Real Dumb Question.. Or is it?! - TCCoA Forums
post #1 of 22 (permalink) Old 08-25-2006, 09:03 AM Thread Starter
Tx_Cat's Avatar
Ok, would it be possible, a good advice, a wise thing to do, is get the tanks that you use to weld to put nitrous and use it in your car? I see why I could not be possible to do, what do you guys think?!
Israel
Tx_Cat is offline
post #2 of 22 (permalink) Old 08-25-2006, 05:29 PM
i don't know if i would take the chance i mean bottles aren't that expensive, but i think if i can handle the pressure of the nitrous then it would work
krazy4 is offline
post #3 of 22 (permalink) Old 08-25-2006, 05:41 PM
But why would you want to. Just asking but I think it would work
84 Fila is offline
post #4 of 22 (permalink) Old 08-25-2006, 06:15 PM
maybe he wants people to think the welder is just to weld and not produce hp gains
krazy4 is offline
post #5 of 22 (permalink) Old 08-28-2006, 05:51 AM
Personally I wouldn't, as most gas cylinders are color coded. If you were in an accident or something and they popped your trunk and saw say a green tank they would think it was oxygen (for example). Also the valves on the tanks may be different as well (not sure). Plus, a full size tank weighs significantly more than a 10 lb nitrous bottle...which would be something you wouldnt want in racing and it would require a lot of tie down strength to hold it in place.
whitecoug is offline
post #6 of 22 (permalink) Old 09-03-2006, 02:23 AM
jesusraybrown's Avatar
The only disadvantage I would see would be weight. It would be cool if you had an acetylene (sp?) cylinder in your trunk, nobody would think twice about you havin' any squeeze. But you could just hide the no2 bottle in the spare well, or in a batman duffle bag for instance. Just get a nitrous bottle, paint it black or red, and put an acetylene sticker on top of it. No one will know... hopefully.
1. This forum requires that you wait 30 seconds between sending private messages. Please try again in 266079416 seconds. wtf?
jesusraybrown is offline
post #7 of 22 (permalink) Old 09-03-2006, 01:24 PM
Street Freekz
96_Cougar's Avatar
Send a message via MSN to 96_Cougar Send a message via Yahoo to 96_Cougar
As a volunteer firefighter I wouldn't recommend using a tank except for what its purpose was intended for. If you would wreck and you had something in the tank other than what the tank color indicated it is a very big threat to safety personnel. We partly rely on the tank colors to identify what its contents are....
In Memory of FD 420
"This will remain the land of the free only so long as it is the home of the brave" ~ Elmer Davis, American news commentator (1890-1958). God bless all veterans: past & present.
96_Cougar is offline
post #8 of 22 (permalink) Old 09-03-2006, 08:50 PM
yep hide the bottle in a bag, thats the way to do it.
krazy4 is offline
post #9 of 22 (permalink) Old 09-03-2006, 10:03 PM
I would worry about gases mixing, I would guess that O2 and N2O would be ok together, but acetylene or something else could cause a reaction when mixed.
Another thing I would wonder about: would any reputable place even put N2O into a bottle that wasn't designed/labeled for the same?
post #10 of 22 (permalink) Old 09-03-2006, 10:56 PM
VicRattlehead's Avatar
no they wouldnt
CMP Drag Racing
VicRattlehead is offline
post #11 of 22 (permalink) Old 09-04-2006, 12:47 PM Thread Starter
Tx_Cat's Avatar
Reason I posted this is because the prices NItrous bottles are just to damn high, I aint paying $165 for a 10lbs nitrous bottle when I can get two tanks for welding purposes and use them as regular NOS bottles. That is why I posted this!
Tx_Cat is offline
post #12 of 22 (permalink) Old 09-04-2006, 08:54 PM
Street Freekz
96_Cougar's Avatar
Check on eBay if you want a Nitrous bottle for less & I still wouldn't advise putting anything in the tank/bottle other than what it is supposed to have in it......
In Memory of FD 420
post #13 of 22 (permalink) Old 09-04-2006, 08:58 PM
nitrous is not cheap. if you think that, your stupid.
CMP Drag Racing
post #14 of 22 (permalink) Old 09-04-2006, 09:19 PM Thread Starter
Tx_Cat's Avatar
I never said or thought that nitrous was cheap, I said the bottle where. Read the post. I aint stupid. And I have checked on ebay.!
Tx_Cat is offline
post #15 of 22 (permalink) Old 09-05-2006, 07:03 PM
Ebay has some cheap nitrous just make sure the seller has legit feedback
krazy4 is offline
post #16 of 22 (permalink) Old 09-08-2006, 08:43 PM
Hittin' Switches
musto's Avatar
Send a message via AIM to musto
75hp for 200 bucks? 40 bucks to refill the tanks.
sounds pretty reasonable to me.
musto is offline
post #17 of 22 (permalink) Old 09-08-2006, 09:00 PM
Street Freekz
96_Cougar's Avatar
I’d still go with eBay for a NOS bottle; just make sure the seller has legit feedback. NOS isn't extremely expensive but its not that cheap either. Long as it was $200-250 or less then I'd go for it!! Just my .02 again
In Memory of FD 420
post #18 of 22 (permalink) Old 09-08-2006, 09:23 PM
Refrigerator Raider Hater
GreenBird's Avatar
$40 again and again and again...
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #19 of 22 (permalink) Old 09-09-2006, 03:14 AM
bottle, lines, selanoids,fuel pump, tune, purge, heater, etc etc etc. lots more then 200 measly bucks.
CMP Drag Racing
post #20 of 22 (permalink) Old 09-09-2006, 10:56 PM
Street Freekz
96_Cougar's Avatar
He was just asking about the NOS bottle. Its not cheap by any means for the entire set-up.
In Memory of FD 420
post #21 of 22 (permalink) Old 09-10-2006, 10:04 PM
did you even read the post i was replying to?
CMP Drag Racing
post #22 of 22 (permalink) Old 09-18-2006, 09:13 PM
bowez's Avatar
You would be just fine to use a CO2 tank, the only issue would be getting someone to fill it. You have to use inert gas threads (forget the number) though and not CO2 fitting threads.
I've personally been leaning toward spent fire extinghers, but I only want/plan on using CO2 and NO2 and only for fogging my IC.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
