125hp Shot - TCCoA Forums
post #1 of 6 (permalink) Old 05-10-2006, 10:25 AM Thread Starter
125hp Shot
I know there is a few things I need up upgrade to go from a 75hp shot to a 125hp shot on my Zex kit. I know I need a new fuel pressure regulator, fuel pump, and a tune. Do I need bigger fuel injectors? Does anyone know the part numbers for the fuel pressure regulator and the fuel pump that I will need to run the 125hp shot.
MadeInDade is offline
post #2 of 6 (permalink) Old 05-10-2006, 11:32 AM
The Great Obucina's Avatar
might as well get blue top 24lb injectors...get a 255lph pump, and for a regulator, I run an Aeromotive and get a pressure gauge for the regulator.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 6 (permalink) Old 05-10-2006, 12:18 PM
FordFanatic's Avatar
get your pump from the place in my sig, they are the cheapest place around.
FordFanatic is offline
post #4 of 6 (permalink) Old 05-10-2006, 03:51 PM
Whining Intakes Rock
Al_Florida's Avatar
You still running a stock engine? Your chances of wasting the stock pistons will be high on a 125 shot.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #5 of 6 (permalink) Old 05-10-2006, 04:09 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
An Aeromotive or BBK regulator should work fine. I've used both. The ZEX kit is set -up for the stock 19 lb injectors and the stock motor and 93 Octane fuel. But safer is better !. I'm also assuming this is a DRY KIT?
I ran everything from 55 up to 125 HP Shot on my stocker for years with no problems. I pulled the factory stock shortblock out with 116K miles on it with no problems when I put the other stock motor in with the PI/bullitt stuff. I'm still running the 125 shot on it. It can be done if you monitor what you are doing.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #6 of 6 (permalink) Old 05-10-2006, 04:34 PM Thread Starter
Yes, it's a dry kit.
