Where to get the ZEX Kit Cheapest? - TCCoA Forums
post #1 of 4 (permalink) Old 08-16-2004, 09:38 PM Thread Starter
281_TBird's Avatar
Hey guys I'm considering getting a ZEX Nitrous kit for my T-bird. Where is the cheapest place to get this kit? Also, what do I need to safely run a 75 to 100 shot? I was thinking a 255 fuel pump, and i new fuel filter, but is there anything else? Also I want to get a purge kit, and I a safety switch to arm and disarm the nitrous. Anything else I should get? Thanks a lot.
1997 Ford Thunderbird, Built NA 2V/ T-45
1997 Ford Explorer AWD 5.0L
2003 Lincoln LS V8 Bolt Ons
2009 Yamaha VMax
2011 F-150 Lariat Limited 6.2L 4WD
2015 Ford Mustang GT Premium, Performance Pack, Recaros
281_TBird is offline
post #2 of 4 (permalink) Old 08-16-2004, 09:41 PM
Whining Intakes Rock
Al_Florida's Avatar
eBay is the cheapest. 300-350 roughly.
You don't have to do a thing to run a 75 shot from what I gathered. You're stock fuel pump can handle that.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 4 (permalink) Old 08-16-2004, 11:37 PM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
to be safe get 24 lb injectors, 255 fuel pump, new fuel filter, adjustable fuel pressure regulator, and a nitrous tune from sct. you dont have to do all of those but if you wanna do it as safe as possible do it like this.
Warlockguitarman is offline
post #4 of 4 (permalink) Old 08-16-2004, 11:38 PM
Hi,
You will need a 255 or 190lph fuel pump to run over a 75 shot safely. An adjustable fuel pressure regulator is also a good idea for over a 75 shot.
Kirban adjustable fpr's and a walbro 190 or 255 are available on www.mn12performance.com for 190 bucks(best price around for new)
With the Zex kit, also you should invest in a bottle heater and Nitrous Pressur gauge fot the bottle(heater around 100)(gauge 45 on Ebay)
Rail mounted Fuel Pressure gauge is also a good idea, so you know where the pressure is at when you adjust it.(ebay about 45 dollars also)
Hope this helps
Dave
DMcBrideBoston is offline
