Plug Gap - TCCoA Forums
post #1 of 8 (permalink) Old 08-21-2004, 03:55 PM Thread Starter
Plug Gap
Ok I have the Nitrous in and my when I hit the juice it is blowing out my plugs. Does anyone know the correct gapping for my plugs? I am at .035 now and it is working but Can I open it up any more?
Uglybird is offline
post #2 of 8 (permalink) Old 08-21-2004, 07:07 PM
Aaron_T's Avatar
It's not blowing out the spark at .035 is it? Cuz it shouldn't.
May wanna try .039 or so.....
what type and heat range of plugs are you using?
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #3 of 8 (permalink) Old 08-22-2004, 06:37 AM
I'm still gapped at 55, I should probably change that before I keep sprayin huh?
Dave
DMcBrideBoston is offline
post #4 of 8 (permalink) Old 08-22-2004, 06:46 AM
You may have other problems, you shouldn't be blowing out your plugs at that gap.
Rich95XR7 is offline
post #5 of 8 (permalink) Old 08-22-2004, 10:36 AM
I've been running mine gapped at .54 and haven't had any issues with the spark being blown out.
JoelBender is offline
post #6 of 8 (permalink) Old 08-23-2004, 08:05 AM Thread Starter
Ok, I have it figure out, the most I can gap is .038 with out blowing out ther spark. I had started at a stock gap of .055 -didnt work, and then went to .035 but I wanted to get the gargest gap possible. I am running a 100 shot now and wow can you feel it. Complete grateness!!!
Uglybird is offline
post #7 of 8 (permalink) Old 08-23-2004, 12:24 PM
If you are blowing out the spark, then you may want to find a way of getting better spark....
Coil packs, wires, and new plugs will allow you to gap the plugs a big wider.
that thing has to have lost a little when you aren't spraying from running a gap that big.
post #8 of 8 (permalink) Old 08-23-2004, 12:31 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
How do you blow out something that should help the ignite the mixture in the cylinder. It should take a bit less spark to ignite the air/fuel/nitrous mixture in the cylinder due to the larger amount of oxygen and the present amount of fuel. Are YOU SURE, you are gettin enough fuel to the cylinder.
I know you aint blowin out no damn spark with nitrous unless you got the bottle turned upside down at 1500 psi in one cylinder.
Better check your ignition system!!!!!
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
