07-18-2014, 09:18 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Lol Brandon
Thanks TM!
Go with the ZEX dry kit with the TPS Switch used on the early 2V 4.6L Mustangs. I purchased mine new in "99" I believe. That system is set up for 19# injectors FYI.
Looking at your mods I would go with 24-30 Lb Injectors. Whichever you can come across at the best price. You also want the upgraded fuel pump. You need to have room with the injectors and with the fuel pump to keep it safe.
My car with a host of bolt ons, fuel pump, pulleys, exhaust, etc. on the NPI Engine -NPI Intake combination went a best of 12.8's and that was on 125 shot and a superchips chip in 2004. I had never had the car on a dyno so have no clue on numbers. Once the Bullitt/PI Swap was completed after that Jerry W dyno'd the car with the 24's and put down 348 HP and 503 Ft lbs.
Later on I had 30lbers added and a Stage 1 cam but never had the car dynode after those.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #13 of 14 (permalink) Old 07-21-2014, 03:08 AM
zex
Im going to.be running a zex wet kit , I would go wet because u dont have to worry about maxing ur injectors however I would still upgrade, go to sccoa we ditch 30/36lbs and even 42lb injectors cheap often
So far I know its 1° of time retard per 25hp
Mine is a supercoupe and going with 55-100 shot depending on how well things go
But I have 60lbs and a 340lph pump
But if u do go with dry system
Make sure u have the fuel system to go with it
Here is my car im not a stranger to the tbirds but im more frequent on sccoa
http://www.sccoa.com/forums/showthre...92-SC-timeline
http://www.sccoa.com/forums/garage_v...vehicle&id=444
miguel5671 is offline
post #14 of 14 (permalink) Old 08-02-2014, 04:07 AM
I have a set of 24lb injectors I would like to part with slightly used low mileage great working shape 60 bucks takes em shipping included
97 Thunderbird LX 4.6 sohc, 60,000 original miles and lots of room for improvement.... All show and no go for now...
Raymondo112 is offline
