New MSD window switch is coming out... - TCCoA Forums
post #1 of 20 (permalink) Old 11-24-2003, 01:22 PM Thread Starter
http://www.msdignition.com/2004/2004_2.htm
Its made for our cars with the coil packs. So then you dont need a tach adapter. And its all digital so there is no need for all the RPM pills.
I dont think its out yet, but I will be getting it when it does.
BlackTbird96 is offline
post #2 of 20 (permalink) Old 11-24-2003, 04:49 PM
Also there is this one available for DIS cars (ours) now
http://www.msdignition.com/ignition_27_c.htm
Probably will cost a hair less than the digitial one. (I hope)
JoelBender is offline
post #3 of 20 (permalink) Old 11-25-2003, 05:35 AM
Aaron_T's Avatar
http://www.harlan-engineering.com/store/store.html
click on window switch
Fully adjustable and only $55 shipped. He's supposed to be a stand up guy, and his products are supposed to be awesome. Mine should be here this week or next.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #4 of 20 (permalink) Old 11-25-2003, 01:22 PM
Like Titles Matter
kdanner's Avatar
These cars have a clean tach lead, so the original window switch already works, no tach adapters needed.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #5 of 20 (permalink) Old 11-25-2003, 04:21 PM
Well that's great news KDanner!
thanks alot, now I dont have to wait any longer, or get some stupid adapter.
(maybe I should have asked this a long time ago, you know, before airboxes started exploding )
post #6 of 20 (permalink) Old 11-25-2003, 05:00 PM Thread Starter
The new DIS-RPM switch is out already. You can buy it from summit for like $65. I haven't found the digital one anywhere yet.
http://store.summitracing.com/defaul...part=MSD-89561
post #7 of 20 (permalink) Old 12-07-2003, 07:51 PM
Ok now I have a really dumb question?
Which wire do I tap off the EEC for the tach output? Or can I tap into a lead coming off the coil packs, if so, which one.
Thanks alot
post #8 of 20 (permalink) Old 12-07-2003, 08:02 PM
Aaron_T's Avatar
Not such a dumb question. I would like to know too
I will look at some wiring diagrams and try and find out, but if someone actually knows
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #9 of 20 (permalink) Old 12-07-2003, 09:00 PM Thread Starter
I think the wire you need is orange/white which is #48 I believe. Or it might be #26 but the #48 sounds better.
Its late and Iv been working a car way too long
post #10 of 20 (permalink) Old 12-07-2003, 09:21 PM
Aaron_T's Avatar
According to my diagram, #26 goes the coild pack for cylinders 1,6,3,5
and #48 goes to the constant control relay module.
#26 - dark blue/lt. green
#48 - lt. green/purple
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #11 of 20 (permalink) Old 12-07-2003, 09:25 PM Thread Starter
I dunno, I had something like that writen down that someone told me a while ago, but I cant find it now. Someone else should know. Im just retarded right now.
post #12 of 20 (permalink) Old 12-07-2003, 09:34 PM
Aaron_T's Avatar
This is from a Chilton's btw, so it may be inaccurate.
Edit: it doesn't appear to be inaccurate except for #48
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #13 of 20 (permalink) Old 12-07-2003, 09:44 PM
Like Titles Matter
kdanner's Avatar
You want the wire that goes from the EEC to the tach.
kdanner is offline
post #14 of 20 (permalink) Old 12-07-2003, 09:53 PM
Thanks alot, now to go hunt down that wire
I really appreciate it
post #15 of 20 (permalink) Old 12-07-2003, 10:50 PM
Going on the information from Kdanner, I found the pinout from the eec and you need to tap wire #48 which is white/pink.
Here is the pinout diagram, If I am incorrect please let me know.
post #16 of 20 (permalink) Old 12-08-2003, 02:47 AM
Aaron_T's Avatar
Thanks Joel, Chiltons appearantly mislabeled #46 w/ a #48, and has no "real" #48 on the diagram.
I knew BlackT was right all along
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #17 of 20 (permalink) Old 12-13-2003, 01:32 PM
Window switch is in, I have an adjustable low rpm module in it, and it's set for 2800 rpms I tested it out today, and it works great, I just tapped into the white/pink wire #48 as it goes into the gauge cluster.
when I have a spare intake laying around I'm going to set the unit to come on at 2500 rpms, which should be fine, but i will have a spare intake sitting on the side, just to be safe. I do know that the stock tach is a bit on the slow side when you go wot from idle.
post #18 of 20 (permalink) Old 12-13-2003, 04:12 PM
Aaron_T's Avatar
Thanks for the info Joel. Now if only my window switch would show up, and there wasn't snow/and ice on the road
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #19 of 20 (permalink) Old 12-13-2003, 09:07 PM
yea I know about the ice, it's gettin bad out tonight, supposed be under freezing rain through tommorow here
post #20 of 20 (permalink) Old 12-13-2003, 10:18 PM Thread Starter
Yea in Chicago, IL its been lightly snowing for most of the evening. So far there is about 1-2" of snow on the ground. Glad my Tbird is in a nice safe garage for the winter this year And the focus is great in the snow. Maybe I should install a nitrous kit in the focus too
BTW - My window switch is on its way too. I will be installing it once I get it and testing it in the spring.
