Running a 125 shot? - TCCoA Forums
post #1 of 21 (permalink) Old 01-24-2004, 08:09 AM Thread Starter
Running a 125 shot?
How many people are running a 125 shot on a stock engine? I'm debating this, and ordering my chip within the next couple days, so I kinda need to make up my mind. I know I need to upgrade my fuel pump, the 255 Walbro is on the way. I'm using the ZEX 4.6 kit 75-125 horsepower, if that makes a difference. I'm planning on getting the 2 position chip, with the 2nd position being a nitrous tune. Will I be relatively safe with this? I know safe is a relative word when using nitrous anyways. My car is in good running shape, and has no mechanical problems. I will only run the 125 shot at the track, and I go probably once a month.
Should I go for the 125, or stick with a lower setting? I know the bottom end in these cars are weak, but have heard 125 is OK with the proper tune.
Any feedback is appreciated, positive or negative.
Rich95XR7 is offline
post #2 of 21 (permalink) Old 01-24-2004, 09:27 AM
JustinH's Avatar
I would not spray more than 75 on a stock motor.
If you want to try 125, make sure you have enough money in the piggybank to pull that motor out and put something better in.
JH
JustinH is offline
post #3 of 21 (permalink) Old 01-24-2004, 09:54 AM
I ran a 75 shot and it wasn't that much. There are a lot of people on here that runs 125 shots and are just fine. I say as long as your tuned for it, then go for it.
BlackTbird96 is offline
post #4 of 21 (permalink) Old 01-28-2004, 12:28 PM
I run a 125 shot, and other than spraying too soon and blowing the intake to bits I havent had any issues.....Mind you my motor also has 150k + on it, and it is still holding together......I know 1MTNCAT also sprays a 125 shot, and has done so for years.
I know that my motor will not last forever, especially at this mileage, but when it goes, or come December this year (whichever comes first) I will be putting something a little special in.
JoelBender is offline
post #5 of 21 (permalink) Old 01-29-2004, 01:34 AM
loopyj22's Avatar
Send a message via AIM to loopyj22
Rich.....I have been running a 125 NOS shot (dry mind you) for about 6 months now....no probs whatsoever.....all the local stang guys run 150 shots on their sohc so I think we are "safe" The weakest part of the whole thing will be your drivetrain...you should look into upgrading tranny, rearend, and suspension mounts.
97 4.6L SOHC
(old times before headswap,PI cams, and PI intake)
N2O - 12.83 1/[email protected] --------- NA - 14.2 1/[email protected] mph
PnP NPI heads, PI intake with adaptor plates, crossover cooling mod, PI cams, 4100 lbs GVW, 2.25" true dual exhaust, Flowmaster 40 series, deleted cats, K&N cold air intake, 120HP NOS shot, NOS Programmable modulator, 80 psi fuel pump with reg., 9MM FRPP plug wires, Reinhart chip, Jmod, Mark8 T/C, FRPP 3.73 Alum. Rear-end, Dynotech MMC D/S, MSD coil packs, Custom ram air
94 T Bird Project Car
Planned installs: Ford 460ci motor, Tubbed rear-end with Dana 40 Axle, NOS power adder, new paint job, complete roll cage
loopyj22 is offline
post #6 of 21 (permalink) Old 01-30-2004, 10:05 PM
what mounts would you guys recommend replacing before running the nitrous. have a 100 shot ill be running within the next two months and am trying to get the adjustable FPR as well as the fuel pump. what FPR would you guys go with? i have the Walbro. I figure i need motor mounts, anything else?
outside18 is offline
post #7 of 21 (permalink) Old 01-30-2004, 11:40 PM
loopyj22's Avatar
Well any FPR will do as long as it is adjustable up to approxiamtely 60 psi. As far as motor mounts go you dont have to do them unless your are bad or old. Make sure that your fuel pump can withstand the added pressure. The one I have is an inline pump rated up to 80 psi
97 4.6L SOHC
loopyj22 is offline
post #8 of 21 (permalink) Old 01-31-2004, 10:44 PM
Send a message via AIM to ruffledfeathers
I have the zex kit and I want to run the 100 shot.
With a adjustable regulator what pressure should it be set at?
Also what fuel pums will fit our cars?
The same as the 4.6 mustangs?
Also how many of you guys are running bottle warmers?
