How Long to run my Nitrous - TCCoA Forums
post #1 of 6 (permalink) Old 08-11-2004, 10:04 PM Thread Starter
I have just put in a wet system, but instead of a push button for a short spray I have an "on / off" toggle switch. I have heard not to run it longer then 10 seconds. (direction on the box) How much are you all sending in at once and for how long? How many time do you hit in in one pass? I have it all set up and am scared to hit it (long walk home) I just want to be sure my first time is not my last time.
thanks
Uglybird is offline
post #2 of 6 (permalink) Old 08-11-2004, 10:17 PM
You can use your system from approx. 3000 rpms up in first gear through the end of a 1/4 mile dragway. I run a 125 hp shot on my NX wet system once I hit 2800 (every car is different) in first gear, and shut it off once I hit the 1/4 mile mark, ussually in around 13.6 seconds. I wouldn't want to spray into 4th gear, as it probably isn't that good on the overdrive band....lol
JoelBender is offline
post #3 of 6 (permalink) Old 08-13-2004, 12:44 AM
I have wondered that also; Thanks Joel
Dave
DMcBrideBoston is offline
post #4 of 6 (permalink) Old 08-13-2004, 09:29 PM
Aaron_T's Avatar
You technically could run it till the bottle is empty. The only "major" risk is the solenoids getting hot, but the nitrous keeps them cool, so as long as there is nitrous.....
I would say no more than 15 seconds though, which you shouldn't need to spray for that long anyways.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #5 of 6 (permalink) Old 08-15-2004, 07:26 PM Thread Starter
Thanks for your alls input...I was not wanting to kill my motor. Thank you!
Uglybird is offline
post #6 of 6 (permalink) Old 08-21-2004, 12:34 PM
Tx_Cat's Avatar
either way, NO2 kills your engine in a long run. Might consider getting replcament or forging it
Tx_Cat is offline
