Bottle location pics - TCCoA Forums
post #1 of 24 (permalink) Old 03-19-2007, 10:02 PM Thread Starter
Where do you guys have your bottles mounted, i just want to get an idea for when i get the juice.
Thanks!
krazy4 is offline
post #2 of 24 (permalink) Old 03-19-2007, 10:41 PM
FordFanatic's Avatar
FordFanatic is offline
post #3 of 24 (permalink) Old 03-20-2007, 05:16 PM
VicRattlehead's Avatar
id recommend NOT doing it like FordFanatic has it. heres why, nitrous when in the bottle is in a liquid form, what happens when you accelerate, within the bottle the liquid wants to move in the opposite direction, in this case to the rear of the car. the problem is with the pickup in the bottle, its angled toward the bottom of the bottle towards one of the edges. usually opposite the label on the bottle. so having the bottle perpendicular to the travel of the vehicle the liquid will not be submerged in the nitrous liquid.
so put the bottle parallel to the vehicle direction, label side up with the bottom facing the rear of the car
and putting it on the pass side allows you to run the line along the fuel line, gives you something to attach it to.
CMP Drag Racing
VicRattlehead is offline
post #4 of 24 (permalink) Old 03-20-2007, 09:21 PM
the way i mounted it was straight out of the zex directions so (i assume) the pick-up tube is angled to the right. so if you are going to mount it like i did make sure you read the directions so you don't run into a problem like vic is describing.
post #5 of 24 (permalink) Old 03-21-2007, 03:06 AM
Mark M. TCCoA VP's Avatar
Pass side back seat floor.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #6 of 24 (permalink) Old 03-21-2007, 10:34 PM Thread Starter
very nice guys i just needed some ideas for where to mount the bottle when i start sprayin'
I like the hidden install and Vic how do you like the compucar 5.0 kit did it fit well? Did you use the WOT switch it came with or did you use another one, because some complain about that switch. Hope it worked out good for you because i was looking at that kit.
Thanks guys!
krazy4 is offline
post #7 of 24 (permalink) Old 03-22-2007, 04:25 PM
it works good. and it is the 5.0 kit that i put on my 4.6 (i didnt notice any difference) i am using the compucar switch, its ehh, if i was out to buy one, i wouldnt get it id get something different but it came with the kit. it works. its kinda hard to setup to get it to open at full wot instead of half it took a little bit to get it mounted so it would work right at wot.
CMP Drag Racing
post #8 of 24 (permalink) Old 03-22-2007, 09:17 PM
zex kit# 82015 FTW.
post #9 of 24 (permalink) Old 03-22-2007, 09:44 PM Thread Starter
Ford fanatic i was looking at the 82015 kit, but i think i want a wet kit. Like the 82023 kit. Although the compucar kit is cheap. lol
krazy4 is offline
post #10 of 24 (permalink) Old 03-22-2007, 10:31 PM
if i was to do it over, id get a nx kit
CMP Drag Racing
post #11 of 24 (permalink) Old 03-22-2007, 11:06 PM
just be real careful with the wet kit, intakes and airboxes like to go boom from them.
look around on eghey or on md for a used kit. i picked mine up for around $300.
post #12 of 24 (permalink) Old 03-23-2007, 05:30 PM Thread Starter
Alright im going to look around for a kit.
By eghey you mean ebay and by md you mean modular depot, just making sure.
Im going to look into the NX and ZEX kits, after what vic said. Seems like NX is supposed to make greater gains.
krazy4 is offline
post #13 of 24 (permalink) Old 03-23-2007, 08:29 PM Thread Starter
I think i made up my mind, since that post ^ i have been reading on the zex kit. Looked at the instructions and i could definately do it. Im talking about the #82015 kit by the way. I like how the solenoid and other parts are in the NMU and how the main switch is already assembled all the way.
FordFanatic I know they say it takes 2-3 hours to install, but how long did it take you to install? Im guessing it would take me like 4-5 hours lol.
krazy4 is offline
post #14 of 24 (permalink) Old 03-24-2007, 01:03 AM
yeah that about how long it took me to install because i really took my time and wanted it to be hidden.
and yes i meant ebay and modual depot.
post #15 of 24 (permalink) Old 03-24-2007, 11:48 AM Thread Starter
alright i didn't know if you meant something else
Do you have a pic where you mounted the NMU?
I was looking at my engine bay yesterday and i couln't really find a spot.
krazy4 is offline
post #16 of 24 (permalink) Old 03-29-2007, 05:18 PM Thread Starter
anyone have pics of their NMU location?
krazy4 is offline
post #19 of 24 (permalink) Old 04-01-2007, 03:17 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I have my bottle exactly like vic's, and my battery is located on the other side of the trunk. My ZEX box is where the battery used to be, along with the rpm switch and adjustable rpm box, all my relays, and a distribution box.
Thomas is offline
post #20 of 24 (permalink) Old 04-02-2007, 02:02 AM Thread Starter
alright thanks guys!
krazy4 is offline
post #21 of 24 (permalink) Old 06-05-2011, 05:14 PM
Audio Alchemist's Avatar
I understand the theory of the liquid sloshing on acceleration and turning, and the bottle intake tube. This being said, can I use the brackets to mount the bottle upside down from the package tray in the trunk?
If you can't hear it before you see it...what's the point?
Audio Alchemist is offline
post #22 of 24 (permalink) Old 06-06-2011, 06:09 AM
Roadrunnner's Avatar
I dont see why it wouldnt work. Just swap the bracket around and flip it.
Will
Roadrunnner is offline
post #23 of 24 (permalink) Old 06-06-2011, 04:35 PM
That's what I was thinking. I want to keep it off the floor.
post #24 of 24 (permalink) Old 06-16-2011, 05:34 PM
Well first let me say, you can take the valve off of any bottle and turn the pick up tube to mount the bottle in any orientation you want. Second wet kits don't make things go boom. it is too much timing or not enough fuel and is not wet or dry kit dependent.
fordfreak300 is offline