94 LX 4.6
SC GFX , Suspension Techniques springs bilstein struts
R.P.C. tuning, 80mm mMAF
2 steps colder plugs, 9 mm wires 180 stat1 piece alum. driveshaft, 3.73 gears
2.5 inch Xpipe no 3rd cat , no mufflers
PI Stallion 9 inch 3k stall converter
March underdrive pullies
Zex dry Nitrous kit 75 hp for now
[email protected]7 with no traction !SOLD!
93 mustang notch 5.0
ruffledfeathers is offline
post #9 of 21 (permalink) Old 02-01-2004, 09:10 PM
Aaron_T's Avatar
You really need a bottle warmer to stay at the right pressure. It will help in not blowing anythign up, as well as get the most out of your nitrous. Along w/ the heater you should get a pressure gauge so you know what your pressure it at.
As for the fuel pump is should be the same as a Stang. You can get a Walbro for around $130 or less.
You can get a good heater for $149.99 at http://www.speedshop.org/store/scrip...?idproduct=17,
and a pressure gauge for $41 at http://www.nitrodaves.com/outlet/pro...up=1&section=3
or if you have the adapter(manifold) there is one for $25.99
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #10 of 21 (permalink) Old 02-01-2004, 11:14 PM
^why does a bottle heater help?
Andrew-L is offline
post #11 of 21 (permalink) Old 02-06-2004, 07:07 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
A bottle heater warms the bottle to help pressurize it. This is particularly useful in colder temperatures. The Bottle pressure on most systems are recommended to be between 900-1100 PSI.
If the pressure is too low the system will not work as efficiently/effectively as it should. In the summer time the opposite is true. You need to monitor the pressures to insure it is down to that recommended safe level.
Bottom line is heat builds pressure. All systems have an optimum operating pressure range. Read the manufacturers instructions for their specific recomendations.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #12 of 21 (permalink) Old 02-09-2004, 07:49 AM
dugweed's Avatar
Send a message via AIM to dugweed Send a message via Yahoo to dugweed
the pump is the same as a stang but the strainer (small nylon mesh pickup) is way different, and the stock one for tbirds will not fit a 255lph pump.
Mike
2009 Harley-Davidson Road Glide
1996 F350 CCLB 7.3 5 speed 4x4
dugweed is offline
post #13 of 21 (permalink) Old 02-09-2004, 06:55 PM
What kind of strainer will fit the 255lph pump?
Also what presure should the regulator be set at?
Im glad you said that b/c i was about to enter my cc# in for a fuel pump kit
with strainer and all. I looked it up for a 96 stang.
Will the strainer that comes with the pump work in my tank?
94 LX 4.6
[email protected] with no traction !SOLD!
post #14 of 21 (permalink) Old 02-11-2004, 11:48 PM
i should be able to run the mustang zex kit on my 5.4 conversion right all same sensors?
5.4blkbird is offline
post #15 of 21 (permalink) Old 02-12-2004, 09:55 PM
I would go with the Compucar 4.6 kit, 125 hp for my mark 8
Goody is offline
post #16 of 21 (permalink) Old 02-13-2004, 02:34 PM
Should just be able to go to Autozone and pick up the strainer sock for a stock t-bird pump. the sock will fit on the mustang pump.
post #17 of 21 (permalink) Old 02-13-2004, 07:23 PM
ok thanks now I can order my pump and regulator.
What pressure would you recomend running the regulator at?
94 LX 4.6
post #18 of 21 (permalink) Old 02-13-2004, 07:34 PM
that I cant help you with. I run a wet system so the stock fuel pressure is fine on my system.
post #19 of 21 (permalink) Old 02-13-2004, 07:38 PM
you sure a stock sock will fit a 255 pump?
earlier in this thread a guy said it will not.
94 LX 4.6
post #20 of 21 (permalink) Old 02-13-2004, 08:25 PM
yes, the attachment where the sock fits on the pump is the same between the two. The design of the fuel pump sock is what differs. It is because of the different design of the t-bird and Mustang fuel tank.
here's a link to MN12's how to on their kit.... it shows the picture of what a t-bird fuel sock looks like. You can look around and find pictures out there of a mustang fuel sock.
http://www.mn12performance.com/mn12p...it-install.htm
post #21 of 21 (permalink) Old 02-13-2004, 08:48 PM
Thank you very much.
I will feel alot better now when I order my pump
94 LX 4.6
