Stalls when purging ... - TCCoA Forums
post #1 of 15 (permalink) Old 07-31-2005, 05:23 PM Thread Starter
ResqBird's Avatar
Ok, there probably is an easy explanation and it has something to do with me being a dumb a**. Every time I purge the system, the motor will stall, then shortly after that, I get a check engine light with a p1443 code. I have the zex 75 dry system if that helps.
ResqBird is offline
post #2 of 15 (permalink) Old 07-31-2005, 09:59 PM
Aaron_T's Avatar
Did it ever work right?
If not, just a guess but maybe you have something wired wrong so that when you hit the purge button the Zex brain pulls vacuum thus having the EEC add more fuel.
Where in the main feed line do you have the purge solenoid connected?
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #3 of 15 (permalink) Old 07-31-2005, 11:34 PM Thread Starter
ResqBird's Avatar
From looking at it, it looks like the solenoid is connected about 20 inches before the brain. I don't know much about the system, it was installed before I bought the car, I'm just learning about it.
ResqBird is offline
post #4 of 15 (permalink) Old 08-01-2005, 12:08 PM
Whining Intakes Rock
Al_Florida's Avatar
You should follow the wiring and check for a short. In fact if it was me, I would yank the whole thing and rewire it again using fuses and relays.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #5 of 15 (permalink) Old 08-01-2005, 02:20 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #6 of 15 (permalink) Old 08-01-2005, 11:03 PM Thread Starter
ResqBird's Avatar
Yeah, I think changing the wiring isn't the problem. It is all fused and working properly. The only thing I can think of is, the brain has a vacum line running from it to a port on the upper mainifold and another line running to a diaphram (looks like a small EGR valve) behind the EGR valve.
ResqBird is offline
post #7 of 15 (permalink) Old 08-01-2005, 11:14 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
the brain has nothing to do with the purge solenoid though. and that second vaccuum line is going to the fuel pressure regulator. thats how your car knows to add more fuel when you use the nitrous.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #8 of 15 (permalink) Old 08-01-2005, 11:54 PM
Al_Florida's Avatar
Yeah, definately sounds like someone messed up the wiring.
# 0 rows returned
post #9 of 15 (permalink) Old 08-02-2005, 12:00 AM
Al_Florida's Avatar
I knew this sounded familiar:
http://forums.tccoa.com/showthread.php?t=62551
This isn't the same car is it?
# 0 rows returned
post #10 of 15 (permalink) Old 08-02-2005, 09:44 AM
Aaron_T's Avatar
Frank
The reason I thought it may have something to do with the brain is if for some reason when the purge button is hit, it somehow is sending power to it/activating it, and if it were to activate it could be flooding out the engine since the nitrous should be going into the purge solenoid instead of getting to the Zex brain.
Plus he's getting a code that could be related to something like that.
They are right thought. The smartest thing to do would be to just redo everything.
It would suck for something to either happen to your motor or something else because of someone elses install. Or at the very least pull everything relating to the purge (except maybe the solenoid) and redo that.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #11 of 15 (permalink) Old 08-02-2005, 02:03 PM
Al_Florida's Avatar
Would it be possible for you to take some pictures of the setup under the hood? Specifically where the vacuum hoses are routed to from the controller.
# 0 rows returned
post #12 of 15 (permalink) Old 08-02-2005, 03:59 PM
Al_Florida's Avatar
That's actually a good point. It would help to have a pic of the install. If the line is running to the evap valve and not the FPR.
# 0 rows returned
post #13 of 15 (permalink) Old 08-02-2005, 08:26 PM Thread Starter
ResqBird's Avatar
Thanks so far for all the imput... I'll get some photos up tonight. And yes Al_ Florida it is the same car as the one in the link. Good catch.
I am pretty fluent in wiring, so I'll start with the wiring to the switch (including the ground) and see what happens.
ResqBird is offline
post #14 of 15 (permalink) Old 08-06-2005, 01:00 PM Thread Starter
ResqBird's Avatar
Well here is a basic photo of the hook ups... I'll try to get a more detailed one if needed.
ResqBird is offline
post #15 of 15 (permalink) Old 08-08-2005, 02:32 PM
Al_Florida's Avatar
Yeah if you could. Hard to tell what's what there in the left most box.
# 0 rows returned
