Zex kit works. - TCCoA Forums
post #1 of 19 (permalink) Old 10-26-2004, 05:33 PM Thread Starter
VA Chapter Director
Jason Miller's Avatar
Send a message via AIM to Jason Miller
Zex kit works.
For anyone wondering how easy it is to use the Zex Dry kits I highly recomend them. I ran mine at the track for the first time with the 55 shot in it and it makes a big difference. My previous best was a 14.15 @ 96.6. Saturday I made a pass with the kit on and swapped blower pullies for less boost. I didn't want to blow things up on the first pass so I went back to the stock pully from the 10% pully I was running during the 14.15 pass. I only got a chance to make one pass but it was all I needed to break my own recond. I now have a new best time of 13.69 @ 96.3. Now we'll see what happens when I step up to the 75 shot.
Member MAMN12 Drag Racing team Best ET 12.44 @109mph
Click here to check out the Mid Atlantic chapter
Jason Miller is offline
post #2 of 19 (permalink) Old 10-26-2004, 06:08 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea lots of us here use the zex dry kit. its a great kit and very easy to install. i went from 15.00 to 13.75 with just the addition of the zex kit (75 shot) and 4.10 gears. i'd reccomend it over other kits just for its ease of installation. no solenoids and crap to mess with.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #3 of 19 (permalink) Old 10-26-2004, 06:32 PM
NUHBOY4.6's Avatar
Send a message via AIM to NUHBOY4.6
what other things need to be taken care of to run this kit? my car is basically stock except a sct chip, could i run this system with a low shot like 55 or 75 without blowing stuff up. im planning on having santa bring me a kit after watching you smoke that ss camaro.
***image removed from signature due to rule violation***
NUHBOY4.6 is offline
post #4 of 19 (permalink) Old 10-26-2004, 07:01 PM Thread Starter
VA Chapter Director
You can probaly get away with running a 75 shot with your stock fuel pump. After that I'd look at gettting at least a 190lph in tank pump. I'm running a 255 hi pressure unit in mine but I also have a blown motor. Other than that it's pretty much a plug and play deal.
post #5 of 19 (permalink) Old 10-26-2004, 07:03 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
you can run a 75 shot or smaller with no upgrades to the fuel system. i'd recommend a chip with a separate nitrous tune. its recommended to upgrade to a higher flowing fuel pump and an adjustable fuel pressure regulator if you decide to go over a 75 shot. the regulator and fuel pump arent a bad idea no matter what shot your running though. the zex kit is the safeest and smartest kit out there. it is controlled by bottle pressure and only adds as much fuel enrichment as is neccessary. i'm still running on the stock fuel system but i plan to upgrade to a walbaro 255 lph fuel pump and adjustable pressure reg. over the winter then step up to a 100 shot. but to run a 75 shot or less all you'll need is the nitrous kit and i'd recommend a chip with a nitrous tune.
Frank
edit: looks like you beat me to it
2007 Dodge Ram 1500
Previous Rides:
post #6 of 19 (permalink) Old 10-26-2004, 07:07 PM
NUHBOY4.6's Avatar
the only time i would really use it would be on the track, if i had my chip tuned to a no2 setting would it screw up normal driving burn that i have now. im just looking for a mild kick in the a$$.
post #7 of 19 (permalink) Old 10-26-2004, 07:12 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
well usually a chip will bump timing and bumped timing + n2o = boom. not always the case with smaller shots but you want the timing at least back to stock when you run nitrous and then if you run bigger shots you need to pull some timing. if you get a flip chip like i got, i have a naturally aspirated tune and a n2o tune. i always use the n/a tune and then just flip to the n2o tune with a switch when i want to use the nitrous. you can switch the tune on the fly too.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #8 of 19 (permalink) Old 10-27-2004, 06:56 AM
NUHBOY4.6's Avatar
so if i dont get a flip chip i would be in trouble? and if so, do i have to buy a totally new chip or can modular depot reconfigure the sct ship i already have. any idea on the cost.
post #9 of 19 (permalink) Old 10-27-2004, 10:46 AM
FordFanatic's Avatar
im running a 55 shot in mine right now with my chip in and i have no problems. i do however plan on having another program burnt to the chip before i move to anything higher. if you already have a flip chip i would pm lonnie and see what it will cost ya.
FordFanatic is offline
post #10 of 19 (permalink) Old 10-27-2004, 10:49 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea if its a sct 4 position chip already, you should be able to just have another program added to it. should be around $75-$100 for the nitrous tune.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #11 of 19 (permalink) Old 10-27-2004, 11:00 AM
alittle off subject but how are you launching off the line now fdawg97lx. i havent had a chance to get to the track yet and am curious as to if i can still floor it and not smoke the tires.
post #12 of 19 (permalink) Old 10-27-2004, 11:10 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
i launch at about half throttle until i know i'm hooked up then tot he floor. i tried launching full throttle with the nitrous on my street tires, bad idea. i noticed i could leave at about 2/3 to 3/4 throttle once i dropped the tire pressure down to 25 psi. The track i race at is prepped really bad usually though so i was never able to launch at full throttle without spinning.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #13 of 19 (permalink) Old 10-27-2004, 11:11 AM
cool thanks, i have no idea how this track down here is so i guess i'll just have to see what happens.
post #14 of 19 (permalink) Old 10-27-2004, 04:26 PM Thread Starter
VA Chapter Director
Frank,
Sounds like your next upgrade is going to be to get yourself a set of Drag radials. When I launched mine the DR's I have hooked as long as I got them good and hot.
Here's a picture from my first nitrous shot down the track.
post #15 of 19 (permalink) Old 10-27-2004, 05:05 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yup drag radials are on the list with the fuel pump. i'm hoping for 13.2-13.4's with the drag radials and the 100 shot.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #16 of 19 (permalink) Old 10-29-2004, 01:28 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
Jason, can you say 12's LOL!!!!!!!
They can be driven any way you like, street tires, drag tires whatever, but I think what Frank is talking about is consistency. Jasons car on the 55 and drags ran consistently every pass, as long as all the variable are under control.
Its fun learning to drive them either way. Drag tires are the way to go however and the 60's will blow your mind. Nothing like having your couch slam you back when you nail the throttle, if its hooking. Otherwise as most are finding out, all that power goes up in smoke.
With a little practice though you can run well at the track on street tires. Franks car pulled great numbers on them and mine has gone 12.7's on regular street tires as well.
Looks like more folks will be registering on the nitrous rosters!!!
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #17 of 19 (permalink) Old 10-29-2004, 02:27 PM
Just to let everyone know, the NOS kit for 89-93 mustangs work very well for our cars too.
post #18 of 19 (permalink) Old 11-01-2004, 03:59 PM
You ain't kidding........
My birdie is now under construction.........
Time to buy some rice for the winter...
DMcBrideBoston is offline
post #19 of 19 (permalink) Old 11-01-2004, 06:50 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
this is probably one of the more important parts of drag racing that goes over looked. it doesnt matter how much power and torque the car has if the driver cant get the car down the track. The only way to keep this variable controled is with practice and experimentation. Find out what works best for you and your application. People think that because car and driver tested a certain car and ran 13.4 that they can go buy that car and run 13.4's automatically. i see/hear this all the time and i just laugh to myself.
Frank
2007 Dodge Ram 1500
Previous Rides:
