Window switch questions - TCCoA Forums
post #1 of 5 (permalink) Old 11-08-2005, 10:48 AM Thread Starter
i'm in the process of setting up a NX wet kit on my bird, and i'm kinda partial to my intake manifold, so i ordered a NX (pretty sure it's made by MSD) window switch. can someone explain to me what these tach adapters are all about? how do they work, and where do you wire them to?
also, i was digging through the forums here and found this thread which indicates that i can tap into the wire from pin #48 for a tach signal. could i do this instead of using the tach adapters?
ThunderChicken1 is offline
post #2 of 5 (permalink) Old 11-08-2005, 11:14 AM
Yes, you can hook the tach lead from the window switch straight to the white/pink wire coming out of the back of the gauge cluster. You don't need tach adapters. they're meant to change the signal from the coils to one the window switch can understand.
JoelBender is offline
post #3 of 5 (permalink) Old 11-10-2005, 02:42 PM Thread Starter
that's exactly what i wanted to hear. now, i wonder if i should battle with taking the dash apart, or digging through the harness on the EEC....decisions decisions...haha.
thanks man!
post #4 of 5 (permalink) Old 11-10-2005, 03:39 PM
Aaron_T's Avatar
I had my EEC already on the floorboard so it wasn't too big of a deal to tap into the wire there. However you don't have much at all to work with, so I think taking the dash apart would be easier.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #5 of 5 (permalink) Old 11-16-2005, 11:04 AM Thread Starter
i still haven't gotten around to it, but yeah i've got the EEC dangling from the harness lying on the floorboard as well. there's not much slack to work with there, but i think i'll manage.
thanks
