Nitro Q's - TCCoA Forums
post #1 of 17 (permalink) Old 01-02-2007, 11:20 AM Thread Starter
MR95XR7's Avatar
Send a message via AIM to MR95XR7
Question Nitro Q's
If i install a nitro kit on a stock 4.6 what would be a good shot without damaging the engine? Oh the engine has 90,086 miles on it. Maybe a 50-75 shot? I ask cause a freind has a kit that he is willing to trade me. a dry kit i think. any help would be appreciated.
SAL.
"Alive man is pliable and weak
Dead he is firm and strong"
- sun pin.
"There is no better weapon than a marine and his rifle"
http://www.cardomain.com/ride/761335/1
MR95XR7 is offline
post #2 of 17 (permalink) Old 01-02-2007, 11:26 AM
Mark M. TCCoA VP's Avatar
Nitro as in Nitroglycerin ? or Nitromethane ?
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #3 of 17 (permalink) Old 01-02-2007, 12:41 PM
FordFanatic's Avatar
i always wondered why he switched to the turbo.
FordFanatic is offline
post #4 of 17 (permalink) Old 01-02-2007, 01:05 PM Thread Starter
MR95XR7's Avatar
oxcide
- sun pin.
MR95XR7 is offline
post #5 of 17 (permalink) Old 01-03-2007, 08:09 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
75 would be good. upgrade your fuel pump and possibly your injectors too. depends what kit you use
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #6 of 17 (permalink) Old 01-03-2007, 08:53 PM
ohhhhh... you mean nitrous i think some people were confused
75 shot would be good but the stock fuel system should be able to handle that, but anything over that should have an upgraded pump.
krazy4 is offline
post #7 of 17 (permalink) Old 01-04-2007, 06:33 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
i'd at least upgrade the pump even with the 75 shot. at 90k that pump might be getting a little tired anyway. add nitrous to the equation and u might lean it out and blow it up. $100 fuel pump is much cheaper than a new engine
2007 Dodge Ram 1500
Previous Rides:
post #8 of 17 (permalink) Old 01-04-2007, 07:41 AM
awe snap he blew the welds on the intake manifold and the floorpan fell out! snap crackle!
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #9 of 17 (permalink) Old 01-04-2007, 01:40 PM
the fuel pump will be good insurance, just get it
krazy4 is offline
post #10 of 17 (permalink) Old 01-06-2007, 09:34 AM Thread Starter
MR95XR7's Avatar
Thanks for info, what would you recommend a dry kit or wet?
- sun pin.
MR95XR7 is offline
post #11 of 17 (permalink) Old 01-06-2007, 10:49 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
zex dry kit is the easiest to use and easiest to install. i ran that in my thunderbirds. currently in my cobra i run a dynotune kit. requires more tuning and take a lot longer to install
2007 Dodge Ram 1500
Previous Rides:
post #12 of 17 (permalink) Old 01-26-2007, 08:43 PM
tbirdmedic's Avatar
I am no expert, but the ZEX DRY KIT seems to be the way to go.
Q: What is the difference between a "wet" nitrous kit and a "dry" nitrous kit?
A: A wet nitrous kit mixes nitrous and enrichment fuel by means of an injector nozzle that is mounted before the throttle body. This mixture is then drawn into the engine through the throttle body and intake manifold. A "dry" nitrous kit injects only nitrous with it’s injector while at the same time, increasing the engine’s fuel rail pressure to feed enrichment fuel through the engine’s own injectors.
Q: What is better, a "wet" or "dry" kit?
A: It all depends on the application. A "wet" kit is ideal for both normally aspirated applications as well as forced induction applications. It can require a little bit more installation time than a "dry" kit, but is easier to tune if greater than stock HP settings are to be experimented with. A "dry" kit is excellent for normally aspirated combinations that have a return style fuel system. They are very easy to install and are a great "first time" nitrous system. It is not recommended that "dry" systems be used on forced induction engines.
You will want a pressure guage
Bottle Heater
New Fuel Pump from http://supercoupeperformance.com/default.aspx
And possibly injectors. If you dont have a chip, get one.
http://www.blueovalchips.com/
Check around. Quite a few guys are using it.
BTW, use the sellers here for the pump and injectors if you can.
This is my winter mod for my LX, along with a bigger MAF.
TbirdMedic
1995 SUPERCOUPE 5-SPEED
'95 LX with a few mods
tbirdmedic is offline
post #13 of 17 (permalink) Old 02-02-2007, 08:40 PM
I (of course) recommend the NOS dry kit.
Supernatural is offline
post #14 of 17 (permalink) Old 02-03-2007, 08:04 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Bottle Heater
the zex heater sux. i used to have it when i had my bird. get a heater from www.dynotunenitrous.com
2007 Dodge Ram 1500
Previous Rides:
post #15 of 17 (permalink) Old 02-19-2007, 12:13 AM
YOu guys think it is possible to put any NOS into my T-bird. ITs got a 146k and I'm worried the engine would just blow up (same reason I don't put a supercharger on it).
mitchellb3 is offline
post #16 of 17 (permalink) Old 02-19-2007, 02:57 PM
the bottom end on my 96 has over 186k on it and still takes a 125 shot like a champ ,so go for it
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #17 of 17 (permalink) Old 02-19-2007, 09:33 PM
Alright, sounds like fun
