Is it possible? - TCCoA Forums
post #1 of 16 (permalink) Old 10-09-2005, 05:52 AM Thread Starter
Is it possible?
I have a 75 shot nitrous system on my car..And i want to have a more powerful system,do i have to buy a complete system in order to get more power? or can i just change some parts of the system i already have to gain more power through nitrous?
Wheelman - JoZeF is offline
post #2 of 16 (permalink) Old 10-09-2005, 06:23 AM
Which Nitrous Kit do you have exactly?
DMcBrideBoston is offline
post #3 of 16 (permalink) Old 10-09-2005, 06:29 AM Thread Starter
Nos
post #4 of 16 (permalink) Old 10-09-2005, 06:35 AM
Model #? Wet Kit? Dry Kit? Nozzle? Fogger?
post #5 of 16 (permalink) Old 10-09-2005, 10:15 AM Thread Starter
i dont recall cuz i swapped parts for that kit and it was modified by my friend to fit a carb setup..so i dont really know..but generally speaking is it possible if i change the pumps and the solenoids?
post #6 of 16 (permalink) Old 10-09-2005, 10:21 AM
In some kits it is, but I cannot tell you for sure without knowing which you do have. You'll need to do some research on the parts in your kit to know for sure. If you have a mutt kit I don't think anyone here will be able to say for sure..
post #7 of 16 (permalink) Old 10-09-2005, 10:24 AM Thread Starter
ahh crap..thanks anyway guess i have to look into my kit a bit more
post #8 of 16 (permalink) Old 10-09-2005, 11:18 AM
Whining Intakes Rock
Al_Florida's Avatar
If you are going to run nitrous, fully understand all components of the system. It's not just a bolt on and go. Understanding how it works and more importantly how to tune it is the only way you will use it to its fullest potential. Otherwise, you'll just be replacing engines.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #9 of 16 (permalink) Old 10-09-2005, 12:55 PM Thread Starter
what u said is understood i do get the components and that i have to tune to a certain air fuel ratio or my engine would crap itself out of my exhaust pipes i get that,but this is a question that popped up in my head u know?
post #10 of 16 (permalink) Old 10-09-2005, 01:14 PM
Al_Florida's Avatar
Yeah, and it's good that you want to learn it.
Usually you change the jet, nozzle or spray bar size to add more. You're solenoid is just an on/off but it will have a flow limit. Do you have any model numbers on these parts to reference?
# 0 rows returned
post #11 of 16 (permalink) Old 10-09-2005, 01:15 PM
Originally Posted by Wheelman - JoZeF
Nos
Just to let you know, I couldn't find a kit with less than 150hp on the NOS website...
post #12 of 16 (permalink) Old 10-09-2005, 02:21 PM
Aaron_T's Avatar
Yea most kits aren't gonna be limited to a 75shot. You can even get a little over a 200 shot out of the standard NX wet kit by removing the jets altogether
I'd unscrew the nozzle from the lines and see what size jet(s) are in there.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #13 of 16 (permalink) Old 10-09-2005, 03:58 PM Thread Starter
hehehe thanks all u guys big help..im gonna have to go and see what kit do i have and ill let all u guys know,cuz my car has been under heavy duty work for around a month now,i havent driven my baby in a month and its KILLING ME..ill let you all know how everything goes (Y)
post #14 of 16 (permalink) Old 10-11-2005, 10:20 AM
hmm, my 5115 kit came preset from NOS at 75hp.
post #15 of 16 (permalink) Old 10-11-2005, 12:40 PM
ITT-BIRD's Avatar
I have a friend that did just that ... well not purposely though. he was changing from 75 to 100 shot and someone got him sidetracked. by the time he came back to it he had forgotten that he didnt have any jets installed. He said it was hauling a$$ til the engine went. 98 v6stang.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #16 of 16 (permalink) Old 10-24-2005, 05:44 PM
Teeps's Avatar
ultimately the nitrous system is limited by the inner diameter of the hoses between the tank and the solenoid, any subsequent fittings between that may have smaller diameter than the hose, or a solenoid that might have a smaller diameter.
Usually the nitrous jet will be the limiting point, but if you get to the 175 horse range, on some kit's its the hose fittings, and or solenoids.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
