purge line - TCCoA Forums
post #1 of 23 (permalink) Old 10-11-2004, 05:07 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
purge line
last friday night i was at the track and blew a hole in my purge line. this is the 3rd time this has happened, so i havent fixed it yet. i was wondering what you guys are using for your purge lines?
the nos purge kit i got came with a brass tube but it was only 12" long so i just attached plastic/vinyl tubing from a hardware store to make up the difference. am i using the right tubing or is there something other than the plastic/vinyl that i can use?
what are you guys using?
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #2 of 23 (permalink) Old 10-11-2004, 06:39 PM
Frank, the line I am using I believe has a pressure rating..I am not sure though. Are you sure that the line doesn't run against anything really hot, because if it does it will blow when the ice cold nitrous goes though it. That was my problem like 4 times, until we re routed the line.
I have heard of using brake line for the purge line.....
Dave
DMcBrideBoston is offline
post #3 of 23 (permalink) Old 10-11-2004, 07:11 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
i dont think its touching anything hot. i even put wire loom around it the last time just in case
2007 Dodge Ram 1500
Previous Rides:
post #4 of 23 (permalink) Old 10-11-2004, 10:22 PM
Isn't wire loom plastic? If so how would that help something, wouldn't it heat up as well?
If it's not touching anything, I'd say the pressure is too much for the line,.
Dave
post #5 of 23 (permalink) Old 10-11-2004, 11:31 PM
VicRattlehead's Avatar
i cant remember the size but its kinda big, im running a rubber fuel line, works fine.
CMP Drag Racing
VicRattlehead is offline
post #6 of 23 (permalink) Old 10-11-2004, 11:32 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea its not touching anything hot. i put the wire loom on to prevent rubbing on anything, in case that was the issue.
i figured this much.
anyone have any suggestions on what to use?
Frank
2007 Dodge Ram 1500
Previous Rides:
post #7 of 23 (permalink) Old 10-11-2004, 11:33 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
thanks keith, i might give that a try
2007 Dodge Ram 1500
Previous Rides:
post #8 of 23 (permalink) Old 10-13-2004, 10:33 AM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
anyone have any other suggestions?
2007 Dodge Ram 1500
Previous Rides:
post #9 of 23 (permalink) Old 10-13-2004, 03:56 PM
Mark M. TCCoA VP's Avatar
Just find a line that has a pressure rating as vac line does not make it at all. Fuel line will work but it is too damn big. Burlington auto parts has the line that I am using with no problems. It is clear and has a pressure rating of like 60lbs.
Mark
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #10 of 23 (permalink) Old 10-13-2004, 06:03 PM
Aaron_T's Avatar
Copper tubing. Should be in the same area/isle as ice maker tubing (actually I think it is ice maker tubing). Comes in rolls.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #11 of 23 (permalink) Old 10-13-2004, 07:49 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
thanks for the suggestions guys. i'm gonna head over to home depot on friday and and see what i can muster up. what size copper tubing are you using? and mark, what size tubing are you using?
Frank
2007 Dodge Ram 1500
Previous Rides:
post #12 of 23 (permalink) Old 10-13-2004, 08:48 PM
Aaron_T's Avatar
Not actually in yet, too lazy. I blew my plastic line so I bought this stuff since other people I know use it.
Soft Copper Tube (it's bendable), 1/4 OD
my 20ft roll came in a little box, made by JMF. Should be easy to spot.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #13 of 23 (permalink) Old 10-13-2004, 08:51 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea only reason i ask is cus the place in the grill where i had the purge exiting was kind of a tight fit for the tubing i'm using now which is 3/16" OD. 1/4" is close though so it should be ok.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #14 of 23 (permalink) Old 10-13-2004, 08:55 PM
Aaron_T's Avatar
Frank
You should be fine. When I was looking for a spot on my car I was able to get 1/4 OD plastic tubing through without much fight. I can check on my car to make sure if you want.
Another good thing about this tubing is once it's bent however you need, you won't have to worry about it moving around or straightening out.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #15 of 23 (permalink) Old 10-13-2004, 08:58 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea the slot where my puge line was coming out is right above the birds head in the grill. its only like half of a honeycomb in the grill. u dont have to check, i'll make it fit .
Frank
2007 Dodge Ram 1500
Previous Rides:
post #16 of 23 (permalink) Old 10-15-2004, 01:17 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
i went with polyurethane hose. 1/4 o.d. says it can handle up to 150 psi, the hose i was using before could only handle up to 65 psi. if i blow the polyurethane, i'll go to brass.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #17 of 23 (permalink) Old 10-18-2004, 08:44 AM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
the polyurethane hose is working out fine so far. i used it all day yesterday and it didnt blow. thanks for the help guys.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #18 of 23 (permalink) Old 10-25-2004, 08:21 PM
Just blew mine yesterday...Time to replace again...
Will they freeze up in out horrible winter temps or should we be okay.
Dave
post #19 of 23 (permalink) Old 10-25-2004, 08:25 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Dave
i'm not sure. i'll probably fill the bottle one more time this week for next weekend if i go to the track and once it runs out i'll just leave it empty for the winter since i dont use it on the street to much anyway.
frank
2007 Dodge Ram 1500
Previous Rides:
post #20 of 23 (permalink) Old 10-25-2004, 08:31 PM
Mine is empty now, and it'll stay that way until I find a reason to fill it......
Since my car isn't show worthy......maybe it wont get filled..
Dave
post #21 of 23 (permalink) Old 10-25-2004, 08:33 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Dave
yea, i'm sure aaron might have some suggestions for purge lines since he's from alaska .
Frank
2007 Dodge Ram 1500
Previous Rides:
post #22 of 23 (permalink) Old 10-25-2004, 08:41 PM
yeah right...
Did you get my PM....
post #23 of 23 (permalink) Old 10-25-2004, 08:46 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea
2007 Dodge Ram 1500
Previous Rides:
