zex wiring help - TCCoA Forums
post #1 of 19 (permalink) Old 10-10-2004, 11:09 AM Thread Starter
FordFanatic's Avatar
zex wiring help
im attempting to finish the wiring today but these zex instructions suck the big one.
first, the middle wire on the tps is the one i need to tap into right?
second, what did you guys do with the vacuum line that was on the fpr? im assuming i'll have to go buy a "T".
and last where did you guys hook the other vacuum line, all the zex instructions say is to hook it to an unused one.
any pics would be a big help. thanks
FordFanatic is offline
post #2 of 19 (permalink) Old 10-10-2004, 12:28 PM Thread Starter
anyone? bueler?
post #3 of 19 (permalink) Old 10-10-2004, 12:40 PM
Mark M. TCCoA VP's Avatar
As I remember it is the green wire but I always test probe the wire to make sure it is the right one. As far as the Vac line yes the Zex instructions su~k. They just want you to run the new line over to the reg and leave to old one hanging. I perfer to go to the firewall and jump off the vac tee fitting that is already there. The tee has a plug on one of the legs so it makes for an easy install. Just leave the old line connection off the top of the reg hanging and you will be good to go.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #4 of 19 (permalink) Old 10-10-2004, 01:14 PM Thread Starter
how will i know which wire it is? should it have power all the time? do i need to car running? i tryed it already thats why im asking, and the top one has power, the other two didnt.
post #5 of 19 (permalink) Old 10-10-2004, 01:31 PM
Take a meter and probe the wire that increases voltage with the key on and throttle increased. Green and black if my mind is right which it is not
post #6 of 19 (permalink) Old 10-10-2004, 01:57 PM Thread Starter
ahhh i was using a test light, turns out to be the middle wire after all. now on to the vacuum lines, i dont see a "T" on the firewall. if i can ever get my camera software to work maybe it will be alittle easier to follow.
post #7 of 19 (permalink) Old 10-10-2004, 04:28 PM Thread Starter
well i have the switch wired up now, that was a huge pita. i still have to wire the bottle warmer, i think im just going to leave the switch for that in the trunk. the zex bottle warmer is thermo controlled anyway so if i leave it on who cares. the only problem left is the stupid a** vacuum lines. anyone have any pics?
post #8 of 19 (permalink) Old 10-10-2004, 06:01 PM
Vac lines...here we go. This is what to do. From the Regulator hose on the zex box...run it to the fuel pressure regulator. Next. From the Intake hose on the zex box. Run that one to the hose you just pulled off the fuel pressure regulator. This will save you from plugging up one vac line and trying to find another. You will need a splice for the second vac line hook up mentioned, unledd you cut the end off and modify it somehow, but a slice s cheap enough.
whitecoug is offline
post #9 of 19 (permalink) Old 10-10-2004, 06:43 PM
This is that "fake" zex kit that we talked about right??? Don't let Jill read this...tsk tsk!
J/K I would help you, But I like Forced induction not sprayed induction
Kodiak Kid is offline
post #10 of 19 (permalink) Old 10-10-2004, 07:04 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
easiest way to do the vaccum lines is how whitecoug said. thats how i did them too. your just basically running the zex box inline with the pressure regulator.
for the bottle warmer, one wire is a ground and the other runs to the switch then another wire comes off the switch to a 12v source. make sure you use a fuse on the wire that attaches to a 12v source.
When we did mine we just ran a larger wire (10 gauge) from the battery for my 12v source for the activation switch, purge switch, and heater switch.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #11 of 19 (permalink) Old 10-10-2004, 08:34 PM
Frank no relay for the heater? If not check the switch to make sure it can handle it.
Mark
post #12 of 19 (permalink) Old 10-10-2004, 10:41 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Mark
there's no relay with the zex heater. i bought it brand new so its not like i peiced it together myself. i used all the stuff that was supplied by zex including the switch and i followed their installation instructions. thats how they said to do it. they just supplied a 30 amp fuse and fuse holder, no relay though. it didnt call for a relay either. all the electronics and stuff are controled by the heater. theres like a little box attached to the heater where the two wires go into. it looks a little different than other heaters i've seen. i'll take a pic and post it up when i get a chance.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #13 of 19 (permalink) Old 10-10-2004, 10:57 PM Thread Starter
that sounds like a really good plan for the vacuum lines. and not to sound stupid but the fpr is the thing that is in the back of the engine around the same spot as the iac except its on the passenger side right?
post #14 of 19 (permalink) Old 10-10-2004, 11:00 PM
No, should be on drivers side. It's the little (ish) silver canister looking thing on the top rear of the fuel rail on the driver side. Should have a red tube running into the top if it. The tube should be covered with some black wire loom I believe. Hope this helps.
EDIT: In seeing that you you have a 94, as do I, but with 96/7 upper style, I can't remember which side the fpr is on at the moment. I will look into it though. It's still on the back on the fuel rail though. And it still looks like a little canister with a tube on it.
post #15 of 19 (permalink) Old 10-10-2004, 11:07 PM Thread Starter
must still be on the passenger side then, i know there was one with a green tube on it and one with a red tube one it. the one with the red tube was on the fuel rail.
post #16 of 19 (permalink) Old 10-10-2004, 11:13 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
i know mine is on the drivers side at the back of the fuel rail. but since u have the 94-95 set up, i'm not sure if yours is in the same place.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #17 of 19 (permalink) Old 10-10-2004, 11:20 PM
It's on the passenger side rail, with red line going to it
DMcBrideBoston is offline
post #18 of 19 (permalink) Old 10-10-2004, 11:49 PM Thread Starter
cool, that will make hooking up the rest of the system pretty easy then.
post #19 of 19 (permalink) Old 10-12-2004, 07:59 AM Thread Starter
ok i finally got my camera working again so heres some pics to help out the next guy.
