Zex Line Is To Short - TCCoA Forums
post #1 of 15 (permalink) Old 11-23-2004, 08:13 PM Thread Starter
NUHBOY4.6's Avatar
Send a message via AIM to NUHBOY4.6
Unhappy Zex Line Is To Short
i ran the line tonight from the zex kit. went right under the tank through a drain hole in the trunk, and along the filler neck and the rest of the way with the fuel lines. only made it up to the fire wall, about 2-2 1/2 ft. short to where i planned on having the box on the apron by the cai. does zex sell small sections of line with fittings or do i need to find something local. any experienced info or help would be appreciated.
***image removed from signature due to rule violation***
NUHBOY4.6 is offline
post #2 of 15 (permalink) Old 11-23-2004, 08:19 PM
Kentwood's Avatar
Send a message via AIM to Kentwood
Don't they use std AN line for that?
Live in Louisiana? - Check out the LA Chapter forum!
http://forums.tccoa.com/forumdisplay.php?forumid=78
Kentwood is offline
post #3 of 15 (permalink) Old 11-23-2004, 08:27 PM Thread Starter
NUHBOY4.6's Avatar
yes, i belive so.
post #4 of 15 (permalink) Old 11-23-2004, 08:29 PM
Kentwood's Avatar
yes, i belive so.
Then just figure out the size AN it is and buy a AN coupler and run some SS flex hose to where you need it.
www.raceplumbing.com
Kentwood is offline
post #5 of 15 (permalink) Old 11-24-2004, 05:10 AM
FordFanatic's Avatar
yeah you can buy extra hose, its pretty expensive though. there is enough hose with the kit if you lay everything out just right. that was the longest part of the install for me.
FordFanatic is offline
post #6 of 15 (permalink) Old 11-24-2004, 06:31 AM
I think you just need to do some rerouting.
Rich95XR7 is offline
post #7 of 15 (permalink) Old 11-24-2004, 07:13 AM
I believe nitrous line is a little different than standard braided line. call summit and ask them for a 4 ft nitrous line and a coupler (male-male fitting ((AN))) That's what I had to do
whitecoug is offline
post #8 of 15 (permalink) Old 11-24-2004, 04:59 PM Thread Starter
NUHBOY4.6's Avatar
all taken care off, went to the local speedshop an bought a 4ft line and union for 13 bucks.
post #9 of 15 (permalink) Old 11-25-2004, 01:37 AM
Good deal. Make sure that the line is rated for nitrous pressure though (700-900 psi)...you wouldn't want to blow a line or something like that...it would be bad to say the least.
post #10 of 15 (permalink) Old 11-25-2004, 01:40 AM
You should be spraying well over 700 psi....
Should be around 1000-1050 per many nitrous threads.
DMcBrideBoston is offline
post #11 of 15 (permalink) Old 11-26-2004, 06:38 AM Thread Starter
NUHBOY4.6's Avatar
i told him what it was for and it is the same quality 4an line that came with the kit.
post #12 of 15 (permalink) Old 11-30-2004, 11:58 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
the line that came with my zex kit was long enough, i beleive it was 17 ft. i actually had about 2 extra ft. that i tucked up under the capet in the trunk.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #13 of 15 (permalink) Old 12-01-2004, 08:16 AM Thread Starter
NUHBOY4.6's Avatar
the guy i got the kit from had it in a stang. i ran it stright up with no out of the way routing taking up slack. closest it came was the top of the fire wall.
post #14 of 15 (permalink) Old 12-01-2004, 08:31 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
yea my kit was for a stang too. i mounted the box right next to my cai and ran the linesover the shock tower and down the fire wall then right along the fule lines. then right near the rear tire theres a drain plug for the trunk i ran the line up there and had a bunch of extra line. my feed line comes into the trunk up near the back seats and then i just ran it under the carpetto the bottle and cut a hole in the carpet to connect it to the bottle.
frank
2007 Dodge Ram 1500
Previous Rides:
post #15 of 15 (permalink) Old 12-01-2004, 06:49 PM
frank
Mine was routed the same way except we cut a whole in my trunk and went along the fuel line that way.
