N20 causing a miss. - TCCoA Forums
post #1 of 3 (permalink) Old 10-13-2004, 08:33 PM Thread Starter
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
N20 causing a miss.
I finaly got around to installing my Zex dry kit. It seems to work fine but the car develops a small miss when it reaches about 4500 rpms in second gear so I back out of it before it shifts to see if the miss would continue. I am only running the 55hp shot to start with and I have already put in a 255lph high pressure fuel pump this past spring. If the car runs lean/rich would it cause it to miss? I know the kit is working because the first pass I made on sunday with the bottle off was a 14.7 @ 92 mph with a 2.1 60' time. The second pass with the bottle on at 800psi was also a 14.7 but part way through I had to back off the throttle so I only ran at 86mph with a 1.9 60' time. Why would it not miss in first get and only in second?
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #2 of 3 (permalink) Old 10-13-2004, 08:39 PM
VicRattlehead's Avatar
what are your plugs gaped to?? sounds a little like the spark is being blown out. regap the plugs to like .35-.38
CMP Drag Racing
VicRattlehead is offline
post #3 of 3 (permalink) Old 10-13-2004, 08:45 PM Thread Starter
VA Chapter Director
The plugs are gapped to the stock specks right now ( .52 - .56) and are only about 6 months old. The instructions didn't say anthing about changing the plugs unless you were running a big shot. Why wouldn't it do the same thing in 1st gear at the same rpms?
