Getting Nitrous But First a Couple ?'s - TCCoA Forums
post #1 of 20 (permalink) Old 09-14-2006, 02:11 PM Thread Starter
greencurse's Avatar
I talked to my local dyno/speed shop and they are going to install a Compucar Dry nitrous system with 75, 90, and 125 horsepower jets it is going to be activated by a window switch. They are also going to install 4.10 gears, a limited slip differential, Mark VIII driveshaft, Maruader torque converter and the SCT Excalibrator 2 Tuner. I have heard that i may need to get a high flow fuel pump as well, but as i am only going to be using the 90hp jet i am not absolutely positive it is necessary. Also what would be the benifit or the Marauder converter over stock because if its not much more than a traction benifit i will not do that to save some labor cost but i will be doing it after. If you have any insight into the necessity of the fuel pump and the Marauder TC as well as other necessary supporting mods to keep my car runnig please let me know as this is all going to start coming together very soon.
Thanks in advance
Edit: it seems that the others that have nitrous are split between getting the fuel pump and not but as the shop said a fuel pump is not priority on such a small hit... if you have any conflicting evidence (ie. blown motor) please let me know... as for the converter i think i'm going to do it but just convince me
1997 Thunderbird LX, 4.6L, Performance White.
3.27 TL, 300hp J-Mod, Mid-Mount Magnaflow w/2.25" True Duals to 3" Magnaflow 15* Slash Cut Tips, PI Intake,
FR500 Steering Wheel, FRPP Wires, 180* T-Stat, 22C Plugs, Cobra Vert Rears, RSTB, SC "L" Braces. 175k and still flying!
greencurse is offline
post #2 of 20 (permalink) Old 09-14-2006, 02:27 PM
Mark M. TCCoA VP's Avatar
Over a 75 shot you should upgrade the pump. You only have a 110LPH pump stock.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 20 (permalink) Old 09-14-2006, 02:31 PM
I can't help you with the nitrous, but please tell us you have a tranny cooler and a complete J-Mod in the tranny.
69 F100 LWB w/460 Engine
post #4 of 20 (permalink) Old 09-14-2006, 05:20 PM
VicRattlehead's Avatar
im running a compucar kit. id get the fuel pump.
CMP Drag Racing
VicRattlehead is offline
post #5 of 20 (permalink) Old 09-14-2006, 08:42 PM
get the fuel pump and it seems like you would be ready to run
Have fun
I want nitrous so badly
krazy4 is offline
post #6 of 20 (permalink) Old 09-15-2006, 09:24 AM Thread Starter
greencurse's Avatar
sorry no to both
also what size fuel pump do i need and what do i need to get to use the big 125hp jet?
post #7 of 20 (permalink) Old 09-15-2006, 09:49 AM
125 jets = fuel pump (255lph) forged pistons (diamond makes some nice ones) forged rods (manley makes nice ones) forged crank (a cobra crank will do fine) and a replacement intake just in case, and some 30+lb injectors
CMP Drag Racing
post #8 of 20 (permalink) Old 09-15-2006, 10:23 AM Thread Starter
greencurse's Avatar
wow!!! nevermind i think i will stick with the 90 hp jet... i'm glad i asked before i got it tuned for 125 because it would have gone BANG...
i think i will stick with a dry 90 shot and just use a 190lph pump does that sound good?
post #9 of 20 (permalink) Old 09-15-2006, 10:29 AM
The price dif between the 190 and 255 is very little so I would just get the 255 to be on the safe side.
post #10 of 20 (permalink) Old 09-15-2006, 10:34 AM Thread Starter
greencurse's Avatar
thank you i will do that
post #11 of 20 (permalink) Old 09-15-2006, 12:21 PM
The Great Obucina's Avatar
95LPH........that was stamped on my pump when i pulled it out.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 20 (permalink) Old 09-15-2006, 06:45 PM
90hp jets list reads like this. fuel pump (255lph) forged pistons (diamond makes some nice ones) forged rods (manley makes nice ones) forged crank (a cobra crank will do fine) and a replacement intake just in case, and some 30+lb injectors
CMP Drag Racing
post #13 of 20 (permalink) Old 09-16-2006, 05:28 PM
he will be fine on the 90hp shot. Make sure you get colder plugs and retard your timing.
krazy4 is offline
post #14 of 20 (permalink) Old 09-20-2006, 09:20 AM Thread Starter
greencurse's Avatar
so all i need to do is upgrade the fuel pump!!! thats exactly what i wanted to hear thanks to all for your help!
post #15 of 20 (permalink) Old 09-20-2006, 09:54 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
The 4.6 seriously needs a built shortblock for 125+? wow, the stock v6 shortblock can take that.
Thomas is offline
post #16 of 20 (permalink) Old 09-20-2006, 10:11 AM
The stock 3.8 can take a 125 shot?
post #17 of 20 (permalink) Old 09-21-2006, 09:48 AM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
I don't know who started that BS cause I've been running a 125 shot on mine (Stock 4.6L internals) for years and never had a problem yet. As far as pushing it beyond that, I don't believe I would till I at least had a built bottom end, which I do not have. We do know the stock bottom end on these motors are weak.
As I've stated before, most that lose engines on that or smaller shots are because of inexperience, prior mechanical problems, or just plain abuse of the system on the car.
If you beat the hell out of it all the time on it, It'll certainly beat back.
Make sure its set up correctly, functioning properly, has all associated upgraded parts to make it safe, and used according to the instructions. All systems vary somewhat. Again, for stock applications and the plastic intakes my recommendation is the dry kits.
Just my 2 cents.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #18 of 20 (permalink) Old 09-21-2006, 10:08 AM
Yep Steve is dead on. I can up mine to a 150 shot as the 5.0 should take it fine but I am staying with the 100 shot. Sir William ran his 4.6 for years on a 150 shot without a problem and that was a wet system. What most of us are saying is don't get greedy with the nitrous and stay on the safe side unless you like waking on the edge. Steve played it safe and limited his to a 125 and that was after much work and tuning. I knew a guy who took an almost stock 3.8 and with gears, converter and a 110 shot and pushed his bird way into the 13s but that is playing with fire. Just my .02 cents
post #19 of 20 (permalink) Old 09-21-2006, 10:40 AM
1MTNCAT's Avatar
Mark is correct on the 5.0's. If they are in good condition they can generally accept up to 175 shot. I've seen this on numerous occasions. The shortblocks on those tend to handle it better.
Irregardless, err on the side of caution. Woulda, coulda, shoulda, gets you no where but along the side of the road with a blown engine.
Let your conscious be your guide.
Happy modding!
Steve
1MTNCAT is offline
post #20 of 20 (permalink) Old 09-22-2006, 08:03 PM
i say just stick with the 90hp jets then you won't have much to worry about
krazy4 is offline
